Old 03-07-2004, 02:26 PM   #8086
Default Oneway rubbing the diff case
I bought a used TC3 with a oneway and i was trying to replace the diff case. The problem is the screw that holds the delrin gear is rubbing against the side wall on the diff case. Anybody know where can I download instructions for the one way or can someone send me a pic of the instructions that came with it?
DRIVEN is offline   Reply With Quote
Old 03-07-2004, 02:53 PM   #8087
etzkev's Avatar
Send a message via AIM to etzkev
Default Re: Paragon
Originally posted by JSJ Racing
How long do you let Paragon soak into you foam tires before you wipe it off?
It depends how grippy the track already is, but like most tire compounds, they recommend about 15 minutes.
etzkev is offline   Reply With Quote
Old 03-07-2004, 09:08 PM   #8088
lem2's Avatar
Originally posted by SpeediePHATT
What ends are yoou guys using on the TRF shocks? Im using associated ends and spring cups I adjusted them so they are the same length as the associated ones were.
Using the AE ends and spring cups also with out any problems!
lem2 is offline   Reply With Quote
Old 03-10-2004, 04:29 AM   #8089
Send a message via AIM to presure2
ttt
presure2 is offline   Reply With Quote
Old 03-10-2004, 10:17 AM   #8090
raffaelli's Avatar
I just heard that there will be a new TC3 next month. A new rear end. There will be an upgrade available for the existing car. Anyone hear similar?
24ITA
raffaelli is offline   Reply With Quote
Old 03-10-2004, 02:07 PM   #8091
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
Someone probably mixed up the TC3 with the NTC3. The NTC3 has just been released with a new rear end. I doubt that it is new parts for the TC3.
Airwide is offline   Reply With Quote
Old 03-10-2004, 02:27 PM   #8092
raffaelli's Avatar
Oh...could be. Thanks!
24ITA
Old 03-10-2004, 03:18 PM   #8093
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
When I was using Associated springs on my EVOIII the other week, I used the stock spring cups, they are just the right size, and there were no problems fitting on the shock.
Bubblestc3 is offline   Reply With Quote
Old 03-11-2004, 07:14 AM   #8094
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
Hey I have a fun I dea lets all post pictures of our cars and their mods. I will start.
tc3stocker is offline   Reply With Quote
Old 03-11-2004, 11:51 AM   #8095
etzkev's Avatar
Uhhh...ok. Lets try to act a little older than 2 years here.
Old 03-11-2004, 12:00 PM   #8096
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
just a question, im running a 10x2 d4 or d5 dont remember which and i was wondering what to start the gearing at for my tc3, running 60 mm foam tires on a preatty open track, cuz last time i raun it i used a 19 with 56mm foams and i got it so hot the brushes came off
Kave is online now   Reply With Quote
Old 03-11-2004, 12:34 PM   #8097
PitCrew's Avatar
You should probably be somewhere closer to 25/26-72. For a med-larger size track.
PitCrew is offline   Reply With Quote
Old 03-12-2004, 04:31 PM   #8098
I have decided to dremel out my Graphite chassis and move my cells in. Do you guys have any suggestions on how to go about doing this task? I mean like what dremel tip and any other tips you guys could give would be greatly appreciated.
Pleskit is offline   Reply With Quote
Old 03-12-2004, 07:39 PM   #8099
tirbolag's Avatar
here's a link. a very informative site...the person "mistercrash" does an excellent job in going step-by-step on how to do the battery mod.
http://www.mistercrash.ca/_themes/page_mod_tc3.htm
tirbolag is offline   Reply With Quote
Old 03-13-2004, 07:56 PM   #8100
tc3 racer sc's Avatar
Default good stock set up on asphalt
any good asphalt set up for tc3 and good set up on concrete track wth low grip i was running at a track and my rear end kept coming around and i was also testing my new helio radio some plse help
tc3 racer sc is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
