Old 05-23-2004, 05:51 PM   #8671
trx1's Avatar
Send a message via Yahoo to trx1
what a awsome tip!! looks like ill have to do to mine sometime soon
trx1 is offline   Reply With Quote
Old 05-23-2004, 10:08 PM   #8672
Trader Rating: 37 (100%+)
that lexan "tip" is wrong....you can't just cut a flat piece of lexan over the rack. it will bind up the steering big time if you do it this way
go to AE's website and download the proper instructions on how to make one.
http://download.teamassociated.com/p...rack_cover.PDF
note: if you don't have a really thin piece of lexan it will still bind a little causing drag on the drivetrain.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 05-24-2004, 08:26 AM   #8673
Trader Rating: 56 (100%+)
Default Bulletproof TC3
I am trying to make the fornt end of my TC3 bullet proof. I'm not the greatest driver yet and want to reduce front end breakage. I just popped in a RPM big bumper and was looking at Megatec or GPM delrin front arms, and carriers.
Anyone have any experience with these?
dynamic_e is offline   Reply With Quote
Old 05-24-2004, 09:02 AM   #8674
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
I think that bumpers all you need really...
Nrctc3 is offline   Reply With Quote
Old 05-24-2004, 11:08 AM   #8675
Baluga's Avatar
Hi,
Can anybody please correct me if 2.5 is the internal gear ratio of TC3. Does Speedmind distribute titanium screw set for TC3? Thanks
Baluga is offline   Reply With Quote
Old 05-24-2004, 11:09 AM   #8676
Send a message via AIM to True R/C Racing
Originally posted by Baluga
Hi,
Can anybody please correct me if 2.5 is the internal gear ratio of TC3. Any idea if Speedmind distribute titanium screw set for TC3? Thanks
yep, Its 2.5 or 2.55 either one. NO I don't Know about the Screws. If your looking for Steels Screws(a bunch of them) I have for sale.
True R/C Racing is offline   Reply With Quote
Old 05-24-2004, 11:17 AM   #8677
Baluga's Avatar
Thanks for the info... I'm planning to replace all screws to ti screws.
Old 05-24-2004, 03:11 PM   #8678
nashrcracer's Avatar
R/C Tech Charter Subscriber
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 05-24-2004, 03:56 PM   #8679
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
The ratio is EXACTLY 2.5.
40/16=2.5
Bubblestc3 is offline   Reply With Quote
Old 05-25-2004, 11:56 AM   #8680
DaveW's Avatar
The infamous glitch continues!!! I took the inline schottky that novak supplies with the GT7, removed the heatshrink and wire. I then took a standard schottky diode and clipped the leads off of it. I then soldered the leads to the Novak schottky diode board (its marked + and - ) using care to NOT overheat the board. I then attach the "super" diode to any motor as i would any other diode. This neatened the wires in my TC3 and tremendously decreased the glitching, although i did get a few hits during race day with one particular motor, and no other. I also swapped the Ti driveshaft out of the car for a standard carbon. I am doing one thing at a time to see what the culprit is. On an interesting note, the diode board is printed on both sides, so if you wanted to attach the wires from your speedo to the opposite side of the diode board, instead of making it fit over the leads on the motor tabs, you can. I dont think the printed circuit can withstand repeated heat from an iron though. I just thought i would share my findings.
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 05-25-2004, 12:15 PM   #8681
Trader Rating: 30 (100%+)
Hi, I'm new on this forum, but I was wondering:
If any of you know why the TC3 one-way diff was discontinued?
Does anyone have any recommendations on a good TC3 rally setup?
Does anyone have any recommendations for the lower suspension pins? I have bent both the stock ones and the Lunsford titanium ones(much weaker than the stock ones and Lunsford does not warranty these).
wrxnfx is offline   Reply With Quote
Old 05-25-2004, 08:02 PM   #8682
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
I got a question:
I noticed that the bearing cap ( the little one that goes over the bearing near the spur gear ) seems to pinch the bearings, anyone else had this issue?
Old 05-25-2004, 08:14 PM   #8683
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
wrxnfx, the one-way was not really discontinued. It was actually replaced with this part number, 3978. As for the suspension pins, Associated released some polished Factory Team pins part number 1651 or you can try the ones from Bud's (BRP) part number 6210.
Cain, I noticed it with mine as well. The only thing I did was back the screws out a little bit and it resolved my problem.
Kraig
KT Hobbies
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-25-2004, 08:26 PM   #8684
wrxnfx
I posted back a page or two .. maybe three .. that I use 3/32 piano wire from a local craft store for mine ... it takes about an hour or two to cut it down to length .. but each tube cost me like a $1.50 I think ... for two three foot lengths ... makes lots of pins for not much money and time .. I cut mine up using a dremel tool and a dremel cut off wheel ... just a thought ...
as far as rally set up ... I have never run a TC3 as a rally car so this is all a guess .. but I would try something like this ... remove all the droop screws or internal shock limiters and then set teh car up like this
front ... silver or blue springs, 30 wt oil with #1 piston, lay the shocks all the way down, use the f-2 block up front, 0* caster hub, -1* camber ... set the ride height to give you just about 1 or 2 mm of down travel before the arm hits the chassis and run the sway bar to help level the chassis
rear ... green or silver springs, 25 wt or 30 wt oil with #1 piston, lay the shocks all the way down, use the r+2+2 block, -1* camber, run the chassis short and use the sway bar ... also set the ride height the same way as with the front ...
run the batteries forward in the chassis ... set the diffs a little on the loose side so that landing off of a jump they will slip a little if under power ... say between 1/2 and 3/4 of a turn out from bottom for the front and maybe 3/4 to 1 full turn out for the rear .. or where ever the diff doesnt slip when applying power from a standstill ... setting the diffs loose like that will save on broken drive line parts from landing jumps ( kinda like a slipper clutch) .. but recheck them after every run .. cause if they loosen anymore they will toast the diff in a hurry .. then just play with the shock package to get the car to not bottom out off of the biggest jump on the track but I wouldnt go much heavier than 40wt oil or a red spring .. but like I said .. this is only a guess I havent done rally before ..
DaveW
sorry to hear that the glitch is back .. did you try the static guard it might help some ... but if it comes and goes with certain motors it really sounds like a bad bearing in a motor or a brush thats bouncing .. or something along those lines ... hope the solution presents itself soon for you ...
have fun racing
E
roddude65 is offline   Reply With Quote
Old 05-25-2004, 11:42 PM   #8685
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Originally posted by Cain
I got a question:
Use the Tobee Craft one from SpeedTech RC. Its aluminum.
Also dont screw it down all the way, just like the tranny case
wolfeman09 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
