Old 01-19-2002, 10:28 AM   #781
Corse-R's Avatar
Originally posted by dw
When the car reaches its maximum angle of roll the force must be entirely compensated for by the springs as the damper is not moving and therefore can't produce a force. The force a spring produces is proportional to the amount it has been compressed, so it must be compressed the same amount regardless of the damper settings. This means that the maximum angle the car reaches is independant of damper settings.
Ok, ok.. you're right, but for the time that really lasts a turn, the oil opposes too a force to the compression up to the time it cannot be compressed more (what really compresses into the shock is the little quantity of air on it) and then the shock locks itself and then the only way that a shock can work is uncompressing it and the spring can be compressed more and more at this moment but the oil don't permits (then the turn should 'say' if they can be uncompressed by the act of forces under).
If not, only two things can occur, a beatiful slide because the abrupt lack of grip or if the tyre can cope with this, a chassis flip.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-20-2002, 09:38 AM   #782
johnbull's Avatar
Hi guys. Greetings from Malta.
Great day for the TC3 again in Malta today.
In modified, son Josh won both finals with his John Bull Racing TC3 with another TC3 second, whilst both the Stock finals were also won by a TC3 driver.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 01-20-2002, 11:08 AM   #783
Impreza's Avatar
Send a message via ICQ to Impreza
I am just wondering what kind of grease I have to put on the gears in my diffs, between the ring and pinion I think its called? I also will put the front one way in, and do I have to use a different type of grease for that?
Thanks!
Impreza is offline   Reply With Quote
Old 01-20-2002, 12:49 PM   #784
Impreza,
If you mean the input gear, from the carbon drive shaft, to the bevelled gear on the diff, most people I know put a little silicon diff grease on these parts.
It's not strictly needed but I think it'll help in the long run.
Some people may argue it impedes the free running of the gears but you'd have to be a pretty serious racer to notice the difference.
In short, a little grease won't do any harm and may prolong the life of the gears. Just my opinion.
Yorkie
Yorkie is offline   Reply With Quote
Old 01-20-2002, 02:44 PM   #785
Buda's Avatar
Default servo probs
Ok two weeks in a row I lost a servo. last week my servo saver came loose probably on a board hit or punt. I readjusted it and lost a servo, i wasnt sure on the adjustment as I didnt have my manual but come to find out I was pretty close this week I had it adjusted to the manual and lost another. nothing was hit hard (2' thick rope) or just a light punt caused it around a hairpin. I had "standard" JR servos could something be wrong with my servo saver or are the servos not really up to it. I dont want to frk out 70-100 for and top servo. any help will be REALLY appreciated. as in what adjustments to make or a good servo less than 50 is a metasl gear servo really needed?
Buda is offline   Reply With Quote
Old 01-20-2002, 02:52 PM   #786
The TC3 is a bit rough on servos. You can get a Kimborough small servo saver and use that instead of the associated servo arm, this will help quite a bit. You might have to do a little trimming but it isnt a big deal. The hitec 525MG is a great low cost metal gear servo, yea its not as good as the expensive ones but hey it costs less than half their prices. Servos can fail because of several reasons, if you don't have the end point adjustments of your radio set and the servo will continue to try to turn your wheels farther even though they have reached lock this will damage your servo and it is the number one reason for throttle servo failure in nitro vehicles and I suspect a very common reason for failure for steering servos too. The big problem is that people that wouldnt know this are more likely to be fairly new and the lower end radios dont have seperate right and left EPA adjustments.
patcollins is offline   Reply With Quote
Old 01-20-2002, 07:39 PM   #787
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
One other thing you could try if you haven't done so already is squeeze the spring with a pair of plyers a couple of times. This should help some.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-21-2002, 09:55 AM   #788
Just out of curiousity, have any of you experimented with placing washers under the ballstud located at the steering knuckle? Supposedly it helps to eliminate bump steer from what I've been reading. My question is what feeling does that mod have on the track? Does it make steering feel more responsive, smooth it out or something else entirely? I race foams on carpet by the way.................
Schuie Driver is offline   Reply With Quote
Old 01-21-2002, 12:29 PM   #789
Schuie I guess you mean the ballstud at the end of the steering linkage. I don't really see there being enough suspension movement in a sedan for that to do much of anything. Now on the upper ballstud on the camber link I have put a thin washer under it on occasion, lowers the roll center slightly so the front of the car rolls a bit more in the turns.
Old 01-21-2002, 01:07 PM   #790
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
Actually, you are raising the roll center when you put a washer under the ballstud. If you want to lower RC slightly, put shims under the shocktower
Airwide is offline   Reply With Quote
Old 01-21-2002, 02:05 PM   #791
Thanks guys........I didn't think there would be much of a noticable difference either but it seems like a bunch of the set up sheets I've read lately have a raised ballstud at the steering knuckle. (not the camber link
Old 01-21-2002, 07:37 PM   #792
Shuie:
Hi,
we are playing around with this. so far we are at .062 shim under the ball stud on the steering knuckle. it seems to take out all the bump steer when we do this. (not sure this is a good thing....yet). we run on carpet/foams. can't really say if it's better. just yet. seems to depend on the track layout i.e flowing or not. I will post more when I have more track time on this setup.
Fakk2 is offline   Reply With Quote
Old 01-22-2002, 07:38 AM   #793
TPhalen's Avatar
R/C Tech Charter Subscriber
You will see more action from the shims under the ball studs if you use them when you change out the caster blocks.
Typically, this is our setup...
0 deg Caster blocks = 1 .100" Spacer
2 deg Caster blocks = 1 .060" Spacer
4 deg Caster blocks = 1 .030" Spacer
This helps out with bumpsteer. This is assuming you are running the F+2 block in the front (2 deg of Kickup).
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 01-22-2002, 01:11 PM   #794
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Tony > Are these the same spacers that make the care longer or shorter? I thought they were all the same size. Where or what part number are the different size ones?
wolfeman09 is offline   Reply With Quote
Old 01-22-2002, 02:15 PM   #795
Thanks for the help Tony!!! Now I just have one other question........when you talk about eliminating bump steer on the car what does that mean? Will my steering be smoother as a result of eliminating the bump steer, will it be more agressive? I guess what I'm trying to say in not so many words is what effect does bump steer have on a car?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
