Old 07-30-2004, 03:33 PM   #9061
Wency_TA03R-PRO's Avatar
Exclamation
Originally posted by The Black Kat
All I know is I've been with more TC3's than I have been women....
that's the spirit of loving your hobby aside to anything else?!..
Wency_TA03R-PRO is offline   Reply With Quote
Old 07-30-2004, 04:20 PM   #9062
Bah, Theres like no female population where I live.
The Black Kat is offline   Reply With Quote
Old 07-30-2004, 04:25 PM   #9063
Dave:
It wasn't duct tape, it was that good quality battery strapping tape..... You know the kind. Actually, I need some of that. Not joking, I really do!! Who makes that stuff? I've been meaning to order it at the shop. If you remember which distributor carried it, that would also be a help.
Bodido is offline   Reply With Quote
Old 07-30-2004, 07:40 PM   #9064
kh15:
i dont have tweak station too.
I just need to use camber ruler , downstop and ride height ruler to setup my car.
If u want to setup well your car , the frist thing is to read more setup instructions, e.g. X-ray , or other sites info. about setup car.
Shalala is offline   Reply With Quote
Old 07-30-2004, 07:58 PM   #9065
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default Rear Toe-In
Hi all, I fixed the steering rack problem. The rack had four high spots caiusing binding points.
Does anyone have an idea as to why my rear Left toe-in is 4 degrees and the right is 2 degrees using the R and R+3+2 blocks?
rinkrat99 is offline   Reply With Quote
Old 07-30-2004, 08:59 PM   #9066
first make sure the block is centred/aligned properly on the chassis.
second replace the block
third some of the early batches of hubs had dodgy molding, causing unequal rear toe. try replacing the rear hubs
hope that helps
Rory is offline   Reply With Quote
Old 07-30-2004, 09:31 PM   #9067
rinkrat99's Avatar
I just swapped out the hinge pins, and blocks and the same result. Maybe it is the rear hubs. I was thinking hingepins myself. But nope they were ok and even after replacing the toe is still wrong.
Old 07-30-2004, 09:51 PM   #9068
rinkrat99:
How you check the teo-in? With wheels?
May be the wheels is bended a little bit.
also , all car (included tc3 ) will get lossen after the parts used a period of time. Check the gaps bewteen all parts.
If too big gaps , use one 0.1 , 0.2 or 0.3 mm spacer to make it fit.(becareful to keep them smooth!)
* Look after your baby (tc3) , if not , she will cry.
Old 07-30-2004, 10:53 PM   #9069
rinkrat99's Avatar
Rear toe-in was checked with the Integy setup gauges. There really is no slop in the rear end of the car so I do not believe that is the problem. Its probably due to the rear hubs being slightly off. Technically, the blocks should space the arms to the 3 degree toein but if the hubs are off in the wrong direction, the toe will either be increased like the left or decreased like the right.
Old 07-31-2004, 05:18 AM   #9070
DaveW's Avatar
It sure is good to see we can laugh between the important stuff on here. I get tired of toe this, and, arm that, balls here, and, ball there. Inuendo is the greatest thing on earth... LOL.
Chad, that strapping tape came from a distributor named Competition R/C. I dont know if they are still a distributor or not. I have had that roll since i worked at Tidewater R/C. I did however see someone else packaging the same roll of tape at the Birds. It was in Superior Hobbies HS. I cant remember who was on the header card, but you might can get more info from Superior Hobbies. They have a webby too, but last i looked it was still under construction. Ill check into it a bit more and see what i can dig up.
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 07-31-2004, 05:26 AM   #9071
DaveW's Avatar
Just for informative purposes, Intertape is the company name printed on the inside of the roll. They have a website of the same name, but the pics/labelling are not very helpful. They also have a listing of distributors.
- DaveW
Old 07-31-2004, 07:58 AM   #9072
Dingus's Avatar
Tphalen addressed this about 100 pages back.
The rear toe being off is most likely due to the way you are installing the rear block. If you put one pin in first, then work the other pin into the second hole, you will oval out the first hole in the block.
The rear block needs to be installed squarely, both holes at the same time and then slid into place. If you are struggling at all, it will be off because the plastic is rather soft. The run of bad hubs was years and years ago and is not the likely culprit.
Dingus is offline   Reply With Quote
Old 07-31-2004, 11:36 AM   #9073
Default somethings about parts broken
It 's very interesting that if i install F+2 arm mount , it is easy to break. If install F+0 arm mount , A-arm is easy to break.
ALso , install R3+0 , it easy break too. But R2-0 or R2+2 are not easy to break.
Old 07-31-2004, 04:56 PM   #9074
Default Tires for TC3
You all seem to know quite a bit about these cars. I am not a racer. I merely run my car on the street. In fact, I am still using the original tires and rims that came with the Racer model car. My question is in two parts. The first question for you is if you know the best tiire to use for the longest life on the street and the second is if the original wheels can be reused. Any information will be greatly appreciated.
Thanks,
Tibbar110 is offline   Reply With Quote
Old 07-31-2004, 06:14 PM   #9075
Exclamation
With regards to tires check on this link..
Sorex 28R on low-grip asphalt
Hope the link help you decide w/c ire is the best....
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
