Old 04-06-2004, 03:11 AM   #8251
chef88's Avatar
Trader Rating: 48 (100%+)
Need some help... I ran 19t last week & fried my diffs.
They were the plastic outdrives. I got some IRS outdrives
but I'm having a hard time securing the diff's with the plastic
housing that surounds the nut. it seems to go to far for the ends to be secure. What do you use when running modifieds?
Thanks for any help. MJ
chef88 is offline   Reply With Quote
Old 04-06-2004, 11:20 AM   #8252
Java1970's Avatar
Be careful when replacing the diff outdrives with aftermarket ones. I discovered that Associated changed the design of the diffs between the first series and the latest. I too fried the plastic diif outdrives in my factory team kit and as a quick fix, tossed in the old ones from my original racer kit. When I got around to replacing them with Hardcore Racing outdrives, I couldn't get the diffs to work. I later discovered that one of the internal bearings (racer kit) had been replaced with a narrower bushing (FT kit) and made all the difference in the world. It kind of sounds like you may have the same problem, the aftermarket parts are a different generation than the the ones that fried. If that's not the issue, email IRS and ask them for advice, could be something simple. Hope this helps, good luck.
Java1970 is offline   Reply With Quote
Old 04-06-2004, 11:25 AM   #8253
The AE steel outdrives and the AE plastic outdrives do not use the same thickness for the internal bearings/bushings.
JWATT is offline   Reply With Quote
Old 04-06-2004, 11:31 AM   #8254
RandyB's Avatar
Does anybody on this thread remember a post someone put up a link to their web sight and was a how to on milling the cassis out to move the batteries more center line it also had the ntc3 steering rack conversion on it anybody remeber whos web sight that was??
thanks
RandyB
RandyB is offline   Reply With Quote
Old 04-06-2004, 11:34 AM   #8255
berger's Avatar
R/C Tech Charter Subscriber
Here.
berger is offline   Reply With Quote
Old 04-06-2004, 11:43 AM   #8256
RandyB's Avatar
Bling thanks man !!!!
Old 04-06-2004, 12:10 PM   #8257
chef88's Avatar
Thanks Java 1970 & JWatt.
Have one of you used the light weight outdrives part #3913?
& if so How did they work for you?
Old 04-06-2004, 12:56 PM   #8258
RandyB's Avatar
Did associated ever come out with a different input gear. like a white-ish colored one??
Old 04-06-2004, 01:13 PM   #8259
RandyB- The new style input gear is not gray, it is the yellow/white color now.
Chef88- The plastic outdrives work fine, just don't last too long.
Old 04-06-2004, 01:41 PM   #8260
Java1970's Avatar
I ran the stock plastic hubs that came with the factory team kit and they melted!! (Wish I had a picture, it was cool, sort of) I replaced them with Hardcore Racing outdrives to help out the shop owner who is a friend of mine, he wanted honest, working feedback on them. I would recommend using the Associated aluminum replacements since they are at the exact same specs as the kit requires. (Since they are the ones who designed the kit in the first place) Hardcore work just fine, but it's almost always to get it from the original source. As for a concern about less weight, it should at a tic more speed since it is less roatating mass.
Old 04-06-2004, 08:49 PM   #8261
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
Hitec HS-5625MG $55
Speed: 0.14 sec/60 degrees at 6.0V
Torque: 130.53 oz/in at 6.0V
Futaba S3050 Servo Digital Standard High Torque BB MG $50
Speed: 0.16 sec/60 degrees at 6V
Torque: 90.2oz/in (kg/cm) at 6V
the hitec is pretty tempting...
the analog ones are cheaper.
Futaba S3305 Standard High-Torque Servo w/Metal Gears $35
0.20 sec/60 degrees at 6V
124 oz/in (8.9 kg/cm) at 6V
Hitec HS-625MG Servo Speed Metal Gear S/JR/Z $37
0.15sec/60 degrees at 6.0V
6.8kg-cm (94.43 oz/in) at 6.0V
what do you guys think? im trying to keep costs down to as low as possible without sacrificing potential. if its really worth it should i just go for the $90+ servos?
R3VoLuTiOn is online now   Reply With Quote
Old 04-06-2004, 09:39 PM   #8262
Send a message via AIM to micros_rock
I have a digital KO servo, and believe me, a digital servo makes a noticable difference/improvement over analog servos. Not only are they extremely quick and strong, but you should never have to worry about the servo not centering or wandering. That HS-5625MG does look pretty good, not too expensive
micros_rock is offline   Reply With Quote
Old 04-06-2004, 10:17 PM   #8263
MClinton's Avatar
I second the idea that digital servos far surpass the analog. The digital is worth the extra money, for sure!
Matt
MClinton is offline   Reply With Quote
Old 04-06-2004, 11:31 PM   #8264
Java1970's Avatar
Default Analog vs Digital
Analog servo= AMC Pacer on valum
Digital servo= Ford GT on rocket fuel
'Nuff said!!!
Old 04-07-2004, 11:30 AM   #8265
RandyB's Avatar
are the new input gear and diff gears a running change in the new kits and how can you tell if you are buying a new kit?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
