Old 02-21-2004, 07:10 PM   #7996
Don'k know what to get. Im looking for a new on-road car. Don't know if I should get the TC3 since its a couple years old. A worker at my LHS told me that the TC3 is to old, he said It doesn't Keep up with the New cars.
What car do you guys think I should get?
Thanks alot
GSR40 is offline   Reply With Quote
Old 02-21-2004, 07:17 PM   #7997
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Not sure what your buddy is smoking. Does not keep up. Maybe Mike Blackstock, Barry Baker, and Mike Dunnighan caouldn't keep up in 2003 as they all won National Titles with the TC3. If you like the car it is fast on any surface with any type of tire. Old but proven and still as good as any of the top cars out their.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 02-21-2004, 07:23 PM   #7998
So that isn't true, Should I get the TC3? I know they have alot of hop-ups. I've heard alot of good things about the TC3 in the past.
I Realy believed the guy He's been into rc cars for a long time.
Old 02-21-2004, 07:28 PM   #7999
wyd
Tech Legend
wyd's Avatar
I have been r/c racing for 18 years. The TC3 is still one of the top 5 cars out their. Pros are great drivers but if the car is lacking even they would have a hard time keeping up as they are racing against other pros. Parts are easy to get and their are a ton of setups for the car.
Old 02-21-2004, 08:58 PM   #8000
tc3 racer sc's Avatar
Default losi rear hubs
i installed the losi hubs on my car which hole do i use the inside or outside on the hubs/ just finishing put a new chasis rebuilding car after the snowbirds thxs reggie
tc3 racer sc is offline   Reply With Quote
Old 02-22-2004, 12:34 PM   #8001
Superfly1967's Avatar
Default Running rear tower on front
When running the rear tower on the front like Blackstock, with his setup concerning shock mounting position, how do I get the ride height low enough? I can't get it lower than 5.5mm in front and that is moving the upper shock mount up and out one from his setup. Do I use limiters?
Superfly1967 is offline   Reply With Quote
Old 02-22-2004, 03:46 PM   #8002
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Run smaller tires or change your droop.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-22-2004, 05:04 PM   #8003
Default Re: Running rear tower on front
a cpl of pages bck mike blackstock say their playing wth roll center and doing shocktower in front look bck few pages
Old 02-22-2004, 07:40 PM   #8004
tirbolag's Avatar
you can cut about an 1/8th of an inch on the shock ball end...or you can unscrew the shock ball end to lenthen the shock, there for lowering your ride height.
when i installed the rear shock tower in the front, i just cut about 1/8th of an inch or 2-3 mm on the shock ball end. doin that allowed me to lower my ride height.
look back a couple of pages and there was a post concerning ride height with the rear shock tower....coz i was the one who asked the same question
tirbolag is offline   Reply With Quote
Old 02-23-2004, 11:05 AM   #8005
EDWARD2003's Avatar
Default New TC3 Conversion
[IMG][IMG]Chassi01.JPG-0.0[/IMG][/IMG]
EDWARD2003 is offline   Reply With Quote
Old 02-23-2004, 11:27 AM   #8006
Anything new coming for the TC 3 anytime soon. I'm thinking of getting one.
Homer Allman is offline   Reply With Quote
Old 02-23-2004, 03:47 PM   #8007
davepull's Avatar
check back a few pages on this thread for blackstock I think he uses .030 spacers under the tower.
davepull is offline   Reply With Quote
Old 02-23-2004, 07:39 PM   #8008
Speedie's Avatar
I put spacers under mine. My TRF shocks are a little on the long side to begin with but just one washer under the 3 screws gives you alot of adjustment.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 02-23-2004, 09:23 PM   #8009
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
If you raise the shocktower, that also alters the roll center. The cutting of the ball cup(holding the shock on the arm) to allow the spring collar to sit lower will give you the desired ride height, with out adjusting the role center in the process. You are also adjusting the angle of the shock(although very slightly), you are somewhat standing the shock up more when raising the tower.(Triangle, change the length of a side, and you change another side's length, along with two of the angles in the triangle)
Bubblestc3 is offline   Reply With Quote
Old 02-23-2004, 09:30 PM   #8010
Default Re: losi rear hubs
The inner hole on the Losi hub is close to the outter hole on the TC3's rear hub(although may be a different height). The holes can be used as a tuning option, you don't just have to use one hole or the other.(inner hole=more steering/less rear traction, outter hole=more rear traction)
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
