Old 11-14-2004, 10:01 PM   #9376
SA_Racer's Avatar
Default Setup for one-way
Does anyone here have a setup for running on a parkinglot track using a oneway .. Not much bite
thanks
SA_Racer is offline   Reply With Quote
Old 11-14-2004, 11:18 PM   #9377
Default Setup
I would also like a parking lot setup but with a spool. I usually run on a totally different surface.
Cheers,
Mossie
Mossie is offline   Reply With Quote
Old 11-15-2004, 10:59 AM   #9378
PaZ
PaZ's Avatar
Iv'e been running my TC3 for almost 3 years now (same car just a bit more blue now ) and i only run stock but reciently when i pull off the start line it sounds like the diffs are slipping cause it sounds like its doing wheel spin but it still shots of the line and it still as quick as the other cars around the track, should i tighten the diffs or just leave it? Also i keep it clean and lubed all the time almost a full strip down every week
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 11-27-2004, 09:54 PM   #9379
Lost Aggresiva's Avatar
I'm just wondering, has anyone tried replacing the TC3 steering rack with the assembly from the TC4?
Lost Aggresiva is offline   Reply With Quote
Old 11-27-2004, 10:43 PM   #9380
I havent tried it, I havent even compared the two assemblys. If you do install it and find it to really help with the car, please post it. It would be something that I wold be interested in.
runnin rc10 is offline   Reply With Quote
Old 11-27-2004, 11:57 PM   #9381
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
it doesn't work
tc3stocker is offline   Reply With Quote
Old 11-28-2004, 04:21 PM   #9382
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
TC3 wins stock touring at US Indoor Championships!!!!!
trackdesigner71 is offline   Reply With Quote
Old 12-01-2004, 05:51 PM   #9383
i was just wondering if anyone out there has any links to site of some set up tips for the TC3. i was looking for things like, battery mod, steering rack mod, and any others you guys have.
thanks
SPZA is offline   Reply With Quote
Old 12-01-2004, 06:13 PM   #9384
sonicboom141's Avatar
Send a message via AIM to sonicboom141
where can i order the team and factory team kit
sonicboom141 is offline   Reply With Quote
Old 12-01-2004, 06:23 PM   #9385
www.towerhobbies.com
Old 12-01-2004, 07:17 PM   #9386
EDWARD2003's Avatar
Set-up for TC3 on ozite carpet
Rubber tires: CS-22's all around med inserts
Reddy QM 19/WR tuned. Blistering fast!!!
NOVAK GTX
PEAK: 1.185
KO 2123 Servo: TC3 servo saver only used.
100/33 spur/pinion
Note: This is a WR PRO Chassis. Handeling may vary to the original TC3 Chassis, and battery mod chassis.
Note: Add stock sway bar to front if traction rolling occurs.
Front
Camber: -1.5
Caster: 4 deg
Shock oil :70 wt
Springs: AsccCopper
Droop level #5 using associated droop guage.
Shock position: Inboard
Toe IN/OUT : 0 deg
5.0 mm
Rear
Camber -1.5
Wheel Base : Short
Shock Oil : 70 wt
Springs: Ascc Silver
Droop level #6 using associated droop guage.
Shock Position: Middle hole
Toe IN/OUT : 3 deg
5.0 mm
Very easy to drive, smooth in the corners and very stable down the straight away. one word!!! STABLE!!!
Tips.
Get a set of vernier calipers, measure each shock shaft. Make sure all four corners are equal ! A MUST!
Make sure each shock has the same compression. Buy LOSI SHOCK DYNO!
Make sure the weights on all fours corners are equal! Balance car is a fast car
Make sure you set the droop equal for the Front L/R and Rear L/R
After ever race make sure the camber hasent changed from a hit!
Get teamlosi xxx-s 4 deg caster/spindel blocks!! yes there for the xxxs but they fit the tc3 without any modifications. why you ask? thre made from stronger materials!
With my set-up it gives a good starting point (i think) You can tinker nw with the spring rates, go up a few rates on the rear.maybe blue?
Good luck.
Edward Pickering
Kingston, Ontario
EDWARD2003 is offline   Reply With Quote
Old 12-01-2004, 07:40 PM   #9387
tornado
Guest
Posts: n/a
Originally posted by EDWARD2003
Tips.
You're absolutely right on this !!
Old 12-02-2004, 04:37 AM   #9388
Trinity2's Avatar
Oops
Trinity2 is offline   Reply With Quote
Old 12-02-2004, 05:59 PM   #9389
Trader Rating: 24 (100%+)
Looking for some advice folks. Just got back into driving a TC3 and I'm looking to try out one of the aftermarket chassis, particularly the IRS or the BMI. Can you guy's pass on some impressions of these 2 if you've had experience with them. Obviously looking for the best performance, quality and service. I've read some of the BMI thread but I can't seem to find much about the IRS.
Evoracer is offline   Reply With Quote
Old 12-02-2004, 06:06 PM   #9390
vtl1180ny's Avatar
R/C Tech Charter Subscriber
When using Mike Blackstock's Snowbirds setup, how the heck is anyone getting 4-5mm of rideheight????
I still lurk....
vtl1180ny is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
