Old 01-30-2002, 10:46 PM   #871
rto997's Avatar
Wolf- your tire selection is quite nice!!! That is all I have been running now for about 9 months!!!
rto997 is offline   Reply With Quote
Old 01-30-2002, 11:07 PM   #872
Corse-R's Avatar
Originally posted by TPhalen
Pirating the TC3 Tuning Guide....
Rather than getting the one by 'easy' methods (pyracy), I've own my own one...
As a 'casual software developer' I'm very concerned with the pyracy
If you enjoy and/or take profit for someone software/whatever give to the creators the possibility of taking profit of their work.
Sorry for this off-topic but someone needed to say.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-30-2002, 11:42 PM   #873
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Corse-R: Are the Powers 3300's available where you are?
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 01-31-2002, 12:36 AM   #874
Corse-R's Avatar
By the moment no, but some very in on the cell business tell me that the 3300 is almost the same as the 3000 with a little improvement on the voltage side. I've asked to them when they're available, send me some packs to test versus GT3000-R.
By the moment, I still trust on my 'old' but very powerful Pasonic SMH.
At Europe, powers cell are like the ugly duck, with our limitation to 12 turns. We're engaged a bad craze search for the ultimate voltage cells and this is killing the touring class (very sad but true, maybe we have some ass*oles on our governing bodies, I'm so tired of saying, maybe some day I'll return to off-road class where aren't limits and youself put your limits). Here the king cells are Panas and RC3000HV.
On pan car class Powers are widely used, but that is another story...
Cheers,
Corse-R
Old 01-31-2002, 01:54 PM   #875
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
RTO > Thanks
wolfeman09 is offline   Reply With Quote
Old 01-31-2002, 03:41 PM   #876
Hey Kids,
How does the stock settings do on carpet. I know it might be a little on the loose (soft) side, but is it a good place to start with?
I have the FTTC3 kit.
OUTofCONTROL is offline   Reply With Quote
Old 01-31-2002, 03:44 PM   #877
If your running rubber tires on carpet it isnt bad, but foam tires on carpet you should start elsewhere. Associated has a foam tire on carpet setup that is a decent place to start.
patcollins is offline   Reply With Quote
Old 01-31-2002, 03:51 PM   #878
I would prefer to run rubber....Sorex 20's in the rear and 24's in the front.
Old 01-31-2002, 04:52 PM   #879
RacerTex's Avatar
OutofControl:
This is my setup for rubber tires on high bite ozite carpet:
Front: 2 deg kickup, 4 deg caster blocks, 1 deg camber, 0 toe in, 60W, 2 hole piston, middle hole shock mount, swaybar, purple spring, 6 droop, 5 mm ride height, Pit 24 with Yok med insert, upper and inside camber link
Rear: 2 deg toe blocks, 0 anti-squat, 1 deg camber, 50 W, 2 hole piston, middle hole shock mount, no swaybar, red spring, 4 droop, 5 ride height, Pit 24 with Yok med insert, upper and inside camber link
If the bite is high, this should give you an aggressive and fast car. One more thing, I run a one way on the shaft.
RacerTex is offline   Reply With Quote
Old 01-31-2002, 05:38 PM   #880
RacerTex: That sounds like what I was planning.
Does anyone know what front blocks come stock on the FTTC3?
Old 01-31-2002, 07:21 PM   #881
Stock blocks are the zero degree ones.
Old 01-31-2002, 08:13 PM   #882
Thank you...That's what I thought they were.
Old 02-01-2002, 12:11 AM   #883
Send a message via ICQ to Barney Rubble
Yeah thats all well and good but in case you hadn't noticed this isn't "software" its only information
PS: I bet none of you guys use "napster" or "win mx" or "morpheus" then do you????
Barney Rubble is offline   Reply With Quote
Old 02-01-2002, 01:42 AM   #884
Corse-R's Avatar
Sorry, but is a part from Associated, runs a item number and rather than being physical is a 'virtual part'. And is something that runs on a computer, then should be software (remember: all the software: Operating system, Apps, drivers, whatever you run in your computer is information, so.... what is software and what is information?).
If Associated would be distributed freely his TC3 tunning guide they solely posted on their website (like their manuals) and let free download to everyone who wanted/needed.
Cheers,
Corse-R
Old 02-01-2002, 02:14 AM   #885
johnbull's Avatar
Hi guys. Greetings from Malta.
CORSE R and others. interesting discussion on batteries.
I have sold and run Powers 3000 - blue cover, Panasonic 3000, Panasonic SMH 3000, Sanyo RC3000, and have now started receiving stocks of Sanyo 3000HV. All are matched by reputable firms - Trinity, Orion, Corally, SMC.
Whilst I agree that the Powers 3000 gives plenty of time, I find that that time just cannot be converted into speed, no matter what you do with gearing, or what turn motor you use. They would be fine for 8 minute racing, but we race for 5 minutes.
The old Panasonic was good when it was the first of the 3000s on the market. The Sanyo RC3000 gives as much time as the Panasonic, and more power, and the Panasonic SMH is a bomb. I haven't tried the Sanyo HV yet so cannot talk on that. Incidentally all the cells we use are the top of the range ones from the various manufacturers.
Yes we are presently running Panasonic SMH 3000, having found them best for both speed and duration so far.
What I have heard from many sources is that Panasonic cells don't last as well as Sanyo, in terms of number of cycles. certainly I find that whereas the old Nicad cells got better with use, these NiMH cells deteriorate with every cycle. Just take a note of the voltage increase with every charge. That should mean more resistance, which is bad news. Mind you, when racing, if you can do a season with a pack of cells, that's enough!
What are your findings?
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
