Old 04-28-2004, 10:14 AM   #8461
John_S's Avatar
i dont know about handling but the bmi chassis looks beter than the demon
John_S is offline   Reply With Quote
Old 04-28-2004, 08:40 PM   #8462
tirbolag's Avatar
Default RC Square Delfrin diff halves
any of you guys running the RC Square delrin BLACK diff havles...find that you have to shim the diff to reduce end play?
anyone using the white delrin diff halves?
tirbolag is offline   Reply With Quote
Old 04-29-2004, 05:25 AM   #8463
Fusedbrain's Avatar
ttt
Fusedbrain is offline   Reply With Quote
Old 04-29-2004, 07:32 AM   #8464
Tech Legend
Cain's Avatar
Trader Rating: 220 (100%+)
Ok, trying this again.
I am currently running a TC3 with the BMI chassis conversion. My car is handling quite well but I want quicker change of direction which I think adding a sway bar front and rear will give.
Anyone who has added a sway bar front and rear to there setup, how did it affect handling?
I tried one in just the rear and it actually had MORE rear traction as the rear didn't want to swing out in the turns, but it wasn't like a normal push.
Old 04-29-2004, 07:47 AM   #8465
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 3 (80%+)
Send a message via MSN to clinttredway
Have you tried just the front?
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 04-29-2004, 08:23 AM   #8466
Speedie's Avatar
Cain the reason it gave the rear more traction having the bar in the rear, is because the swaybar keeps the rear from transfering as much weight to the front during cornering by lessing the body roll.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 04-29-2004, 11:06 AM   #8467
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Default Re: RC Square Delfrin diff halves
I am using the Aquare Black Delrin Diff Halves. Yes that is the adavantage of the Black over the White.
The white ones are exactly the same as the AE ones as the Black ones need shimming. This frees up the drivetrain even more.
I beleive teh right way to do it is to have more shims on the left than the right. This pushes the gear to the right to free it up. Not to much or you will strip the gear, so shims on the right is needed as well.
So far so good. This outdrives are awesome!!! Then even include an extra hole so when the first pair wear down you can move it to the extra hole. Like two outdrives for the price of one. Defintley an imporvement over the AE ones.
You can get them at www.speedtechrc.com
Let me know if you have any other questions.
wolfeman09 is offline   Reply With Quote
Old 04-29-2004, 11:16 AM   #8468
Tech Legend
Cain's Avatar
i figured it was something like that, but my terminology is not that good. A usual grunt will do the job
May have to look into those diff halves...
What have you guys done on a stock TC3 to free up the drive train without installing new parts. I have heard of sanding, but I don't where to begin with that.
Old 04-29-2004, 01:37 PM   #8469
wolfeman09's Avatar
If you dont want to sand, then purchase a pair of warspeed trany cases. They have done all the sanding for you and have also coiled the screws so they dont strip.
Old 04-29-2004, 01:46 PM   #8470
Tech Legend
Cain's Avatar
Thanks,
Will the warpspeed cases make a good difference? I may also buy a set of new bearings as these are getting alittle worn.
Old 04-29-2004, 05:02 PM   #8471
In my opinion, Yes...very much. They really free up the stock drivetrain and the helicoils also add strength to the screw holes, which tend to strip over time from hard hits and also from continually loosening and tightening the screws in the diff case.
DOTMAN is offline   Reply With Quote
Old 04-29-2004, 06:39 PM   #8472
Default Front Bumper brace
Has anyone done any mods to add a top bumper brace. I find that my RPM bumper always tend to bend down every after race. Besides not hitting any thing, any suggestions on how to keep the bumper UP?
DRIVEN is offline   Reply With Quote
Old 04-29-2004, 06:46 PM   #8473
etzkev's Avatar
Send a message via AIM to etzkev
All you need to do is boil some water and then dip it in and bend it back. It works great. No brace needed!
etzkev is offline   Reply With Quote
Old 04-29-2004, 08:08 PM   #8474
Send a message via AIM to Just got one
this is old but ive heard this story on multiple occasions, so i got a tc3. lol
Just got one is offline   Reply With Quote
Old 04-29-2004, 08:32 PM   #8475
Ok well it didnt quote the other story ill try again
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
