Old 02-20-2004, 05:38 PM   #7981
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
No, MarchTC3, the Warpspeed wasn't designed just for carpet, it was designed for all surfaces that we race TC's on. What handles better to you might not handle as good to someone else . Believe me when I tell you that with the right setup on the Warpspeed car will be faster 9 out of 10 times than the IRS with the same driver.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-20-2004, 05:56 PM   #7982
Could it be that im a better driver Yeah right! His car just seemed to be a little looser than mine but it could mean a lot of other things that caused it. Most of the time though his car is faster than me and has better handling.
MarchTC3 is offline   Reply With Quote
Old 02-20-2004, 07:55 PM   #7983
davepull's Avatar
the new sales pitch for the next touring car from associated is " the new tc4 don't hit nothin, I mean nothin"
davepull is offline   Reply With Quote
Old 02-21-2004, 12:12 AM   #7984
Whats the deal with people using losi parts on there TC3's r they stronger or what, i would also like to know the part # for the losi parts.
Cheers.
Doug Smith
RC America - X-ray - Hudy
doug smith is offline   Reply With Quote
Old 02-21-2004, 02:21 AM   #7985
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
I use Losi rear hubs for two reasons.
1. They are availabe with 1/2 toe-in(I usually run 2.5 of rear toe-in).
2. The hubs have a different set of camber link holes. The inner hole on the Losi hubs are close to the outer hole on the AE hubs.
I haven't tried the Losi caster or steering blocks though.
Airwide is offline   Reply With Quote
Old 02-21-2004, 06:04 AM   #7986
lem2's Avatar
Default LOSI PARTS
Reasons:
Knuckle arms don't strip and better steering
Rear hub, for additional Toe-in
C-hubs, i use the LOSI 6degree hubs with a spool to make it turn better!
Some other racers use the springs for an in between spring weight, ifthey can't find it with the AE springs.
Peace and Happy Racing!
lem2 is offline   Reply With Quote
Old 02-21-2004, 06:05 AM   #7987
Speedie's Avatar
I definately think the Losi hubs are stronger. I switched a while ago and ran the same Losi set for 2 months. Then 2 weeks ago broke one, and replaced with an ae one. since Ive replaced the AE one twice.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 02-21-2004, 06:46 AM   #7988
lem2's Avatar
Default NTC3 Steering
I have noticed/seen that if I use the NTC3 rack on the TC3, the turnbuckles are really angled.
Will this cause any problem? And By using the NTC3 rack, will I feel any difference, like from switching to Losi Knuckles?
Thanks in advance!
Lem
Old 02-21-2004, 07:59 AM   #7989
Can anyone give me instructions on blueprinting the diff cases on my tc3. I need to know where to remove the material to make my drivetrain spin more freely. Thanks in advance.
qcrvr is offline   Reply With Quote
Old 02-21-2004, 08:12 AM   #7990
new92's Avatar
I am wanting to blueprint mine too, but I am afraid of doing the wrong area and not having teh cash for a new chassis at the moment some pictures or a walkthru would be really nice.
new92 is offline   Reply With Quote
Old 02-21-2004, 09:32 AM   #7991
etzkev's Avatar
Send a message via AIM to etzkev
Well it doesn't really involve the chasis at all, so you don't need to worry about ruining that. What happens is when the two Diff Case halves are tightened together, the bearings are pinched, causing more drag. All you need to do is use a dremel to take some (not too much) of the material out where the outdrive bearings are touched. That way, when you tighten the diff back together, the bearings won't be pinched.
Hope this helps,
etzkev
P.S. Feel free to ask any questions.
etzkev is offline   Reply With Quote
Old 02-21-2004, 09:40 AM   #7992
lem2's Avatar
Default Go here
hope this helps as an inspiration to your blueprinting!
goodluck!!
http://www.mistercrash.ca/_themes/pa...ciated_tc3.htm
Old 02-21-2004, 05:16 PM   #7993
hogdaddy77's Avatar
dumb question...
I have the RTR version TC3..how free should it be and is the
freeness measured-- with the motor in, or out? Right now the motor is out, and it feels a little tight when I spin a wheel...
it being the RTR, should I rebuild the diffs?
hogdaddy77 is offline   Reply With Quote
Old 02-21-2004, 05:20 PM   #7994
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
You might not need to rebuild the diffs but I'm sure it won't spin freely. You will more tahn likely need to clean out all you bearings and relube with a lightweight oil lik WD40 or something similiar. Then put each transmission back together and after you tighten down the diff cases then check to see how smoothly it spins. You will more than likely need to loosen up your scres on the transmission cases to get it to spin nicely and you might have to use spacers or dremel the cases a little to get it all freed up.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 02-21-2004, 05:29 PM   #7995
hogdaddy77's Avatar
thanks for the info!
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
