Old 04-29-2004, 08:33 PM   #8476
Send a message via AIM to Just got one
Originally posted by TSR6
Hey guys, I saw a guy take a TC3 RTR straight from the box, onto the track. The only change he made was his Radio. It seamed to run fairly well considering it was a RTR.
Just got one is offline   Reply With Quote
Old 04-29-2004, 09:28 PM   #8477
Tech Legend
Cain's Avatar
Trader Rating: 220 (100%+)
saw that too. Its a good car, just alittle tweaking for more competitive racing and your all set.
I may just look into those diff cases as I think mine are stripped in places.
Old 04-30-2004, 01:15 AM   #8478
johnbull's Avatar
Default Re: Front Bumper brace
Originally posted by DRIVEN
Has anyone done any mods to add a top bumper brace. I find that my RPM bumper always tend to bend down every after race. Besides not hitting any thing, any suggestions on how to keep the bumper UP?
Just see what I've done.
It works fine.
johnbull is offline   Reply With Quote
Old 05-01-2004, 12:20 AM   #8479
Default Bumper brace
Try putting the shummmacker axsis 2 batterie straps on one underneath the foam and one on top they fit perfect over the body posts. It also lifts the foam off the bumper by a couple of mill so the foam takes the impact and not the plastic. Carbon ones look cool too.
Hope this helps.
simo is offline   Reply With Quote
Old 05-01-2004, 07:51 PM   #8480
I found this while looking over the web. Anyone tried this yet?
http://www.superdavegl.com/images/brace_a.jpg
DRIVEN is offline   Reply With Quote
Old 05-01-2004, 09:07 PM   #8481
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
I have seen it, but I have not ordered yet. Looks much better than the BMI ones I just purchased. If you can see it, the plastic goes down from the tranny case. That is trick. The BMI just go straight so you have to add some spacers or foam so it keeps the bumper down.
wolfeman09 is offline   Reply With Quote
Old 05-01-2004, 10:26 PM   #8482
I got a problem. I raced today and i couldnt figure out how to fix this problem. The car would push making a left turn but would have no rear traction when i turned right and the car would instantly slide out. Any ideas?? if u need any more info on setup just ask
MarchTC3 is offline   Reply With Quote
Old 05-01-2004, 11:09 PM   #8483
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
marchtc3, hinge pin or cvd, its one of the two
Kave is offline   Reply With Quote
Old 05-02-2004, 07:48 AM   #8484
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey MarchTC3
Just ad some preload to your left rear shock hope this helps
mike ivy is offline   Reply With Quote
Old 05-02-2004, 07:50 AM   #8485
mike ivy's Avatar
Hey MarchTC3
Just ad some preload to your Right rear shock hope this helps
Old 05-02-2004, 07:53 AM   #8486
mike ivy's Avatar
Sorry I hope I did'nt confuse you I double posted just ad preload to your right rear shock
Old 05-02-2004, 09:07 AM   #8487
Could use some advice. I'm a carpet guy. I do pretty well on it. But asphalt and rubber tires are a different story. So I'm hoping you guys can give me some pointers with my setup.
Here's the deal:
Track is smooth, recently paved, well groomed asphalt, large, sweeping fast turns, maybe 75 degrees outside, 110 track temp.
TC3 factory team, I'm using the Barry Baker setup from the Reedy Race in 2003. Without the spool or sway bars. I'm running Takeoff CS27 tires (practicing for some handout races, so I need to get it to work with these tires)
Did a few packs, car was pushing pretty bad. Both low and high speed.
I move the shocks out in the rear end to stiffen it up a bit. That helped it rotate better.
Did another pack, still not great.
I put a rear sway bar on. This helped it rotate pretty well, but it still had a high speed push.
I put a spool in it. LOTS of rotation, too much for me, but a bad low speed push (I need to learn to drive with a spool)
So, I want to get it setup w/o the spool, but need to keep it from pushing. Any pointers? Do you think this is a driving technique issue? Do you guys run drag brake?
Any and all pointers will be appreciated!
spyderx is offline   Reply With Quote
Old 05-02-2004, 01:02 PM   #8488
Tech Legend
Cain's Avatar
I am thinking of going with 64 pitch gears, what is a good spur gear size to go with ? Right now my stock 48 pitch gearing range is between 27 and 32 tooth pinions.
Old 05-02-2004, 01:33 PM   #8489
nashrcracer's Avatar
R/C Tech Charter Subscriber
75 = 100
72 = 96
67.5 = 90
27 = 36
28 = 37.3 associated reccomends for stock on a 72 = 96
32 = 42
most people run stock on a 96 I run a 90 64 pitch tooth on my tc3 and it
seems to get a good range from 27 to 35 for 19turn
90/27=3.33
72/27=2.66
90/35=2.57
72/32=2.25
90/40=2.25
but I have been known to run it with a 38 on a 19turn but it came off real real hot stock is not as bad at that gearing. If you talk to several people they'll probably tell you to go with a 100 for the rotating mass but I think that the difference isn't noticable enough for club racing. I also figure I can't get a big enough pinion on a 100 and run the smaller gear. don't run stock so I can't completely help on that but it depends on the roll out for what gears to use also unless your running rubber. I run foams at my local track.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 05-02-2004, 01:38 PM   #8490
etzkev's Avatar
Send a message via AIM to etzkev
Yeah, I run a 96T spur and never go over a 40T pinion in stock.
etzkev is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
