Old 06-27-2004, 01:33 PM   #8791
Charlie O's Avatar
Default Fan Cooling
Why not just use a traditional small ac fan or dc automotive cigarrett lighter adapter fan, then you can cool your motor, batts, and electronics, & maybe you to on a hot day.
Charlie O is offline   Reply With Quote
Old 06-27-2004, 04:02 PM   #8792
bubbles's Avatar
Originally posted by Smalls
Guys real quick questions.....
If I run a rear block... R 3+2
And run Losi rear carriers that are 1.5
Will I have 1.5 degree of rear Toe?
Thanks!
Chris
Somewhat of a late answer...
I do not know Losi rear hubs too well, and the few times that I did use them, I used 0degree hubs. I wanted to try different rear, outter camber link locations. I know of 0, .5, and 1degree rear hubs for the Losi, but this is the first I have heard of 1.5degree rear hubs. When you install these hubs, make sure they are "backwards"(Left one is on the Right side, and Right one is on the Left side, because you want to get rid of toe), and then you will have 1.5 degrees of rear toe.
Another thing to note...
When adjusting the toe with the suspension blocks, you are also altering the wheelbase. So by having these 1.5degree hubs, and the R-3+2 block on the rear, you will end up with a "shorter" wheelbase, and 1.5degrees of toe. There is another option to try, R-2+2 with Losi .5degree rear hubs(again installed "backwards"). This has a "longer" wheelbase, yet with the desired 1.5degrees of toe.
bubbles is offline   Reply With Quote
Old 06-27-2004, 07:30 PM   #8793
ae4ever's Avatar
Default colling fan
The fan is mounted on the car.
And to follow up the ae heat sink fan will work when connected directly to your battery, and it runs a lot faster.
ae4ever is offline   Reply With Quote
Old 06-27-2004, 07:48 PM   #8794
ae4ever's Avatar
Lightbulb cooling fan
For those same fans you can go to affilated electronics and buy them for $1.35 per fan or $13.50 per dozen.
Do you have a web address or some way I can get a hold of affilated electronics ?
Old 06-30-2004, 02:28 AM   #8795
whats up, i will be getting a tc3 once i get some more cash in my pocket but whats the best advice you can give to a newbie with this car being his first?
whats the best upgrade for this car?
thanks!
kh15 is offline   Reply With Quote
Old 06-30-2004, 06:57 AM   #8796
lem2's Avatar
thanks!
Congratulations in Advance!
Track time is the best advice! First off--get a RPM WIDE from bumper for the TC3, will save you a lot money later on.!
lem2 is offline   Reply With Quote
Old 06-30-2004, 02:32 PM   #8797
cool thanks but i read that the only thing wrong with a rtr car of this proformance is it dosent come with "duel steering" or something like that
Old 06-30-2004, 02:36 PM   #8798
with the rpm front bumper is this all i get?
http://www.rpmrcproducts.com/product...ires/80045.htm
or does it come with the foam to?
Old 06-30-2004, 02:58 PM   #8799
dcracer's Avatar
This is the bumper you will need. The foam bumper is part of the kit.
http://www.rpmrcproducts.com/product...ires/80292.htm
dcracer is offline   Reply With Quote
Old 06-30-2004, 05:33 PM   #8800
Ian_da_bomb's Avatar
Send a message via AIM to Ian_da_bomb Send a message via Yahoo to Ian_da_bomb
Default Re: MISSING THREAD
Originally posted by Wency_TA03R-PRO
Guys just want to ask where can I find the previous thread of mike you the guy who knows most on the TC3 stuff and settings??.. Tnx in advance ...
Whhaaaaa?
Ian_da_bomb is offline   Reply With Quote
Old 06-30-2004, 07:24 PM   #8801
Bubbles, thanks...
you use the outer holes with the losi hubs, right?
Smalls is offline   Reply With Quote
Old 07-01-2004, 01:43 AM   #8802
bubbles's Avatar
I used the outter holes, and one of the good things about those hubs, is that you can also adjust the height of the ballstud(vertical). Eye balling everything, the inner hole on the Losi hub is close to the outter hole on the Associated hub, but they have a slightly different height. I forget if you have to raise the ballstud, or lower it when using the Losi hubs, but they're not EXACT.
When driving the different hubs, I noticed that the Associated hubs make the car slightly more edgy than the Losi ones(when using the outter hole on both hubs), but the car would rotate better through the corner.
Old 07-01-2004, 07:47 AM   #8803
Send a message via AIM to TCRacerPro
Thumbs up
I have been racing my TC3 for more than 4 1/2 years. Heres my first one I still race, im keeping this one forever...!!!
TC3 #1 ...
Heres mine!
TCRacerPro is offline   Reply With Quote
Old 07-01-2004, 08:53 AM   #8804
SammyXp's Avatar
TC3 #1 ...
Heres mine!
She's a thing of beauty! It's nice to see an umolested copy of the first TC3. Keep it clean!
SammyXp is offline   Reply With Quote
Old 07-01-2004, 11:41 AM   #8805
Shumacher 99's Avatar
Default One way
I can't seem to find a one way for my elec. TC3 anyone know where I can get one. I already looked on the Team web site Couldn't find it??????????
Shumacher 99 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
