Old 04-14-2004, 10:54 AM   #8356
The fan DEFINATELY makes a difference. Have tried it several times, temp w/o a fan over 200, temp with a fan under 150. Motor doesn't fade, brushes last longer. I mounted a fan on my nerf wings, aimed at the motor.
JWATT is offline   Reply With Quote
Old 04-14-2004, 10:57 AM   #8357
MClinton's Avatar
I've got some brackets that mount to the motor clamp....i can blow the fan air directly onto the arm, and yeah, it seems to help. I'll try to post some pics of the bracket.
Matt
MClinton is offline   Reply With Quote
Old 04-14-2004, 11:32 AM   #8358
Send a message via AIM to True R/C Racing
Does anyone know where I can find a chrome(titanium) color TRF Damper Shocks by tamiya?
True R/C Racing is offline   Reply With Quote
Old 04-14-2004, 11:36 AM   #8359
Java1970's Avatar
The heatsink/fan looks nice, but also looks like it would raise the center of gravity, IMHO.
Java1970 is offline   Reply With Quote
Old 04-14-2004, 11:36 AM   #8360
they seem to fall off too....AT my track some guy had one and it was falling out
Old 04-14-2004, 11:38 AM   #8361
etzkev's Avatar
Send a message via AIM to etzkev
Sorry man, they only have Red and Blue.
-etzkev
etzkev is offline   Reply With Quote
Old 04-14-2004, 11:49 AM   #8362
etzkev's Avatar
You might be able to use oven cleaner to take the anodizing off though for a silver finish...I don't know though.
Old 04-14-2004, 11:51 AM   #8363
BLue Will Do, Anyone know the cheapest place other than
$49.99 Off ebay? I would buy em used if someone has
Edit** Kevin U got em? what you think?
Also how much would a Used perfect cond AE threaded shocks go for w/ a set of springs?
Old 04-14-2004, 12:50 PM   #8364
PitCrew's Avatar
I did the fan trick just as Barry Baker did I believe. Mounted by the ESC blowing directly on the endbell. HUGE DIFFERENCE!!! Can't say that enough. Mods rarely reach 140. After 7minute 19t races, motor temps at 120. AWESOME!!
PitCrew is offline   Reply With Quote
Old 04-14-2004, 12:51 PM   #8365
I tryed doing that But I cant get the motor to Stay. Its like a 1/4inch wide So it barely Grips, All it wants to do is tip over....
Old 04-14-2004, 01:55 PM   #8366
what do you connect the Fan to?
GSR40 is offline   Reply With Quote
Old 04-14-2004, 02:00 PM   #8367
I connected it to the battery input at the esc, you also can plug it into ch3 of the receiver. You will get more rpm if it is conn to the batt.
Old 04-14-2004, 03:05 PM   #8368
Xtant3150c's Avatar
I recently got a tc3 team kit, and it has a graphite chassis and some other parts.
My question is that I want to get the version 2 arms for it with the droopscrews as the car I have does not have these arms?
I am wondering if they will work on my chassis? To me it does not look like the droop screws would touch the chassis?
Xtant3150c is offline   Reply With Quote
Old 04-14-2004, 03:07 PM   #8369
if its graphite it should. If you look at chassis on top where diff cases go is there a little piece Sticken out ? the reg plastic chassis does not have these though
Old 04-14-2004, 03:08 PM   #8370
diskostew's Avatar
Send a message via Yahoo to diskostew
the second gen chassis are differnt. they have little ears on the side where the droop screws will hit on the new arms You really should update. you will not be able to get the car to hook up right. Droop plays a big part...
hope this helps!
diskostew is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
