Old 09-08-2004, 06:42 PM   #9316
raffaelli's Avatar
HPI has these foam strips for the front of the micro. I used those.
raffaelli is offline   Reply With Quote
Old 09-08-2004, 06:49 PM   #9317
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
The material I used was from BRP called Battery Nesting Tape. Their part number is 7546.
Kraig
KT Hobbies
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-08-2004, 07:45 PM   #9318
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
yeah i also use the brp nesting tape and have had good results, its cheap and works so you cant beat that
Javen13 is offline   Reply With Quote
Old 09-08-2004, 08:11 PM   #9319
A_Stratus's Avatar
I was thinking...what about a (2) 4-40 screw with a plastic nut at the end?
Team Express Motorsports
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
A_Stratus is offline   Reply With Quote
Old 09-09-2004, 12:51 AM   #9320
johnbull's Avatar
Originally posted by lazyeh
I just milled out my TC3 chassis and I was wondering what that black material is on the side to push the battery towards the drive shaft?
Aaron
Pick up an old rear arm support or two, and screw them to the side of the chassis. That's what I have done on at least half a dozen customer cars. They look very neat and hold the cells perfectly.
Have a look at the attached pic.
johnbull is offline   Reply With Quote
Old 09-12-2004, 08:10 PM   #9321
wow, this thread dropped down 3 pages back. Do we just let this thread die now that the TC4 is out.
Johnbull, thanks for the tip. Works like a charm
DRIVEN is offline   Reply With Quote
Old 09-13-2004, 12:19 AM   #9322
johnbull's Avatar
The tread may be dead but the TC3 certainly isn't.
We had 4 races this summer and son Josh won them all with his mod TC3, despite the fact that he refuses to come down and practice. The other guys may as well set up camp at the track, the amount of time they spend there testing and practicing.
I can't wait for the arrival of the TC4.
Old 09-15-2004, 01:03 PM   #9323
I got my IRS diff-outdrives and don't know which nut driver I need to assemble it. Will a associated driver be small enough to fit in the outdrive?
Thx!
greez, mc_rr
MC_RR is offline   Reply With Quote
Old 09-15-2004, 01:05 PM   #9324
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
most likly will not fit, you should use the HG Titanium diff nut it fits right in and does not require a nut driver, if you use a nut it will be very difficult to set your diff tension
you could also buy he kit to build a steel diff (just the hardware)
tc3stocker is offline   Reply With Quote
Old 09-17-2004, 04:23 PM   #9325
onnetz's Avatar
well its not available as of yet, so I say keep this thread alive...
onnetz is offline   Reply With Quote
Old 09-19-2004, 12:42 PM   #9326
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Hey anybody got some extra servo and/or motor mounting screws for the TC3 lying around? I am dying to get mine up and running since I have some connectors on their way in the mail.
Oh and anybody got a good stock touring setup?
trackdesigner71 is offline   Reply With Quote
Old 10-01-2004, 06:47 PM   #9327
j240z's Avatar
Default Rear shock tower up front?
OK, a local racer gave me some advice about running the rear shock tower up front. We were in between heats so I didn't get to chat long enough to find out why..?
What are the advantages of doing this? What else will I need to do after installing the rear shock tower in front? Should I run lighter/stiffer springs? Different oil? Will this affect ride height? What holes should be used for shocks/ camber links?
I tried reading through this thread and I'm sure the answer is in here somewhere. Could someone help me with this or point me in the right direction.
Thanks.
j240z is offline   Reply With Quote
Old 10-01-2004, 07:12 PM   #9328
i dont know why its better but i know it is, i run a rear up front also and i think it just gives the shocks a better stance, i use the same oil and spring is i did with the front tower the only thing thats diffrent is the possition of the actuall shock
kh15 is offline   Reply With Quote
Old 10-10-2004, 06:56 PM   #9329
raffaelli's Avatar
I was running 36/98 today with 59.5mm tires. I was looking to move to a larger pinion for some testing, say all the way to 40. I was having a very hard time with gear mesh with anything past 36. FT motors mounts. Should I be able to get a 40 with a 98?
Old 10-11-2004, 06:41 PM   #9330
Can anyone help me with a question on rear hubs. I was told a while ago to put losi 1 deg rear hubs on my TC3. what is the advantage. Right now I run a R2+2 rear mount,and do they go on r on right or do I need to put the L on the right to take toe out of the car. Its been a while since I wanted to make the change now I want to try it.
Troubled is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
