Old 05-28-2004, 03:59 AM   #8716
protc3's Avatar
the BMI kit does not use the corner braces.that is included in the top deck design.the price is 119.99 and 109.99 with everything you need.there is no catches.i do not offer shock towers at this time and if i did,50.00 sounds a little steep.however.the chassis does look very nice and i wish you alot of luck with it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-28-2004, 04:03 AM   #8717
protc3's Avatar
what you see is what you get
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-28-2004, 04:44 AM   #8718
Tech Legend
Cain's Avatar
Trader Rating: 230 (100%+)
The BMI chassis is great. The only issues I have had is that one of the preinstalled motor mount screws backed out as I don't think they were threadlocked from the factory ( I should have checked ) and if you use the stock battery holddown you need to put some foam on it to hold the packs in better. If I could pickup the right size ( they look to be pretty short in length ) I would pick one up immediately.
So just make sure that you threadlock the motor mount screws and use foam on the battery holdown or get a better holdown.
Old 05-28-2004, 06:44 AM   #8719
J_Longbrake's Avatar
Trader Rating: 20 (100%+)
Originally posted by Penguin r/c
Currently leading RC Nation Points
RC Nation Points? You are kidding right, lol.
J_Longbrake is offline   Reply With Quote
Old 05-28-2004, 06:58 AM   #8720
By the way, I have bought Penguin products in the past and would buy again in the future. Very good quality.
Old 05-28-2004, 07:02 AM   #8721
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Is that C main club race points??
pimpedaccord is offline   Reply With Quote
Old 05-28-2004, 07:38 AM   #8722
Tech Legend
Cain's Avatar
What are some of the common things I can do to get alittle more on power steering? I am currently running plaids & purples, before running tans and cyans, maybe going back to that combo will give me back some of that steerings since the cyans compound other than the outer edge is slightly softer?
Old 05-28-2004, 07:46 AM   #8723
Reduce rear droop. Stiffen the rear. Decrease F. Caster. These should help.
JWATT is offline   Reply With Quote
Old 05-28-2004, 10:30 AM   #8724
Trader Rating: 30 (100%+)
I have purchased Penguin products in the past and believe that they provide a well designed and tested product. Besides build quality, the R & D that goes into the performance aspect is really what you're paying for. The unfortunate part is that I believe the Penguin chassis could be a little too late as there were so many competitors that have already released a chassis set and the TC3 may soon be outdated.
Going back to the low-voltage fans, I went to my LHS, yesterday.
The Reedy part number for their small about 1" x 1" brushless fan is part#448. However, we couldn't find a price for it, yet. Perhaps something worth looking into.
wrxnfx is offline   Reply With Quote
Old 05-28-2004, 11:04 AM   #8725
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
That fan retails for $10.00.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-28-2004, 11:08 AM   #8726
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Kraig can you get these fans .... Might need a few
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 05-28-2004, 11:10 AM   #8727
Super Moderator
Kraig's Avatar
Yes I can, they should be withing a week.
Old 05-28-2004, 11:22 AM   #8728
Looks Like a Have one more order to place then... unless you need something else from my neck of the woods
-Dave
Old 05-28-2004, 01:33 PM   #8729
Default rear shock mounting.
has anyone seen the mod you can do to the rear shock tower to get more positive damping?
well what you do is get some 1.5 inches screw or nut and drill a hole in the body post where the screw entres the body post
you can move the shock into position and there you go a fourth mounting position.
rc_1uk is offline   Reply With Quote
Old 05-28-2004, 01:41 PM   #8730
DaveW's Avatar
RORY: Thanks for the idea! I think a local electronics shop might have something like that for me! Ill try it and let ya know if i glitch tomorrow at the track!
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
