Old 05-05-2004, 04:52 PM   #8521
Klr
JDXray,
Are you going to run foam or rubber tires? Goto AE's website and download Mike Blackstock's Snowbird setup for foam or Juho Levanen's Lrp setup for rubber. Both have worked pretty well for me.
Klr is offline   Reply With Quote
Old 05-05-2004, 05:23 PM   #8522
etzkev's Avatar
Send a message via AIM to etzkev
JDXray,
True R/C Racing...those springs for carpet??? That is wayy different than by me. We all have high grip carpet tracks, so everyone is running either yellow or white up front and purples in back! Depending on how much grip your track has, I would recommend to go harder than True R/C Racing's suggestions.
-etzkev
etzkev is offline   Reply With Quote
Old 05-05-2004, 06:06 PM   #8523
JDXray's Avatar
Send a message via AIM to JDXray
Right now i am running white in front and purple in back. Is that okay?
This is for carpet racing.
JDXray is offline   Reply With Quote
Old 05-05-2004, 06:11 PM   #8524
etzkev's Avatar
Yeah! Thats more like it! I don't know what Ariel was talking about! I'm just messing Ariel.
Old 05-05-2004, 06:12 PM   #8525
JDXray's Avatar
lol, Nice. I guess i will just leave it with white upfront and purple rear.
Any more suggestions?
Old 05-05-2004, 06:18 PM   #8526
etzkev's Avatar
Unless you are a great driver, and dont hit any boards, get the RPM front bumper.
Old 05-05-2004, 06:19 PM   #8527
Trader Rating: 37 (100%+)
as for springs when running foams...
most of these suggestion are really great....take into consideration that other parts of their set-ups can be different which would effect what spring they use.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 05-06-2004, 03:57 AM   #8528
JDXray's Avatar
to etzkev: i do already have the RPM bumper,
Old 05-06-2004, 03:59 AM   #8529
Send a message via AIM to True R/C Racing
I have no bumper just the foam, and I ran Copper rear, purple front 50 wt all around w/ 3# upfront. I was dialed, But if i hit upfront i would break since i had no protection
yes, On foam
True R/C Racing is offline   Reply With Quote
Old 05-06-2004, 09:39 AM   #8530
Wency_TA03R-PRO's Avatar
Exclamation
Wency_TA03R-PRO is offline   Reply With Quote
Old 05-06-2004, 04:31 PM   #8531
ok folks .. I need a hand ... I am done playing in the dirt in the summer time ... so I gotta set up my TC for outdoors ... I looked that the Associated site .. but didnt see anything that really jumped and said this is right ... the two tracks I will be running at one is 1/8 or 200mm gas size .. big open .. smooth asphalt med grip. the other is more 1/10th or tight 200 mm pebbly asphalt ... low to med grip... bot use sugar water to prep the tracks ... I will probibly be running 19 or mod at both ... any starting suggestions. the car is my back up carpet machine .. so I dont even have a baseline to test off of. thanks in advance folks
Eric
roddude65 is offline   Reply With Quote
Old 05-06-2004, 04:35 PM   #8532
JDXray's Avatar
you should try a one way in the front for the big track.
Old 05-06-2004, 05:06 PM   #8533
DaveW's Avatar
Rubber tire/ asphalt setup.
Front
Shocks: #3 piston - 40wt ASC oil - red spring - middle hole on standard front tower, inner hole on arm.
Chassis: F-0 pin brace - 2* caster block - 3 droop - 5mm height.
Camber: Inside upper hole on tower - -1.5 camber.
Bumpsteer: Make steering turnbuckle angle match the front suspension arm at rideheight. Should be .090 in washers if you use a Losi steering block and Losi Ti ballstuds.
Ackerman: Stock.
Toe: 1* out
Rear
Shocks: #2 piston - 40wt ASC oil - blue spring - middle hole on rear tower, outer hole on arm.
Chassis: F and 3+2 pin brace - Losi rear outer hubs - 2 droop - 5mm rideheight.
Camber: Inside upper hole on tower - outside hole on Losi rear hub - - 1.5 camber.
Tires: CS of whatever temperature range you are running, or works well at your track.
Battery: Forward
Make sure you tweak the car. If the car seems "lazy" in chicanes or switchback turns, raise the spring rate front and rear equally. If the spring rate increase is more than 15lbs, increase the oil weight as well. This setup will work well on a medium to smooth surface with sweeping turns, is neutral feeling, with plenty of rear bite for 19t. You may need to stiffen the rear spring for mod if you lose steering off the corner. For a "pebbly" surface (i am assuming you mean the asphalt is deteriorating, but not dusty or smooth) you can use this setup with a softer insert in whatever tire you use matching the temperature range of the track. There will be notable tire wear with the softer insert. Hope this helps.
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 05-06-2004, 05:28 PM   #8534
koabich's Avatar
Send a message via Yahoo to koabich
Hello,
I have hear a lot of talk about the larger RPM bumber for the TC3. I considered buying it becuase I always had a problem bending the front left hinge pin and chunking my front tires. I never bought it because of the extra weight and I didn't like the way it looked.
But I did buy the RD Logics front foam bumber, and it solved all my problems. I have been running it for the last 2 months and have not had one bent hinge pin, no chunked tires and no broken front end parts. This foam bumper is much bigger than stock and also made of a more dense material. Hands down better than the trinity and stock foam bumpers. The best part of the RD Logics bumper is that you can buy 2 for $5.00!
koabich is offline   Reply With Quote
Old 05-06-2004, 05:36 PM   #8535
that helps a whole bunch Dave W ... I'll have to look into getting some rubber tires then ... the one guy I talked with at the hobby shop said it was an open tire class for the big track so foams were ok .. but I'll try that out with some rubber tires .. and yes when I said pebbly I meant more worn out older asphalt the lighter grey stuff witht he bigger chunks in it... not the smoother deep black stuff that comes out like glass and grips closer to carpet in the middle of the summer. God I would love a track like that up here in Michigan ... so if anyone has any ideas for outdoor foams I could use those too thanks again
Eric
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
