Old 10-27-2004, 11:06 AM   #9361
SammyXp's Avatar
Well it is possible that your drivetrain is not as efficient as his, or his motors/batteries are slightly superior, but the difference might not be nearly as signficant as, for example, if you were able to carry an extra 2-3 mph coming out of a corner.
The bottom line is that it is impossible for us to be able to tell whether or not your car is actually any slower than the car leading you by 1.5s/lap. Challenge him to a drag race in the parking lot, hehe.
SammyXp is offline   Reply With Quote
Old 10-27-2004, 11:50 AM   #9362
Vue Vang's Avatar
For your analysis, my TC3 is equipped with QC2(no big blue capacitor installed), Fukyuma matched batteries (1.71), Monster pro motor, 3degree rear toe in, 2 degree camber all around, front and rear diff. My car is 20g above the min weight. I finished charging the batteries just before the race. The car handled quite well (neutral balance). During heats and the final, I did not crash nor touch any board. I mostly followed the race line.
raceblast if you can run the line of the fast guyst then this is what i suggest, have one of fast guy run in front of you and see if you can keep up. You should be able to see where you are losing time on the track. Do that and if you can keep up with the fast then you should be there.
Vue Vang is offline   Reply With Quote
Old 10-27-2004, 12:21 PM   #9363
rayhuang's Avatar
Raceblast-the simple truth is that to keep up with the best drivers-everything matters. And if those guys run at the front Nationally and your 1.5 sec behind, but very consistent-your not doing that bad.
At our track-we have some of the fastest stock and Mod drivers n the country as regulars and most of us struggle to stay within 0.8 sec to even 2 sec. of them in TC and a full second to 3 sec. per lap beihnd them in 12th scale.
What doesnt seem apparent is there ability to time exactly when to lift, when to turn in, how quickly they return to full throttle. Its VERY, VERY hard to run against the top dogs at any track. There ability alone is 0.5 sec and then all the knowlede about motors, good batteries, excellent car set-up is another 0.5 seconds per lap.
I am not downing you-in fact I struggle with the same dillemma every practice night and every race-how to close the gap. I can say I have killer batterues, a a great car, fast motors, the right tires and the right body-but I am still slower than the top 3 or 4 guys every week.
Pay every close attention to there throttle inputs and I bet youll see they lift for a split second and right back-on. But there cars look so smooth on the track.
Old 10-27-2004, 01:21 PM   #9364
onefstsnake's Avatar
ok I got a question. I just got some parts from a guy for free for my TC3 and it came with 200mm blue axles and these strang looking front arms.
The arms are thick plastic type. Look machined and look wider than stock.
Anyone know of an aftermarket plastic arm?
Im stumped.
onefstsnake is offline   Reply With Quote
Old 10-27-2004, 03:40 PM   #9365
Could be the Rally conversion? That was 200mm heavy duty arms I think.
Andy M is offline   Reply With Quote
Old 10-27-2004, 05:03 PM   #9366
plastic looks alot different...
Old 10-27-2004, 08:52 PM   #9367
most likely its the rally convershion arms, the arms are a molded composite type of material thats why they look diffrent
kh15 is offline   Reply With Quote
Old 10-27-2004, 09:11 PM   #9368
Actually the guy I bought them from said they were some prototype arms that Barry Baker made.
Pretty cool. That would explain the rough machined look.
Old 10-27-2004, 09:16 PM   #9369
raffaelli's Avatar
Did you get that car from someone in New England?
raffaelli is offline   Reply With Quote
Old 10-27-2004, 09:46 PM   #9370
no but he used to race with a guy who knew Barry Baker and gave them to him.
Old 10-28-2004, 05:28 AM   #9371
raffaelli's Avatar
There are several cars running around New England with machined rear cars. They are not from the 200mm conversion. They help account for some strength and sloppy rear toe.
Old 10-28-2004, 05:31 AM   #9372
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I have a fully uprgraded TC3 in the sales forum if anyone is interested.
Thanks,
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 11-11-2004, 09:05 PM   #9373
SA_Racer's Avatar
Default loose diff/tight diff
I just switched to a front one way and was wondering what would be the best for the rear diff,
should it be loose or tight?
any other tips also welcome
SA_Racer is offline   Reply With Quote
Old 11-11-2004, 09:31 PM   #9374
does anyone run a one way on carpet? what advantages would it provide for a small tight carpet track?
runnin rc10 is offline   Reply With Quote
Old 11-11-2004, 11:09 PM   #9375
onnetz's Avatar
maybe a spool...... but I can't imagine a one way working very well on a small tight track.
onnetz is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
