Old 04-09-2004, 04:26 PM   #8296
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Default Re: TC3 Motor Cam Loosening
Originally posted by rinkrat99
Hi all,
I had some problems last night running on carpet where my Cam would loosen and thus cause the gear mesh to be tight to the point the motor was smelling burnt.
I added a piece of double-sided tape under the cam and this worked but what about a longterm fix?
What does everyone else do?
Do you mean the motor clamp is not holding the cam tight enough, or do you mean that the screws that hold the cam to the motor come lose?
If the screws are coming lose, then try some different screws.
If the motor clamp is not holding the motor cam tight enough, you could file down the chassis to make the clamp, clamp tighter. My friend had somewhat of a similar problem, he filed the chassis down, and it solved his problem. Scott could be of more help in this area...
Bubblestc3 is offline   Reply With Quote
Old 04-09-2004, 04:32 PM   #8297
PitCrew's Avatar
I had aluminum rear arm mounts. I didn't like them. The toe in and anti squat were way different and the car handled like poopoo. They did have a cool feature. The hinge pins rode in delin balls that could be replaced. So, instead of the mounts breaking or getting bent, the balls would break or pop out and could be replaced.
PitCrew is offline   Reply With Quote
Old 04-09-2004, 07:26 PM   #8298
lem2's Avatar
Originally posted by Dougnuts55
Does anyone make aluminum rear arm mounts.
Doug
I use the Ones From SQUARE! If you do not like Aluminum and an Aftermarket kind'na guy, you can Get TobeeCraft DELRIN Rear Arm Mounts at SPEEDTECH. Just waiting for my SQUARE mounts to break before I replace them!
lem2 is offline   Reply With Quote
Old 04-09-2004, 08:12 PM   #8299
Originally posted by s2
ive heard the term 'spool diff' what is this? is it like a locked diff? what are its effects on the cars handling?
Stew
Yes, this is just a solid front axle/diff. The effects of the car's handling tend to make the car easier to drive, but you lose a considerable amount of steering. Although on-power you have the same amount of steering as you would have with a one-way. Off-power the car will not "rotate" as well as a car would with a one-way. The good part about having a Spool is that you will always have full braking abality's, and suposedly cleaner driving.
Old 04-09-2004, 08:24 PM   #8300
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Hey Bubbles
The cam is moving due to the motor clamp not holding it tight enough. I replaced the hex screw on the non-spring side and it helped but it seems the spacing between the chassis and the cam is a hair too large.
Why would filing the chassis help? Friction? Or do you mean file the area where the screws from the motor clamp come in contact with the chassis?
rinkrat99 is offline   Reply With Quote
Old 04-09-2004, 11:39 PM   #8301
The section of the carbon chassis, where it comes in contact with the motor clamp. This could be filed down in order to provide a tighter clamping effect. My friend Scott performed this and has had no problems since...
Old 04-10-2004, 07:29 AM   #8302
Crashmaster's Avatar
Is it true that some people put tooth paste on the ring and pinion gears on there car and run it for like 10 minutes to bed them in (I saw this on the team orion forum)???
Cheers
Crashmaster
Crashmaster is offline   Reply With Quote
Old 04-10-2004, 11:18 AM   #8303
Hi,
Sorry bout the double post, but I only just remembered this part...
I'm now running V2 front arms with the rear shock tower on the front, but when I put the shocks in the outer hole, the shocks catch the block carrier. How can I stop this front happening
I know this has already been on this thread before, and I have read it before, but quite frankly I can't be bothered to read through 277 pages to find it... just a lazy person
Cheers
Crashmaster
Old 04-10-2004, 11:19 AM   #8304
Java1970's Avatar
Cheers
Crashmaster
I'd like to know the answer to that one!!!
Java1970 is offline   Reply With Quote
Old 04-10-2004, 11:23 AM   #8305
Tooth paste??
There's the link...
Crashmaster
Old 04-10-2004, 01:42 PM   #8306
etzkev's Avatar
Send a message via AIM to etzkev
Although I have never heard of putting the Toothpaste on your pinion and spur, I have heard of putting toothpaste on your bushings and running an arm in your motor to break in the brushes. I do that myself. Therefore, putting toothpaste on your spur makes sense to me.
-etzkev
etzkev is offline   Reply With Quote
Old 04-10-2004, 03:56 PM   #8307
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Default Hinge Pins..
Hey all, just wondering what company you are using for Hinge Pins on the TC3.
Also, do you polish them and with what kind of polish?
Thanks....
wolfeman09 is offline   Reply With Quote
Old 04-10-2004, 04:10 PM   #8308
berger's Avatar
R/C Tech Charter Subscriber
Im using the standard associated ones, i place mine in a drill spin them up and use about 1000 grade silicon carbide paper on them until they are nice and shiny.
berger is offline   Reply With Quote
Old 04-10-2004, 06:37 PM   #8309
Default Factory team pins
Blackstock says he runs the new Factory Team polished pins from A.E. They go for $10 but they are already polished and are made out of better material. Mike claims he has not bend one of these new pins. Look on the A.E web site for the part number, its under the TC3 Factory Team section. I just got mine this weekend they are nice but I have not run the car yet to see how they hold up. I'll let you know as soon as I can.
ccm399 is offline   Reply With Quote
Old 04-12-2004, 01:05 AM   #8310
Cheers
Crashmaster
Many people do this on Tamiya M-series cars to make the drivetrain VERY freeeeeee. It tends to make the car slightly louder than stock, but the gears are perfectly "grooved"(they mesh perfectly). From what I have heard, it is not 10minutes, more like 10hours. But then again, I could be wrong...
As for the shocks, friends have had the right "C" carrier catch the right front spring along with the spring "cup"(I forgot the exact name of this part. Hey, it's late here in California. hahaha). To solve this, they filed back the right "C"carrier for more shock room.
They were also using the 4degree carriers.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
