Old 04-15-2004, 07:40 AM   #8401
etzkev's Avatar
Send a message via AIM to etzkev
Originally posted by micros_rock
RCBoyz.com sells the threaded shock kit for $39.99, which is the cheapest I've seen.
Really? I didn't know that! Thanks for posting. RCBoys does good business. I really like them.
etzkev is offline   Reply With Quote
Old 04-15-2004, 08:40 AM   #8402
Originally posted by johnbull
Hi friends.Greetings from Malta.
FANS
With the hot temperatures we race in in Malta a fan is a must.
Here's how I run it on my son's championship winning car.
Incidentally this car won all 3 finals at last weekend's Kelloggs Easter Cup, breaking lap and race records in the process.
To the fella that asked about keeping diffs in one piece: get a set of IRS alloy diff halves to replace the plastic ones. You'll never touch them again.
Regards
Joe from sunny Malta.
Johnbull...where did you get the motor clamp?
DOTMAN is offline   Reply With Quote
Old 04-15-2004, 08:58 AM   #8403
SammyXp's Avatar
Just finished reading all 280 pages of this thread. It was actually at 240 pages when I started reading! I just thought that was an accomplishment worth sharing, haha.
Quick question: (And I'm positive this hasn't been covered in this thread yet) Do the steel outdrives call for a longer diff screw than the plastic outdrives? I've seen a few conflicting part numbers.
The diff bolt that comes with the thrust washers (6573) is 3/4" long and the diff bolt that comes with the T-Nut thrust bolt (6575) is 1" long.
Also, I understand there are two different sizes of internal bearings and bushings that have been specified for the diff over the years, and one set has been obsoleted. Which is the most recent?
SammyXp is offline   Reply With Quote
Old 04-15-2004, 09:06 AM   #8404
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Those are good questions, i usually just buy the steel diff kit to make sure I have everything that is supposed to be correct. I am now running IRS alu diffs, and i like them alot. The screws and nuts need to match on the steel diffs, also maike sure u note that everything must be put together with the correct bearings. i think they are different sizes, but I am not sure as to what size they actually are.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 04-15-2004, 08:08 PM   #8405
Fusedbrain's Avatar
I just bought a TC3 and was wondering if you were to buy a new stock motor right now, what would you buy. I want to pick one up this weekend. I'm open to suggestions. I'd like to pay about 100$ canadian for one. That should get me a nice motor.
Eric.
Fusedbrain is offline   Reply With Quote
Old 04-15-2004, 08:11 PM   #8406
etzkev's Avatar
Oh god. $100 Canadian?! Thats crazy! Anyone charging $100 for a stock motor is trying to rip you off. Just go with the Trinity Monster Horsepower Stock Pro motor. It is the most popular stock motor for touring cars these days. It is really a great motor. You probably can find one for $50 canadian brand new.
-etzkev
Old 04-15-2004, 08:18 PM   #8407
Send a message via AIM to True R/C Racing
Dude ill get u 5 NIP Motors (monster stock) for 500$ shipped!
Nah just messing If you woulda told me before i was selling stock motors Very good cond for 10$ monsters 6$green machines W/ brand new 767's brushes....
You can find good deal on here.
True R/C Racing is offline   Reply With Quote
Old 04-15-2004, 08:29 PM   #8408
etzkev's Avatar
Ariel, do you wanna hook me up with any Monsters for a good price??? I do really need a new motor. Let me know man! Im gonna get on aim now.
Old 04-15-2004, 08:35 PM   #8409
Fusedbrain's Avatar
Default New Stock Motor
I'm simply looking for something of quality. Something fast and reliable. I've always had hand me downs for cheap here and there and I'm considering buying a new motor for a change. Looking for something good.
Eric.
Old 04-15-2004, 08:49 PM   #8410
etzkev's Avatar
My opinion stands! Go with the Monster!
Old 04-16-2004, 01:02 AM   #8411
johnbull's Avatar
Hi friends. Greetings from Malta.
JAVA & DOTMAN.
The motor clamp is part of a Fastrax optional item. A proper heatsink comes with it too.
I haven't used the heatsink because I let the fan do the work of cooling the motor and don't want to retain the heat on the heatsink. The fan should blow through and over the motor, and by my understanding that should be enough.
Put it this way, we run 8 turn motors in our hot climate. This car is always the quickest mod touring car and we always end up with plenty of power in the cells, even after 5 minutes of racing.
ROVIC.
The reason for the different mounting of the rear camber link is simply to ease removal of the rear diff cover. With this system all you need remove is the 6 screws retaining the cover, and 1 shock screw to lift the case off and get at the diff.
There is a spacer under the ball joint which can be varied to alter the rear roll centre but at present it's position is similar to the top inner hole on the tower.
What I have done is played with spacing under the suspension mounts so that both front and rear lower arms run parallel to the chassis - no kick up or antisquat in other words. It seems to work very well that way.
Regards
johnbull is offline   Reply With Quote
Old 04-16-2004, 04:06 AM   #8412
Yea dude Ill hook you up wit my Current Raceing Motor by XS. 15$-10$ But i gotta get my new motors in before i sell you it.
Old 04-16-2004, 09:09 AM   #8413
etzkev's Avatar
Alright, that sounds good. I'll talk to you on AIM sometime about it.
-Kevin
Old 04-16-2004, 03:30 PM   #8414
fatbear's Avatar
Send a message via Yahoo to fatbear
Default Has anyone tried a reciever battery in their TC3 for extra runtime.
Hi and greetings from beautiful New Zealand,
I have been running a reciever battery in my car (mod class at a high level) for a few meetings now but I am still undecided if it is helping with extra run time or not.
Has anyone tried this before?
Darren
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 04-16-2004, 05:02 PM   #8415
tc3rookie's Avatar
would there be any negative impacts by cutting the heat sink part off the motor clamp? (i still have the black steel one) i run stock on a tight track. any info would be appreciated. thanks.
tc3rookie is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
