Old 08-24-2004, 07:48 PM   #9226
lem2's Avatar
Originally posted by kh15
i may mill my battery closer to the center, because i have shop class at high school so i can cut it on a cnc machine for extra credit, but does anyone have a site with a review of this mod
http://www.mistercrash.ca/_themes/page_mod_tc3.htm
lem2 is offline   Reply With Quote
Old 08-24-2004, 07:56 PM   #9227
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
how much has this mod to the TC3 chassis taken off your laptimes?
dontfeelcold is offline   Reply With Quote
Old 08-24-2004, 08:07 PM   #9228
j240z's Avatar
Great link! Thanks
j240z is offline   Reply With Quote
Old 08-24-2004, 08:19 PM   #9229
lem2's Avatar
a lot!!! about +1lap or 2 Then moved on to a warp chassis. Did better, but my TC3 is on Vacation now, just usingthe CGM as my main car.
Old 08-25-2004, 05:43 AM   #9230
Vue Vang's Avatar
LOOKS LIKE A LOT OF WORK BUT LOOKS VERY NICE. NICE JOB ON THE MOD AND THANKS FOR THE INFO. IS THAT SETUP FOR FOAM CARPET?
Vue Vang is offline   Reply With Quote
Old 08-25-2004, 05:21 PM   #9231
j240z's Avatar
Anyone know the part number and good source for the Yokomo one-way for the TC3? Is it that much better than the Ae one?
Old 08-25-2004, 08:43 PM   #9232
does anyone try to replace the Pro4 arms to TC3??
Loman is offline   Reply With Quote
Old 08-25-2004, 09:08 PM   #9233
i dident even know the pro4 arms can fit on the tc3, what are the bennifits of that mod?
kh15 is offline   Reply With Quote
Old 08-25-2004, 10:21 PM   #9234
stronger and cheaper
Old 08-25-2004, 10:59 PM   #9235
are the allen wrenches that come with the tc3 american or metric?
Old 08-26-2004, 01:50 AM   #9236
tornado
Guest
Posts: n/a
What else do you need for this modification? C hubs etc...
Bryan
Old 08-26-2004, 01:51 AM   #9237
tornado
Guest
Posts: n/a
Americano babe.
Bryan
Old 08-26-2004, 11:55 AM   #9238
thanks!
i'm really leaning twoards doing the ntc3 steerng mod for my tc3 because in the last 2 days i have crashed pretty hard 3 times because small rocks keep getting stuck in that stupid steering system, in my oppinion AE should have went back to the drawing board on that one!
Old 08-26-2004, 12:13 PM   #9239
AE has a simpler fix on their website, a lexan cover. Check it out.
JWATT is offline   Reply With Quote
Old 08-26-2004, 12:28 PM   #9240
calstarjig90j's Avatar
Default Re: TC3 Q's:
As an alternative to buying more hubs you can get the losi set screw that they use for their similar hinge pin setup. It is much larger and it will work perfectly while creating new grooves that won't strip as easily. Saves you money too. Another alternative is to buy the losi hubs. You can buy the graphite parts with different caster angles and still be cheaper than buying regular associated plastic 2 or 4 degree hubs. It's the 2 or 4 degree kit for the xxx-s. Comes with set screws also.
Originally posted by j240z
I've been battling this problem with my TC3 for a while now. Hopefully someone knows of a fix for this. The problem is mainly in the rear but sometimes in the front too.
The problem is with the parts that has the grub screw the is supposed to hold the out hinge pin in place. No matter how much I try to tighten the grub screw, the hinge pin still works it's way loose and will eventualy rub on the inner part of the wheel, leaving marks on the wheel itself. After a while the hole for the grub screw becomes stripped from me trying to tighten it too much and I have to change out the molded piece....Is this only happening to me..?
Also, is there an upper bumper plate for the TC3 like the one for the NTC3? I know BMI makes one but I don't think it will match the FT graphite very well...?
calstarjig90j is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
