Old 05-20-2004, 08:12 AM   #8641
Crashmaster's Avatar
Hi guys,
I was wondering if you could tell me how to work out the ratio when people say they have like a 8.03 ratio??
Cheers
Crashmaster
Crashmaster is offline   Reply With Quote
Old 05-20-2004, 08:41 AM   #8642
lem2's Avatar
Originally posted by Crashmaster
Hi guys,
Cheers
Crashmaster
What pitch are they using?
here is the ratio for 72T 48pitch. that's the only ratio i use
72 SPUR GEAR
21= 8.60
22 = 8.20
23 = 7.82
24 = 7.50
25 = 7.20
26 = 6.92
27 = 6.66
28 = 6.43
29 = 6.21
lem2 is offline   Reply With Quote
Old 05-20-2004, 08:45 AM   #8643
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
hi lem! hehehe im still praying for the rain to stop so we can have the race of champions push through this weekend!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 05-20-2004, 10:39 AM   #8644
Could sb tell me the exact size of the one way bearings?!Thx a lot!
Greez,mc_rr
MC_RR is offline   Reply With Quote
Old 05-20-2004, 11:28 AM   #8645
Hi guys,
Cheers
Crashmaster
Take the spur, divide it by the pinion, and multiply that times the ratio of the transmission (2.5 in the TC3). So a 100 t spur with a 29t pinion would be: 100/29*2.5=8.62 ratio.
Hope this helps.
JWATT is offline   Reply With Quote
Old 05-20-2004, 11:29 AM   #8646
72 SPUR GEAR
21= 8.60
22 = 8.20
23 = 7.82
24 = 7.50
25 = 7.20
26 = 6.92
27 = 6.66
28 = 6.43
29 = 6.21
Thanks lem2. We're running 48dp I recon.
Cheers
Crashmaster
Old 05-20-2004, 03:41 PM   #8647
Wency_TA03R-PRO's Avatar
Exclamation
So do I.. so that I could watch the race of champions with out the weather disturbances... Hopefully I could come after office work..
Wency_TA03R-PRO is offline   Reply With Quote
Old 05-20-2004, 03:53 PM   #8648
I'm not sure if this has been asked before, but has anyone here had problems with the steering rack binding up on them? Recently I noticed that there when sliding the steering rack from side to side, there are 2 places where it binds up. I have cleaned the bearings and bought a new rack, but the problem is still there. I checked the bearings pretty quickly, and even took some calipers to them to check if they were out of round, however, they seem good.
Is this a common problem? Should I recheck my bearings or are the posts most likely the problem? If anyone else has had this problem, let me know.
Oh, and does anyone know where I can get replacement bearings for the TC3 steering rack cheap?
Griffin is offline   Reply With Quote
Old 05-20-2004, 04:40 PM   #8649
trx1's Avatar
Send a message via Yahoo to trx1
where can i find a good place for hop ups at id like to get a aluminum center shaft, and a set of arms, if possible
trx1 is offline   Reply With Quote
Old 05-20-2004, 06:06 PM   #8650
LancerEvoV's Avatar
try tower hobbies at www.towerhobbies.com they seem to have everything.
LancerEvoV is offline   Reply With Quote
Old 05-20-2004, 06:12 PM   #8651
griffin,
sometimes the rack will have high spots where the bearing gets pinched a little. take a sharpie or mark where its binding and lightly sand with fine grit sandpaper where its binding. dont go too far tho, a little will do the trick.
MarchTC3 is offline   Reply With Quote
Old 05-20-2004, 08:37 PM   #8652
Exclamation
Originally posted by MarchTC3
griffin,
I already encountered this problem on my FT TC3 recently. MarchTC3 suggestion is what I did and the problem on my steering was resolve..
Old 05-20-2004, 08:53 PM   #8653
Really? I'll give it a shot, but it seems strange that the problem just popped up out of nowhere, and it happens with the old AND new rack.
I'll give it a shot though.
Old 05-20-2004, 09:38 PM   #8654
Wicked's Avatar
Default Progress on my in$ane tc3 project
Well heres were i'm at. System is in and running. Little more complex then my ss5800 was but I am sure it will be well worth it. I hope to have this out tommorro if its not raining.
Baja 5B Flux, Baja 5T, HPI Savage Flux XL, Brushless Erevo, Summit, X Maxx, Arrma Big Rock, Tamiya Bruiser, & Hi lux, Slash, Skully,
Blade 200qx, Inductrix 200, Nano qx2 fpv, Cx, Proto X SLT
Wicked is offline   Reply With Quote
Old 05-20-2004, 09:42 PM   #8655
Send a message via AIM to micros_rock
Damn, that esc is huge! LOL
Sweet TC3 dude!
micros_rock is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
