Old 07-24-2004, 11:04 PM   #9016
DaveW's Avatar
SCWERTA: You might have the screw clamp hexes. It sounds like to me the problem isnt the hex, but its the size of the hole the rims have. Some rims have a smaller hole than the TC3 axle size, so you are tugging on it for sure the problem is the hex, and the whole time its the damn rim. Try wobbling it back and forth, seeing if you can twist it off. You can try taking the arms off of the car one by one, letting you hold the arm and tire in your hand, minus the rest of the car. Try holding the rim with one half of it on the edge of a workbench, the other half in your hand, and hitting the axle with a hammer to tap the axle through the rim. Of course, the nut would be off of the axle during this procedure. If you hit it just right, the axle will fall to the floor with the rim in your hand. There should be no damage to the axle or the rim, but maybe to your hand, if you arent careful. From then on, if this is the case, i would make sure your rims have appropriate sized holes for the axles. Usually japanese spec rims (metric) have 4mm holes, these are too small for the TC3. Hope this helps.
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 07-25-2004, 12:20 PM   #9017
johnbull's Avatar
Yes. I bet that's all it is.
johnbull is offline   Reply With Quote
Old 07-25-2004, 03:12 PM   #9018
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Jeff, why do you want to switch from the CGM to the TC3?
My Yok has been shelved for a while because of issues I was having running the SSG chassis on carpet... I can tell you this though, when it hooked up it was faster than the TC3...
Although I haven't gotten to run the CGM yet just from looking the Yok and AE are so similiar... I'm about to convert my SSG over the CGM and I'll decide later on which becomes my main and backup cars...
vtl1180ny is offline   Reply With Quote
Old 07-25-2004, 07:15 PM   #9019
tornado
Guest
Posts: n/a
I ran both of them.....equally good.....you need to trim the rotating mass CGM (lightened center shaft, lightened output shafts, CVDs and the wheel axles ) though to match the acceleration of the TC3.
Bryan
Old 07-26-2004, 04:30 AM   #9020
Wency_TA03R-PRO's Avatar
Exclamation
Not bad for your back-up cars bro!!!..
Wency_TA03R-PRO is offline   Reply With Quote
Old 07-26-2004, 10:43 PM   #9021
Hey,
Whats the size of the stock FT sway bars?
Thank you -Dan
The Black Kat is offline   Reply With Quote
Old 07-26-2004, 10:46 PM   #9022
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 07-27-2004, 01:01 AM   #9023
Default My IRS TC3
Here is my IRS TC3.
The most advantages of this chassic kit is adjustable the hardness of the chassic by installing "Side-bar" and "Middle-bar".
There are few combinations for your choice especially on a low traction track.
I m from Hong Kong , nice to meet you guys.
Shalala is offline   Reply With Quote
Old 07-27-2004, 02:49 AM   #9024
tornado
Guest
Posts: n/a
Default Re: My IRS TC3
Originally posted by Shalala
Here is my IRS TC3.
Any hkg webby selling the IRS chassis ? Trying to get one from asia. I'm from Malaysia.
Bryan
Old 07-27-2004, 07:50 AM   #9025
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
Default Re: Re: My IRS TC3
Bryan
Why not get it straight from Dave Irrgang's website? The place to go is http://www.teamirsrc.com
Flash Gordan is offline   Reply With Quote
Old 07-27-2004, 08:48 PM   #9026
Default Tires for asphalt
I was just wondering what the best (longest-lasting) tires are for concrete running. I am not a racer, yet I do have that kit.
Anyway, which tire/wheel should I have for the most usage for the least amount of money?
Thanks,
Tibbar110 is offline   Reply With Quote
Old 07-27-2004, 09:47 PM   #9027
tornado
Guest
Posts: n/a
Default Re: Re: Re: My IRS TC3
Thanks ! I've found them cheaper here : http://www.sslorder.com/speedtechrc/70.html
Bryan
Old 07-27-2004, 11:54 PM   #9028
yeaaaaaaaaaaaaaaaaaaa i got enough money to finally get my rtr tc3 i cant wait, but i was wondering whats the best hop-up for this car besides a motor for under 40$?
kh15 is offline   Reply With Quote
Old 07-28-2004, 12:06 AM   #9029
Exclamation
All I can say is enjoy the out of the box kit from now. After a while you really handle the car better then that's the proper time for you to hop-up the car... just my $.02 opinion...
Old 07-28-2004, 12:56 AM   #9030
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
i agree, learn to work with the car, change setups and get it dialed in. when your car is totally dialed and cant go any faster, then is the time to upgrade. also, remember, hopups are things to improve your car, not the look
R3VoLuTiOn is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
