Old 07-31-2004, 10:09 PM   #9076
Default RE: Tires for TC3
Thanks for the link, but unfortunately, it does not help me. I must admit that I am a rookie, which is the reason for enlisting this groups much appreciated assistance. Honestly, I have never heard of the tires listed. Do you know which Pro-Line tires I can use for this purpose, and can I re-use the same wheels. If I can re-use the same wheels, how do I remove the old tires?
Thanks in advance!
Tibbar110 is offline   Reply With Quote
Old 07-31-2004, 10:20 PM   #9077
onnetz's Avatar
Default re: tires
hey tibbar110,
I run my tc3 in parking lots and on the street as well...
and I have tried quite a few different tires..most last about 5 runs..
the best I have found for grip and life are cs27 takeoffs..
I bought several pair used and have put about 10 runs on the first pair and they are still looking good...
I just did a quick google search ..
http://www.balakracing.com/takeofftires.htm
like I said. if your just running them in the street, the best way to go is buy some used ones.... you can usually get a good deal.
onnetz is offline   Reply With Quote
Old 08-03-2004, 06:12 AM   #9078
DaveW's Avatar
TTT How dare we let this thread drop!
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 08-03-2004, 07:03 AM   #9079
Arun's Avatar
- DaveW
Norrca nats in two weeks, Dave .
http://nexusracing.com
Arun is offline   Reply With Quote
Old 08-03-2004, 11:12 AM   #9080
Default Why AE stopped to sell 4mm one way?
I like 4mm one way very much , super smooth , can use diff. gear and lighter than 6mm one way with one way cup.
Shalala is offline   Reply With Quote
Old 08-03-2004, 03:51 PM   #9081
Wency_TA03R-PRO's Avatar
Exclamation
- DaveW
let's keep this thread active for more other newbie racers can have all the info they need for their TC3 either team kit or FT TC3...
Wency_TA03R-PRO is offline   Reply With Quote
Old 08-03-2004, 08:04 PM   #9082
Nitro TC3 one-way:
Can it be fitted into the EP TC3??
Many Thanks!
MARKANO is offline   Reply With Quote
Old 08-03-2004, 08:42 PM   #9083
MARKANO:
Yes , but the one way cup is difference. Go to AE site to D/L the manuel then you will know.
Old 08-03-2004, 09:14 PM   #9084
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default graphite upgrade + r NOt
hey guyz not really new to r/c but. will it make a big difference if i dont upgrade my tc3 to the graphite? as far as handeling/weight issues?if so r not plz xplain y would it benefit me r y it wouldnt be a big of a deal to upgrade.im currently usin the mike blackstocks 2004 snowbirds setup off the associated website an the car is practically dialed to my standards.i run expert stock sedan. the car is really free an clean.
Steven
crACkeD ChaSsiS is offline   Reply With Quote
Old 08-04-2004, 12:11 AM   #9085
crACkeD ChaSsiS:
I m using IRS kit. The weight compare with modified originial chassic is almost the same +/- 10g
For the handeling , graphite chassic can have more traction , more easy to set up car and more easy to drive too.
It is good for low to mid-high traction.
On the other hand , the graphite chassic always contain "Tweak" problem after a crash. Also , i feel the irs kit is too soft for High traction track in MODIFY class. (may be the limitations is lower than original tc3 chassic....)
My opinion is stay with the original chassic , try to setup the surpensions to fit with it that you can learn more about it.
easy to dirve / high limitations....m.....hard to choose
Old 08-04-2004, 12:47 AM   #9086
donoman's Avatar
Send a message via Yahoo to donoman
Hey guys, I just raced tonight.
Somehow the ball cup ripped off the tie-rod for the rear camber adjustment. Totally weird. I don't even know what I did to cause that. <sigh>
I hate not finishing my races. I've only finished 1 of 3 so far
donoman is offline   Reply With Quote
Old 08-04-2004, 04:39 AM   #9087
losixxx's Avatar
Send a message via AIM to losixxx
i had the same probleam until i switched to rpm ball cups
losixxx is offline   Reply With Quote
Old 08-04-2004, 05:01 AM   #9088
DaveW's Avatar
PROFICAR403: Arun... no Nats for me... too much on my plate for now. How ya been? I havent seen you on here in a bit, is your phone # the same as before? Lata...
DONOMAN: RPM cups are a good answer for your problem as LOSIXXX said, but they can give you problems with rubbing the inside of some rims. Schumacher makes the best cups to date, super strong, super long, no rim rubbing, and super tight with NO binding. They are just a little hard to find.
CRACKEDCHASSIS: The easiest answer is, goto an all graphite setup on your car when you finish races with all of your laps within tenths of each other. If you already do then, you are set! With consistency in lap times, and a stiffer/lighter car, speed is the natural by-product. The down side is, ease to break, and some people dont like the response a stiffer car gives you. As always, comes down to driver preference.
- DaveW
Old 08-04-2004, 07:21 AM   #9089
Default another question plz
ty guys very much i really needed that help/been going back an 4th to upgrade but dont upgrade.well do u think i could run snowbirds with a composite tc3????i dont think so
????an i barely get ny practice in nowadays/ maybe thats y im thinkin about upgrading. but when i do go to the track my lines and laptimes are always consistent.
Old 08-04-2004, 08:52 AM   #9090
lem2's Avatar
Default Re: another question plz
Hi! Before you try and change your chassis, may i suggest you place an upper deck by Warpspeed? Its cheaper than a new graphite chassis, and later when you do get the graphite chassis, after doingthe battery mod--you may also want the upper deck to avoid the flex.
Your lap times are consistent because you are a good driver and exhausted almost every possible set up with your TC3, now by making the car more stiff with an upper deck maybe you'll be faster?? I dunno only one way to find out!
Peace and Happy Racing! - Lem
lem2 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
