Old 04-14-2004, 04:57 PM   #8386
R/C Paperboy:
1) yeah I think you can still get the steel outdrives, if not get yourself some IRS lite drives, or pretty much any other aftermarket one. You could also try Square's delrin ones for less rotating mass
2) never heard of anyone doing this... but there are some aluminium hubs out there if you want to try them... or a lot of people use losi rear hubs for extra tuning options, but I don't think they're any more durable
3) Yep, there's a new HD oneway out now. Less breakages due to 6mm oneway bearings. part no is 3978
Rory is offline   Reply With Quote
Old 04-14-2004, 05:45 PM   #8387
etzkev's Avatar
Send a message via AIM to etzkev
Originally posted by True R/C Racing
BLue Will Do, Anyone know the cheapest place other than
$49.99 Off ebay? I would buy em used if someone has
Edit** Kevin U got em? what you think?
Also how much would a Used perfect cond AE threaded shocks go for w/ a set of springs?
Ariel,
I have done some looking before, and the cheapest I found was Ebay.
I don't have them, but I wouldn't mind picking some up (wishing I had some ). I have heard nothing but GREAT things about them, so they should work out pretty good.
I'm not sure how much some used threaded shocks for the TC3 would be. I have just never looked into them.
-Kevin
etzkev is offline   Reply With Quote
Old 04-14-2004, 05:46 PM   #8388
etzkev's Avatar
Im SoOO stupid....
You JUST figured that out?!
Haha Just playin' man!
Old 04-14-2004, 07:06 PM   #8389
Xtant3150c's Avatar
Im SoOO stupid.... hahaha Now i see the Pm Button
Nah man I turned it on after you posted!
Xtant3150c is offline   Reply With Quote
Old 04-14-2004, 07:09 PM   #8390
Xtant3150c's Avatar
Default Re: chassis
Originally posted by tc3rookie
so you're saying that the plastic chassis and older graphite chassis don't have the things for the droop screws, and a new(er)
chassis would? sorry to be still asking about this, but i'm not sure whats up.
thanks in advance
Yeah I guess the tc3 I have is like 5-6 years old and the arms on it don't have the droop screws! And the chassis does'nt have the little ears on the chassis that make contact with the droop screws.
Old 04-14-2004, 07:37 PM   #8391
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
i have the older style chassis without the "ears" to support the droop screws. i have found that the newer style arms with droop screws will still work, it may not be as long lasting as with the "ears" but so far ive saved $40 on a new chassis.
R3VoLuTiOn is offline   Reply With Quote
Old 04-14-2004, 07:43 PM   #8392
Xtant3150c's Avatar
Thanks for the info R3VoLuTiOn!
But I might have found a new chassis already!
At least now I know I can get the arms!
Old 04-14-2004, 11:51 PM   #8393
Send a message via AIM to micros_rock
Originally posted by etzkev
Ariel,
-Kevin
RCBoyz.com sells the threaded shock kit for $39.99, which is the cheapest I've seen.
micros_rock is offline   Reply With Quote
Old 04-15-2004, 12:05 AM   #8394
Java1970's Avatar
Default Re: chassis
thanks in advance
I bought the FIRST generation Racer TC3 and there was nothing at all involving droop screws. Then, in Oct '03 I got the FT TC3 and that was when I found droop!! They also changed the Diffs, but had to find that out the hard way!!!
Java1970 is offline   Reply With Quote
Old 04-15-2004, 12:29 AM   #8395
johnbull's Avatar
Hi friends.Greetings from Malta.
FANS
With the hot temperatures we race in in Malta a fan is a must.
Here's how I run it on my son's championship winning car.
Incidentally this car won all 3 finals at last weekend's Kelloggs Easter Cup, breaking lap and race records in the process.
To the fella that asked about keeping diffs in one piece: get a set of IRS alloy diff halves to replace the plastic ones. You'll never touch them again.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 04-15-2004, 12:32 AM   #8396
Java1970's Avatar
FANS
Regards
Where did that motor clamp come from? It has to be aftermarket, theres no heatsink on it.
Old 04-15-2004, 12:49 AM   #8397
Speedie's Avatar
Originally posted by RC Paperboy
1) The diffs. I melted about 3 of those plastic lightweight diffs before I switched back to the steel outdrives. Does AE still make the steel outdrives? I sold them, now Im wishing I didnt
2) In high heat, with heavy collisions, I found myself twisting rear hub carriers. I know it sounds weird, but they would actually warp 2-3 degrees and bind up the bearings. It was really bizzare.
3) Is there a good oneway available? I seem to remember AE discontinuing the oneway I had and I had to junk it after breaking an outdrive.
The diffs they fixed with brass bushings inside instead of bearings. I have never melted mine even once when it came loose on me because I was trying to run it too loose.
The rear hub carriers still have the same problem. This is easily fixed by not hitting stuff. If thats not possible the Losi rear hubs are alot nicer. The graphite ones wont bend and the plastic ones will take alot of abuse before breaking. They also give you a little more wheelbase adjustment as they need another spacer in the rear.
The new associated heavy duty oneway is alot better. And the Yokomo one is even better than that.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 04-15-2004, 05:51 AM   #8398
Wow, thanks for all the replies. Sounds like the car just keeps on getting better and better.
RC Paperboy is offline   Reply With Quote
Old 04-15-2004, 06:04 AM   #8399
rovic's Avatar
johnbull,
what/how different/trying to achive - mounting the rear camberlinks like so?
(pretty clever)
thanks rovic...
rovic is offline   Reply With Quote
Old 04-15-2004, 07:14 AM   #8400
yodace's Avatar
R/C Tech Charter Subscriber
I've been away awhile, could anybody tell me about the updated diffs? Or any new parts for the TC3?
yodace is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
