Old 07-16-2004, 05:02 AM   #8926
OleC's Avatar
Post Setup question
You can use either rollbars or a higher roll center to decrease roll (obviously...), but when are one preferred before the other??
(I'm sorry for double posting, but I wanted to ask the Xray guys on their opinion also so I posted my question on their thread as well.)
JQ The Car Black Edition - O.S. - BUKU - AKA - Byron - Sanwa - Sav÷x
No sponsors. I drive what I like, and so should you
OleC is offline   Reply With Quote
Old 07-16-2004, 05:08 AM   #8927
Wency_TA03R-PRO's Avatar
Exclamation Re: tc3
Originally posted by crACkeD ChaSsiS
hey guyz my tc3 has been sittin up for a mnth now. im wondering if i go to race my car would i have to resetup my car>??!? friends telin me ill have to? so ny answers would really help.
Have tried running it??.. It your are not satified on the running performance of your TC3 then its about time to check your gearing,shocks,camber alignment, and motor etc.....
Wency_TA03R-PRO is offline   Reply With Quote
Old 07-16-2004, 05:13 AM   #8928
Default Re: Setup question
i suppose using a rollbar has greater effect on handling
billtc3 is offline   Reply With Quote
Old 07-16-2004, 05:19 AM   #8929
rice's Avatar
Default Re: tc3
maybe its time to try another kit. in order to experience the trill of asmbling and set up. or stick with ur tc3 and re set up it again.
rice is offline   Reply With Quote
Old 07-16-2004, 05:19 AM   #8930
OleC's Avatar
Default Re: Re: Setup question
Would that be the only difference?
I do agree that roll bars have a greater effect but I dont know of any other differences they create in handling.
Old 07-16-2004, 07:21 AM   #8931
DaveW's Avatar
Johnbull: God i wish i was at the NATS. I only have one week of vacation from work a year, so i use it to goto the Snowbirds. If i cant make the race in a normal weekend trip, then i cant go. Workin for a livin sucks. Im going to check on those dogbones, im hoping they are cheaper than the Niftech stuff.
OLEC: Both swaybars and roll center adjustments are a big change. Im assume by saying "higher roll center" you mean changing ballstud location on either shock tower. Ballstud changes are dramatic. Swaybars are not as dramatic, unless you are using a blade type, have your swaybar adjusted really tight (short lever point), or its a very thick one. The faster/easier the car transfers weight laterally on or off throttle through a corner (soft overall setup, hard driving, certain track layouts) the more noticeable a swaybar becomes. The ballstud change is felt all the time. It can alter the feel of overall stability, traction, and cornering speed. I pretty much run swaybars everywhere, except rough parkinglot tracks. Swaybars can be deceiving though, giving you the feel that the car is dialed, when it may be pushing horribly. Tire wear is an indicator here. If you shave 2mm off of your front foams in one run with little wear to the rears, you have adjusted your swaybars to overcompensate for another setting that needs to be changed. Caster angle is a popular one in this case. There is alot of speed to be found in making the car turn without "binding up" in the corners. Swaybars must work along with everything else (other settings)on the chassis... not just the reason it seems to be 'dialed'.
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 07-16-2004, 08:47 AM   #8932
DR RushQuake PH's Avatar
Send a message via AIM to DR RushQuake PH
backyard bashing a tc-3?
Used to be I bashed my T-maxx (Then It got racified, then I bashed my rush (Racified) Then my b4 and down on the line... My newest car is generally a basher for a while, or until we get an onroad track out here.
Yes, I have quite a few buddies who just ordered TC3's as well. Our plan for this winter when its cold is , every sunday, to et up cone tracks in the huge high school gym and have weekend races....
DR RushQuake PH is offline   Reply With Quote
Old 07-16-2004, 02:02 PM   #8933
J-P
J-P's Avatar
hey john bull,
i got the yok shock caps like you said, can you tell me how you fit them up and bleed them,
many thanks
J-P
J-P is offline   Reply With Quote
Old 07-16-2004, 02:15 PM   #8934
johnbull's Avatar
Originally posted by J-P
hey john bull,
many thanks
J-P
Just bleed them like you do normal shocks. They are actually easier to bleed.
If you leave them with the sponges you will get some rebound with them. If you want them to be linear on bump and rebound you can remove the sponges. I prefer them that way.
Good luck.
johnbull is offline   Reply With Quote
Old 07-16-2004, 02:20 PM   #8935
J-P
J-P's Avatar
many thanks joe,
i will run them next sunday and let you know how i get on,
J-P
Old 07-16-2004, 02:33 PM   #8936
Does anyone have the TC3 Rally conversion?
Old 07-16-2004, 03:05 PM   #8937
hey john bull,
many thanks
J-P
If you use the yok caps, you should remove the Associated sponges. Using the sponges with the Yok bladders makes your shocks feel real squishy.
DOTMAN is offline   Reply With Quote
Old 07-17-2004, 11:28 PM   #8938
Regional Moderator
nitrous36's Avatar
Do you guys run with the stick packs or the cells? Which do you prefer?
nitrous36 is offline   Reply With Quote
Old 07-18-2004, 05:27 AM   #8939
losixxx's Avatar
Send a message via AIM to losixxx
cells They sit lower in the chassie and you have the option of milling the chassie to move them closer to the driveshaft!
losixxx is offline   Reply With Quote
Old 07-18-2004, 09:37 AM   #8940
J-P
J-P's Avatar
hey dotman
do you mean the ones under the piston??
J-P
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
