Old 03-26-2004, 09:01 AM   #8161
JoshR 85's Avatar
HeY!!!
I'm sure they will be testing it out again this weekend at ROAR nats if they do have a new chassis design, etc.
JoshR 85 is offline   Reply With Quote
Old 03-26-2004, 06:16 PM   #8162
Default One-way maintenance
How do you maintain your one-way diff? Does it require re-greasing all the time?
DRIVEN is offline   Reply With Quote
Old 03-27-2004, 01:26 AM   #8163
Default YES...I hope so...
I just wish they would say, "AE is currently testing new updated parts for the TC3."
Nightbreed is offline   Reply With Quote
Old 03-27-2004, 01:29 AM   #8164
carkillaii's Avatar
that would be nice to hear
carkillaii is offline   Reply With Quote
Old 03-27-2004, 10:43 AM   #8165
Send a message via AIM to R/C Anonymous
Driven when i used to have a TC3 back in the days of 99-2001 i only greased it the first time i put it in my car and never did after that....i never had problems with it either but im sure it wold be better to grease it more often then i did . . . maybe every couple weeks ?
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 03-28-2004, 02:42 PM   #8166
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Default Re: One-way maintenance
I would think that best would be to re-grease the one-way at about the same time you rebuild your shocks, or when ever you feel as though the outdrives bind somewhat in the housing. The Heavy Duty one-way seems less susceptible to binding because of how thick the outdrive's are. The older one-way may need a little bit more attention to keep "one-waying".
Bubblestc3 is offline   Reply With Quote
Old 03-28-2004, 08:40 PM   #8167
Can I use motor cleaner to remove old grease out?
Old 03-29-2004, 10:14 AM   #8168
lem2's Avatar
use wd-40 first then the motor cleaner, so you won't use much of the mtr cleaner!
lem2 is offline   Reply With Quote
Old 03-29-2004, 10:47 AM   #8169
tc3rookie's Avatar
Default chassis balancing
i'm trying to balance my chassis, and its too heavy on the battery side (and about 1/2 pound heavier than ROAR minimum weight), and i've already dremeled the chassis to move the batteries in, and am using the graphite battery bar. any suggestions on hoy to lighten the battery side and balance the car?
tc3rookie is offline   Reply With Quote
Old 03-29-2004, 11:37 AM   #8170
PitCrew's Avatar
Remove the spur gear and dremel some of the stiffening material away from under the spur gear. Use a slighty larger spur gear ( I run a 75 tooth 48p gear instead of 72) This way to get the same gear ratio, you will use a larger pinion as well, therefore moving the motor just a bit more away from centerline, counterbalancing the battery. Thay way you are not adding weight, just re-balancing the weight that you HAVE to have in there.
PitCrew is offline   Reply With Quote
Old 03-30-2004, 04:08 PM   #8171
berger's Avatar
R/C Tech Charter Subscriber
Carpet TC3 setups. Right i need a better setup than what im running at the moment, i currently run the stock springs and allmost everything at default with some 28mm jaco spec blue foams and the shocks laid right down with the rear tower on the front. The car seems very stable maybe a touch slow in the twisties, can someone give me a point in the right direction, trying stiffer spings just seemed to lose me grip and time.
berger is offline   Reply With Quote
Old 03-30-2004, 05:09 PM   #8172
Speedie's Avatar
Default Re: chassis balancing
After I did the battery mod to my chassis it only took 14 grams of weight on the right side to balance it out perfectly.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 03-30-2004, 06:03 PM   #8173
Moderator
Speedo's Avatar
Can you run any other tires? If possible, switch to Jaco dbl pink orange/ dbl pinks. Last time I ran, we had a new layout which was pretty flowing, and traction was low. I ended up with purple/red, front tower w/ outer hole, rear tower middle. The car was awesome, but would probably only be on this track. I would try purple/copper springs as a good general place to start.
Speedo is offline   Reply With Quote
Old 03-30-2004, 08:41 PM   #8174
Tape is lighter than the battery strap...
Just a thought
Old 03-31-2004, 10:19 AM   #8175
rayhuang's Avatar
Default Bumper hangin down...
Hey all,
I got this from BMI mostly to hold my PT in place nicely and to keep my body posts from bending back, but low and behold-I didnt realize this also keep the RPM bumper up. Its like viagra for bumpers!!!
HOpefully I wont have to replace the otherwise perfect RPM bumper every two or three months since its draggin the carpet.
Ray
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
