Old 02-14-2004, 09:39 AM   #7921
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Just to piggy back off tc3 racer sc, there was another thread, closed about a month back, informing us of no new TCX. Both Barry and Tony Phalen (employed with AE) said they knew nothing about a new onroad kit.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 02-14-2004, 09:41 AM   #7922
Roger's Avatar
yeah, the new TCX is that new Yokomo CGM car. I saw it last night at a race and it looks like a TC3
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 02-14-2004, 10:23 AM   #7923
LOL.....yeah.....right.....Brokomo CGM:=TCx.
V-Dezign 4.0
Old 02-14-2004, 06:29 PM   #7924
29Dennis's Avatar
Default Tamiya Shocks and TC3 Springs?
I was wondering if anyone if the Associated springs will work on the Tamiya shocks. If anyone has any suggestions on goos shocks it would helpful too.
29Dennis is offline   Reply With Quote
Old 02-14-2004, 07:24 PM   #7925
P2
P2's Avatar
Default Re: Tamiya Shocks and TC3 Springs?
Yes ASE springs do work on the Tamiya shocks, i used to run them on my Evo 3.
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 02-14-2004, 07:25 PM   #7926
29Dennis's Avatar
thanx P2
Old 02-15-2004, 12:56 AM   #7927
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Default Re: Re: Tamiya Shocks and TC3 Springs?
Especially at the Tamiya Track!
WOW, TC3 was DIALED today!!! I tried one of JasonC's chassis' where he moved the battery towards the shaft, and it did not feel much different... (but the car was indeed lighter because of all the material removed and I taped my batteries in, rather than using the battery bar)
Bubblestc3 is offline   Reply With Quote
Old 02-15-2004, 05:03 AM   #7928
lem2's Avatar
Default Help!
Call it stupid, but I accidentally placed a small amount of
(Prol-Line) Liquid CA to keep my antena from fallin off, but a small amount went inside the tube and got to the antenna wire.
What is the best debonder for this type of CA?
and if while doing do so the antenna wire gets cut, can I replace it or just add wire to make it the exact lenght again?
I'm using a Ko302 Rx.
Many Thanks!!
Lem
lem2 is offline   Reply With Quote
Old 02-15-2004, 05:50 AM   #7929
P2
P2's Avatar
Default Re: Help!
Many Thanks!!
Lem
You can try soaking the wire/tube in acetone(nail polish remover) and work it's way out. I don't think you'll get it out though. Your last resort would be to replace the wire with the exact guage/length.
Good luck,
P2
Old 02-15-2004, 06:02 AM   #7930
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default IRS OUTDRIVES
I just started building the IRS outdrives and i can't see how you screw the diffs topgether as the IRS ones don't have anywhere for the nut to bed into to stop it from turning in the smaller of the two.
amyone else experience this
regards brad
Xray T4 16 | Sanwa MX11 | Much More Fleta | HW 3.1 | LRP Batteries | Team Argo | Meakin Park | Bayside | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 02-15-2004, 02:38 PM   #7931
DaveW's Avatar
BRAD: You use the white locknut from the steel TC3 outdrive set to secure the IRS set. The spring also goes under the nut, and not under the thrust assembly, as in the plastic TC3 outdrive set.
I evidently had problems with my digicam at the Birds. I have only a few pics on the memory card... im very upset. I THOUGHT had a ton of them to share with you guys. Anyways, here is one remaining pic of my car.
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 02-15-2004, 02:47 PM   #7932
Default Ca glue problems
I would try to VERY CAREFULLY cut through the tube on either side of the glue then soak it in the acetone. I take awhile for the acetone to work, probably around 2-3 hours since its inside the tube but it should soften the glue enough to remove the wire. If not you will have to replace the whole wire as was stared earlier. Good Luck!! Maybe next time try Shoe-Goo.
ccm399 is online now   Reply With Quote
Old 02-15-2004, 02:57 PM   #7933
etzkev's Avatar
Send a message via AIM to etzkev
- Dave
Nice looking car! Very clean! Correct me if I'm wrong, but isn't it against rules to mount the transponder in front of the front shock tower?
-etzkev
etzkev is offline   Reply With Quote
Old 02-15-2004, 02:59 PM   #7934
JusBox's Avatar
get some ca remover. should be available at any decent hobby shop
JusBox is offline   Reply With Quote
Old 02-15-2004, 03:05 PM   #7935
etzkev's Avatar
- Dave
Oh, and BTW, what shocks are those?
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
