Old 04-02-2004, 08:50 AM   #8191
rayhuang's Avatar
dizzy-yup!!! e-mail Jason at: probrein@cs.com or all him (better) at 352-544-0463
Old 04-02-2004, 08:51 AM   #8192
Originally posted by mikejr718
I just purchased an integy sutup station and in attempting to setup my tc3 found that the rear toe is always almost 2 degrees more on the left than on the right. I tried changing the rear arm mounts( r,r+3+2) and found it had no effect. I was wondering if this is designed into the car or if I have further problems.
I had a similar that came up after I destroyed the R block in a wreck and replaced it with a spare I had in my parts box. After that, I had more rear toe on the left than the right. I bought a new R block and the problem went away
DOTMAN is offline   Reply With Quote
Old 04-02-2004, 09:46 PM   #8193
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Anyone have a place to get a full kit for Ceramic Bearings for the TC3?
Thanks...
wolfeman09 is offline   Reply With Quote
Old 04-02-2004, 10:12 PM   #8194
Speedie's Avatar
dizzy-yup ask for the BMI bumper brace made with 3mm carbon fiber. You'll thank yourself.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 04-02-2004, 10:56 PM   #8195
Default ? JohnBull.
Is that a pic of the new TC3 chassis you posted? I also saw what appeared to be a new motor mount cam? If not who makes it. I like the motor mount.
Nightbreed is offline   Reply With Quote
Old 04-02-2004, 11:25 PM   #8196
Java1970's Avatar
Default Speaking of TC3 chassis
If it's the Hardcore Racing chassis for the electric TC3, DON'T BUY IT!!! I picked one up and it claimed to be able to easily replace the stock chassis. Bull****!!! The four chassis bracers did not match up properly and, as a result, there was such a binding that I lost speed even going from a stock to a modified motor. When I asked the company about it, they suggested using THEIR bracers (more money) irregardless of the claims of easy replacement. Look at the team guys who are racing at the top level, all their cars are box-stock, or very close to it. Spend the money elsewhere, batteries, ESC, tires, ANYTHING but the Hardcore Racing chassis!!
(*pant* pant* pant*)
My ranting is done, time for my meds again.
Java1970 is offline   Reply With Quote
Old 04-03-2004, 03:23 AM   #8197
J-P
J-P's Avatar
hey wolfeman09,
try www.acerracing.com i just checked it out and also ordered some, expensive but from what ive heard and read they will be worth it!!!!
hope this helps
J-P
J-P is offline   Reply With Quote
Old 04-03-2004, 09:33 AM   #8198
Regional Moderator
Send a message via AIM to Mike F
Default Drfting question
I search this site for the answer but I couldn't find it. I know it was posted once befoer but I can't recall by who.
My question is this.
Down the str8t, the car will drift to the side and once I recenter it, it drifts again.
Here's my set up and equipment
Front
Rear shock tower up front, middle hole on shock tower, lower outter hole on A arm, 40 weight, silver srings. Camber link upper inner hole. 1.5 degree of camber. Locked diff
no toe in
Rear
Middle hole on shock tower, lower outter hole on A arm, 40 weight, blue spring. Camber link upper inner hole. 1.5 degree of camber. Short wheel base.
2 degree toe in
Tires- take off's 27
Servo - Hitec digital
Esc gt7
monster stock motor
I've used the RPM ball cups throughout the car with the exception of the lower steering links, they have the original ass. ball cups.
any assistance would be greatly appreciated. I'm leaning towards the lower ball cups on the steering links or more camber up front
Mike F is offline   Reply With Quote
Old 04-03-2004, 09:47 AM   #8199
etzkev's Avatar
Send a message via AIM to etzkev
One word - TWEAK!
Have that checked and set, and your problem will be fixed!
etzkev is offline   Reply With Quote
Old 04-03-2004, 09:48 AM   #8200
Regional Moderator
I thought that too but the chassis isnt tweaked
Old 04-03-2004, 09:50 AM   #8201
etzkev's Avatar
How do you know? Have you recently put it on a tweak board?
Old 04-03-2004, 09:50 AM   #8202
Send a message via AIM to True R/C Racing
check droop, And Shocks. Make sure they are Working propertly. I once had that, My left shock on rear the Eclip inside the shock to hold the piston fell out. Hope this helps
True R/C Racing is offline   Reply With Quote
Old 04-03-2004, 09:53 AM   #8203
koabich's Avatar
Send a message via Yahoo to koabich
Default Re: Drfting question
Front
no toe in
Rear
2 degree toe in
Esc gt7
monster stock motor
Make sure the screw for the servo saver on the bottom of the steering rack hasn't come loose.
koabich is offline   Reply With Quote
Old 04-03-2004, 09:53 AM   #8204
Regional Moderator
I'll check that out, thanks
Old 04-03-2004, 10:23 AM   #8205
I've had this problem before, traced it down to a non full self centering servo (centered OK from right, but not from left)
TraceRacing is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
