Old 05-15-2004, 12:18 PM   #8581
Send a message via AIM to True R/C Racing
Originally posted by Nrctc3
As for the driveshafts. I hate the aluminum one, all I do is bend it. I put my cf one back in and havent had any problems.
stop crashing
True R/C Racing is offline   Reply With Quote
Old 05-15-2004, 03:00 PM   #8582
Xtant3150c's Avatar
Where can you get a carbon fiber shaft from?
Xtant3150c is offline   Reply With Quote
Old 05-15-2004, 03:06 PM   #8583
its the Composite one that comes with a TEam Kit type.
Old 05-15-2004, 04:01 PM   #8584
Xtant3150c's Avatar
Thanks Ariel!
Old 05-15-2004, 04:02 PM   #8585
Thanks Ariel!
No Problem
Old 05-15-2004, 05:08 PM   #8586
actually the team kit comes with the aluminium one nowadays i believe, so unless you have one lying around from an old kit they will be very hard to find, unless you feel like buying a racer or RTR kit just for the shaft
Rory is offline   Reply With Quote
Old 05-15-2004, 05:40 PM   #8587
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
I remember that the old FT kit came with the carbon fiber shaft.
Nrctc3 is offline   Reply With Quote
Old 05-15-2004, 05:40 PM   #8588
Sow&Steady's Avatar
Default Events Calendar
edit - Please keep advertizing of your site in the appropriate forum, thanks.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-15-2004, 11:55 PM   #8589
all kits used to come with the composite or CF shaft .. but since the introduction of the NTC3 they have switched over to the alum. models .... as a matter of fact .. if you can even find a CF one anymore ... they were more expensive than the alum. models once Assc. switched over ... I asked the local hobby guy here and he thinks that all of the kits have switched over now .. if not then the rtr is the last with the CF shaft .. just until Assc. runs out of em ... the last racer kit he got in had the alum. shaft in it ...
also .. nrctc3 .. what are you doing to bend the alum. shaft ... I am no never hit anything racer .. but even with a 7x1 in the car on carpet with foams messing around one day I have never bent or even tweaked an alum. shaft .... and that 7x1 was with a very nice 3300 pack ... a factory driver and I were messing around one day it was a fun afternoon .. messing around with factory clas motors and batteries ....
have fun racing
roddude65 is offline   Reply With Quote
Old 05-16-2004, 12:50 AM   #8590
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
The Racer Kit and the RTR both, are now including the blue aluminum driveshaft. You should be able to find the carbon shafts in old hobby shops, just ask for them. They might have them in back somewhere. They are sort of expencive, at $12, BUT they are about three grams lighter than the blue aluminum shaft.
The carbon shafts are not made anymore, and could become hard to find.
Bubblestc3 is offline   Reply With Quote
Old 05-16-2004, 07:15 AM   #8591
etzkev's Avatar
Send a message via AIM to etzkev
Haha, I feel special. I got one!
etzkev is offline   Reply With Quote
Old 05-16-2004, 07:19 AM   #8592
when i sold my parts i had 4 extras
Old 05-16-2004, 07:21 AM   #8593
etzkev's Avatar
Nice.
Old 05-16-2004, 04:34 PM   #8594
trx1's Avatar
Send a message via Yahoo to trx1
HELLO, my name is mike. im a newbie to tc's and this forum but not r/c i got a tc3 RTR for christmas, love it! i dont know why it happened, but i trashed the motor(19t) that came with it. not to worry with it, just slapped a spec motor in, and away we go!
trx1 is offline   Reply With Quote
Old 05-16-2004, 09:14 PM   #8595
DaveW's Avatar
RODDUDE: I had a great weekend on the asphalt! That previous setup i posted worked VERY well! (qualified 2nd in stock A, finished first, beating TQ time AND fast lap of the day) If anything, i pushed coming into corners. I tried firmer inserts, the preassembled CS-27 worked very well. Track temp hovered around 115*. I will be going to a one-way the next race. I was doing some thinking about foams on this setup, if the grip would be med/high as you mentioned before, adding a standard front swaybar, and .5* more negative camber F/R might do the trick.
My only gripe is a recurring glitch that seems speedo induced. Anyone else having GT7 issues?? Im about to set both of em on fire!
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
