Old 03-17-2004, 09:31 AM   #8116
rayhuang's Avatar
Originally posted by OB42TC3
The brokomo bladders work great (not the whole retrofit kit, bladders only). I used the high traction ones and it increased the damping force so I had to step down in shock oil weight 10-20. So a little adjustment but well worth the lack of hassle for perfect shocks.
Cool!!
Old 03-17-2004, 10:08 AM   #8117
Thanks guys! That is very helpful. And your picture actually really cleared things up - without it I would have installed the bladders upside down!
As soon as I can get some I'm going to try it. And thanks for the warning about the potential change in damping.
zgeist is offline   Reply With Quote
Old 03-17-2004, 10:54 AM   #8118
acyrier - I've been exploring the website www.gsracing.com and horizon hobbies and GS seems to make several versions of shock bladders - there are even multiple links to ones that are 1/10th scale and blue. So my guess is that some are thicker than others, but I can't confirm this based on their website.
Since you've actually used them, acyrier, do you have any idea what the differences might be? Or perhaps you just order the same ones every time, or maybe even never had to order them more than once?
It probably doesn't matter that much, as long as I get one kind and stick to it... I was just curious.
Old 03-17-2004, 11:00 AM   #8119
acyrier's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to acyrier
Default Bladders.
I think just colors. I find it wierd that they have different colors since they are installed on the inside of the shock body and can-not be seen. I've actually never thought about them being different thicknesses. Note that there are also bladders for 1/8th scale. Make sure you pick-out the correct ones. I have lt.blue ones in my truck t4, and pinkish ones in my TC3. It's just what my hobbyshop had in at the time. When I installed the newones, (recently in my T4) I didn't look to see if they were the same as my tc3. I can look tonight if I get the chance.
Since your in chicago, you might be interested in our club race at Notre Dame. Check out www.lapazraceway.com for details if your interested.
The products and places I support.
www.michianarc.com www.facebook.com/michianarc - www.russellrc.com
www.teamtekin.com - www.teamcrc.com - www.teamassociated.com
www.fantomracing.com - www.discountrcstore.com
acyrier is offline   Reply With Quote
Old 03-17-2004, 11:07 AM   #8120
You don't have to check if it means opening up your shocks! ;-) I was just curious. But I did see at least two different part numbers for 1/10th scale bladders in Blue - maybe they were just different shades of blue! ..ha, ha!
What some people do for fashion!
I was looking at the shock caps that are sold at Speedtechrc.com and I don't see any bleed screws in the picture - does anyone know if they actually have bleed screws?
Old 03-17-2004, 11:11 AM   #8121
acyrier's Avatar
Actually,
since the kit comes w/(5) bladders, I should have 1 of each in my box. I'll try to rember and look. I have to mount and true some foam tires tonight anyway, so I'll be in the stuff anyway.
Old 03-17-2004, 05:29 PM   #8122
lem2's Avatar
To make all things easy, I switched to Tamiya Shocks they are easier to fill, less messy and more predictable.
Peace and Happy Racing!
lem2 is offline   Reply With Quote
Old 03-17-2004, 05:49 PM   #8123
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
hey guys..ive been reading up the last few pages. Ive got a few questions.
Should i upgrade to factory team graphite parts, or just stick with my current team version parts? $60, i dont race much but i might start this year, and i like to bash on the streets and alleys.
Ive stripped 1/3 of the slots in my diff cases, and im planning to order new ones. Should i get the warpspeed ones that have been blueprinted and special stuff in the screw holes? I looked up on the site, and $35 for diff cases? how much longer would they last?
What is the best way to remove stripped screws, i stripped like 4 of the screws on the underside of the chassis and cant get them out.
I also have the team version shocks on my tc3, is it time to upgrade to threaded or should i just save the money and stick with my current shocks? Im just trying to somewhat plan to start racing.
As for going to the local track... what should i bring? please list everything you bring
R3VoLuTiOn is offline   Reply With Quote
Old 03-17-2004, 06:26 PM   #8124
acyrier's Avatar
Default Answers...kinda
Now, keep in mind, when you ask questions like these, your going to get different opinions/perspectives/expierences.
The difference between graphite and your stock parts is Less Flex. (graphite has less) They ARE more fragile, but they're also a little lighter. The "stock" components are a little more forgiving when crashing.
I've heard of people placing Helicoils in different areas (including diff cases) to keep from stripping them out. I have been very fortunate and have NOT stripped out any holes. I do have a heli coil kit in my tool box, but it's a "just in case" thing.
The easiest way I've found to remove screws is by taking a cutting wheel and a dremmel, cutting a "slot" and taking the screw out w/a normal straightblade screw dirver. The "other" alternatitive, is the dremmel also has a very SMALL drill head. Looks like what the dentist uses and drill a hole into the head, then backing it out w/"easy-outs"
Your team shocks will perform well if you have all the spacers to be able to adjust your ride height. When and if you start racing more seriously, that might be the time to upgrade to threaded shock bodies.
HOLY cow.... a list...well... geeze...I bring too much, but here's prabably a minimum:
Tools necessay to change out any and all parts on your car.
at least (2) of what you break the most.
Charger,
discharger,
Soldering Iron
Powersupply (if your charger/discharger needs one)
radio, batts car...etc. (I've forggotten my radio by mistake...oops)
lubricants
spare parts
Most people have a fishing "tackle box" that they carry a lot of their tools and spare parts. Some people go on to carry their motor lathes and such to the track. I don't, I usually do my motor work at home when I have more time to do it right.
That's about all I can think of off the top of my head. You'll get lots more input shortly from other drivers I'm sure.
Old 03-17-2004, 06:37 PM   #8125
R3VoLuTiOn's Avatar
yea i totally understand, i just want to know all my options, and try to learn from others experiences.
Old 03-17-2004, 06:37 PM   #8126
Default Getting stripped screws out
Generally the term "stripped screw" is used in refrence to having the threads stripped out so you can't tighten the parts together. This is fixed by installing a helicoil in the part to make new threads. However, for a rounded out hex in the head of a screw. I have found over the years that a lot of the time you can take your hex (allen) wrench and grind about 1/8 inch off the end with a dremel tool to get a fresh hex. Most of the time that is enough to get a screw out but replace it with a new screw before putting it back together.
As for what to take to the track, take everything you have ever used to work on your car at home then borrow the rest of the tools you find you need. Before going back to the track, get your own tool for whatever you had to borrow last time.
Good luck.
Jack
oldrc12e is offline   Reply With Quote
Old 03-18-2004, 09:30 AM   #8127
tc3rookie's Avatar
should the shocks have bladders or foam things in the caps? i had the RTR shocks and upgraded to threaded body but there are none. is this going to help preformance and should i get them? Thanx.
tc3rookie is offline   Reply With Quote
Old 03-18-2004, 09:31 AM   #8128
tc3rookie's Avatar
Default sorry didnt read above...
please delete me above post. sorry
Old 03-18-2004, 11:49 PM   #8129
Default Ride Height
Hello,
After looking over several setup sheets for the TC3, I've noticed that standard ride height seems to be 4.5 to 5 mm in the front. Unfortunately, I cant seem to get my car this low. Even with the spring retaining ring screwed all the way to the top of the shock body, by my measurements (fromt he ground to the bottom of the chassis using a .200" indexing block) the car is still above 5 mm in front.
My batteries are in the forward position and I have an additional BRB extra wide bumper up front.
Any input?
Griffin is offline   Reply With Quote
Old 03-19-2004, 12:06 PM   #8130
PitCrew's Avatar
Make sure your shock ends are screwed all the way in.
Are you using associated springs?
PitCrew is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
