Old 03-19-2004, 01:40 PM   #8131
dizzy1's Avatar
Trader Rating: 23 (100%+)
If you are running a rear tower up front and using the inside arm holes this happens, if it is, you have to use the outside hole on the arm.
dizzy1 is offline   Reply With Quote
Old 03-19-2004, 01:46 PM   #8132
Yeah, I figured that out about a minute after writing the email. Sorry for the dumb question and thanks for the replies!!!
Griffin is offline   Reply With Quote
Old 03-19-2004, 02:33 PM   #8133
Griffin,
You can also cut the ball end down some on the bottom of the shock. Basically the part that threads onto the shock shaft needs to be trimmed about 2mm, this allows the spring perch to sit lower which lowers the ride height.
Ozwald Bates is offline   Reply With Quote
Old 03-19-2004, 03:58 PM   #8134
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Check this out guys, I just got my new Diggity Designs driveshaft/input system in my car...it's SOOOO light...easily takes off half the weight of the stock system. It also frees up the car and it is wayyyy quieter. I'm testing it this weekend, should have MAD rip. It's been tested for weeks in stock/19t/mod and held up just fine.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-19-2004, 03:59 PM   #8135
Here's the next one...
USVTA Member #211
Old 03-19-2004, 03:59 PM   #8136
And the Last one...
PM me if you want contact info to get one.
USVTA Member #211
Old 03-19-2004, 04:01 PM   #8137
Send a message via AIM to Johnnytc3
how much is it? does it come in blue?
Johnnytc3 is offline   Reply With Quote
Old 03-19-2004, 04:06 PM   #8138
Send me a PM, and i'll get you info
USVTA Member #211
Old 03-19-2004, 10:28 PM   #8139
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Originally posted by mistercrash
I have noticed that this thread falls down to the second page quite often lately. Could it be that everything has been said and done about the TC3????
LOL. To me, it seems that too many people don't search, and post threads about things already discussed in previous threads, and bumps this thread to the second page.
HPI also makes bladders for shocks.(Just to let you guys know)
Bubblestc3 is offline   Reply With Quote
Old 03-21-2004, 11:06 AM   #8140
YES, it DID!
USVTA Member #211
Old 03-21-2004, 01:27 PM   #8141
Does anybody know who makes lightweight aluminum outdrives for the TC3 that use the stock (D shape) diff rings?
JWATT is offline   Reply With Quote
Old 03-21-2004, 01:31 PM   #8142
IRS
USVTA Member #211
Old 03-21-2004, 06:37 PM   #8143
berger's Avatar
Heres my TC3 its a team with a few bits and bobs added. Recently i finished up 8th out of 76 in the Ellesmere Port Winter Classic stock class. It was my first proper attempt at a competition so im pretty happy with the result. Im thinking about switching to composite dogbones to reduce the rotating mass but im not sure about strength if i want to use a one way, could go through a lot of them. Next update is perhaps cutting the chassis to move the batterys in which will require me soldering battery bars and moving my corrally connectors ontop of the cells which is no biggy. Thinking about getting a Revolution (V2) 10 single but not sure between the Hara and standard modified black endbell.
berger is offline   Reply With Quote
Old 03-22-2004, 09:26 AM   #8144
do the HPI bladders fit in the associated shocks? Would you have to remove the rubber o-ring from the assoc shock to make them fit?
zgeist is offline   Reply With Quote
Old 03-22-2004, 02:42 PM   #8145
DaveW's Avatar
TTT
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
