Like Tree65Likes
TC3 Forum
Old 09-05-2004, 08:22 AM
  #9301
woo woo , all blue parts , quit Good looking......only......
Shalala is offline
Old 09-06-2004, 08:13 AM
  #9302
DaveW's Avatar
How did everyones racing go this weekend?
- DaveW
DaveW is offline
Old 09-06-2004, 08:58 AM
  #9303
lem2's Avatar
Default Re: Tamiya SHocks
Originally posted by Blakesrc
Hey Guys,
Anybody using the tamiya shocks on their tc3? I just picked up a used tc3 and it has tamiya shocks on it. I rebuilt them last night but noticed that the stock associated pistons wont fit in them. Should i just stick with the tamiya pistons or is there a better alternative?
Thanks,
Blake
Use the tamiya ones, but if you want the AE ones, you'd have to take out a sand paper and carefully sand wach one until it fits perfectly.
lem2 is offline
Old 09-06-2004, 09:44 PM
  #9304
donoman's Avatar
Anyone use a servo saver in conjunction with the crappy little TC3 servo saver? I have a KO Propo 2343... What do you guys recommend?
donoman is offline
Old 09-07-2004, 12:19 AM
  #9305
johnbull's Avatar
The blue TC3 looks nice but I bet it weighs a ton.
The NTC3 hubs and arms are interesting.
johnbull is offline
Old 09-07-2004, 12:59 AM
  #9306
donoman's Avatar
I am asking about a servo saver because I repeatedly strip my servo gears when I'm racing because... well... I suck!?
donoman is offline
Old 09-07-2004, 05:44 AM
  #9307
trackdesigner71's Avatar
Hey, I know that this question has been asked before but I need foam tire information. I am racing this thing on carpet and would appreciate any help you guys could provide. How good are Speedmind foam tires too?
trackdesigner71 is offline
Old 09-07-2004, 07:13 AM
  #9308
crACkeD ChaSsiS's Avatar
Default havent been here in a while!!
dang havent been here for a while.college really takin over r/c racing.
crACkeD ChaSsiS is offline
Old 09-07-2004, 01:25 PM
  #9309
tc3stocker's Avatar
for carpet you will run TRC 28mm front and 30mm rear with Plaids up front and Purples or double purples in the rear, you will need to true down the tires and you run double purples in the rear if you want a loose car...................there are many different tires combinations that you can use howecer these are the basic ones..................as to Speedmind tires, I would not suggest them, use either Mono tuning, TRC (trinity), Jaco, or any rims you want with TRC donuts
Hope this helps, I used to run the TC3
tc3stocker is offline
Old 09-07-2004, 03:01 PM
  #9310
i got my order from tower today!!!!!
got some new fresh kicks from orion, rear shock tower (snapped the first one), and i finally got the all important camber gauge, so anyway i set my front camber to -1 and i dident want even think to change the back because their just the stock settings but i checked them anyway and one is -4 and the other wheel is -5 thats so messed up lol what should it be like -3?
kh15 is offline
Old 09-07-2004, 04:13 PM
  #9311
donoman's Avatar
kh15 guys i know run 1.5 negative camb all around bye
donoman is offline
Old 09-07-2004, 07:08 PM
  #9312
Please conduct all selling in the For Sale forum.
Thanks,
Josh
rally is offline
Old 09-07-2004, 08:46 PM
  #9313
I used to set mine at 1.5 - 2 degrees but I get better tire wear when set to 1 degree all around.
DRIVEN is offline
Old 09-08-2004, 05:54 PM
  #9314
A_Stratus's Avatar
I just milled out my TC3 chassis and I was wondering what that black material is on the side to push the battery towards the drive shaft?
Aaron
A_Stratus is offline
Old 09-08-2004, 06:00 PM
  #9315
BBSpence's Avatar
Trader Rating: 64 (100%+)
Aaron
I used weather stripping from Home Depot.
BBSpence is offline
