Old 07-28-2004, 08:03 AM   #9031
lem2's Avatar
Default IRS-TC3
Any word on their new Aftermarket chassis?
Heard that there was one on the works?
Just asking / interested on howit will look like.
R10 sa a conversion kit forthe IRS, but hoing directly willbe cheaper! But before you set your eyes on the IRS, look also for the BMI/Penguin ans WarpSpeed!!!
Mine resembles the IRS because the side braces protect the electronic really well...
lem2 is offline   Reply With Quote
Old 07-28-2004, 08:09 AM   #9032
lem2's Avatar
Default Re: IRS-TC3
R10 sa a conversion kit forthe IRS, but hoing directly willbe cheaper! But before you set your eyes on the IRS, look also for the BMI/Penguin and WarpSpeed!!!
another view..... Sorry I just love my TC3
Old 07-28-2004, 01:27 PM   #9033
yes i agree i will wait it get used to the car, but one more question and then i'll shut up!, how many runs should i go through before i clean the motor?
and how do i clean the motor because i cant remove the endbell right?
and should i just leave the batterys in my car with my car on to discharge them?
alittle more than one question lol but its all good
kh15 is offline   Reply With Quote
Old 07-28-2004, 01:37 PM   #9034
Charlie O's Avatar
Originally posted by kh15
yeaaaaaaaaaaaaaaaaaaa i got enough money to finally get my rtr tc3 i cant wait, but i was wondering whats the best hop-up for this car besides a motor for under 40$?
Metal gear servo & an RPM front bumper.
Charlie O is offline   Reply With Quote
Old 07-28-2004, 02:37 PM   #9035
donoman's Avatar
Send a message via Yahoo to donoman
Anyone here run dual sway bars on the TC3?
donoman is offline   Reply With Quote
Old 07-29-2004, 11:26 AM   #9036
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default Damn TC3 steering setup!
Hi all,
I reinstalled new ballcups last night, reset the turnbuckle links to manual settings, then checked toe/camber etc.. with my Integy setup and had to reset the steering to zero subtrim.
I generally set steering by cebntering the rack by the saver screw then adjust l/r turnbuckles. Thsi should get me subtrim of 0 or close to it. I started the race at subtrim +2R but after 2 laps the car pulled buig time left to maybe another corerection of +5R.
What can I do to recenter/adjust better
rinkrat99 is offline   Reply With Quote
Old 07-29-2004, 11:42 AM   #9037
Rinkrat99:
Try to check :
Servo mount (tighten) , servo saver (lossen), servo hon (cracked or the patten inside ),front arm pins (bended)and streeing block (cracked), streeing rod(bended)...............
Shalala is offline   Reply With Quote
Old 07-29-2004, 12:49 PM   #9038
rinkrat99's Avatar
Shalala
The ballcups were new RPM shorties. The turnbuckle was slightly bent but I am not sure why this would effect the steering after the initial setup.
Servo mount (tighten) - GOOD
Servo saver (lossen) - Need to check but I think it is tight
servo hon (cracked or the patten inside ) - Need to check
front arm pins (bended) - New hinge pins
streeing block (cracked) - NEW
Old 07-29-2004, 09:16 PM   #9039
i installed a second rear shock tower in the front of my car to better the stance but whats the best positioning for the shocks (what holes)?
Old 07-30-2004, 01:04 AM   #9040
rinkrat99
too many reasons......hard to tell all
May be some parts were cracked or lossen. (C-hubs......)
Or the streeing block is free?
Old 07-30-2004, 01:12 AM   #9041
kh15:
My feel is the big tower give some stable feel (may feel push).
For mod. motor 8,9 turns , it may good.
But for stock motor , it may understree.
Anyway , you can try the middle / inner hole on the tower.
p.s. the small tower give me some aggressive streeing feeling.
If still feel push when using inner hole , you may try the inner hole of the A-arms with inner hole of the tower.
Old 07-30-2004, 02:42 AM   #9042
okay thanks, also i read that the rtr tc3 has a problem with the car pushing to one side or the other when accelerating because the car is not balanced, i have no scales or anything so has anyone elese had this problem if so how did you fix it and if i have it how can i?
Old 07-30-2004, 03:29 AM   #9043
tornado
Guest
Posts: n/a
Default Re: Re: IRS-TC3
Hey ! The battery is on the other side of the car....hmmmmmm similar to the cudas.....any difference in the handling ?
Bryan
Old 07-30-2004, 03:30 AM   #9044
kh15:
You are newbies? :>
Fristly , if you got everythings well , i believe it can race too. The problem will not so serious that cannot be drive.
*TC3 is more streeing on the left. And becos of the 3300 battery heavier then 3000 battery and the electronic become small , so the problem enlarged.
You can do :
Make sure your car setting is correct , same camber teo-in/out.........on the L / R side.
Check the tyre wearless on left or right (it will affected with left and right streeing more or less)
Also the damper , i re-build damper every track day or 3 -4 days run time.
um..... you can mod. your chassic like http://www.mistercrash.ca/_themes/pa...ciated_tc3.htm
or add some weight on the motor side (may be more easy for you)
There are many things you need to experience. It is a long way to become a RC Pro racer. Now , just treat your car well like your girl friends. Then you will know more of her and she will help you.
Old 07-30-2004, 06:46 AM   #9045
DaveW's Avatar
Shalala: Now , just treat your car well like your girl friends. Then you will know more of her and she will help you.
Come to think of it, my TC3 makes me smile more than any woman i have been with. Guess im shoppin in the wrong place for a woman?
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
