Old 02-02-2004, 08:19 PM   #7831
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
The plastic spur gear mount is not true at all.
Speedo is offline   Reply With Quote
Old 02-03-2004, 05:10 AM   #7832
lem2's Avatar
Default ALUMINUM PARTS
I have tried, GPM, IRS, tobee craft and SQUARE on the TC3.
I prefer the build quality of the SQUARE parts. So if you plan on changing the knuckles get the ones from RC-SQUARE they have 2 versions one is the exact replica of the TC3 and the other is the LOSI XXX-s, and they come in BLUE!
I agree with speedo that the IRS is not that true, have changed it to SQUARE.
they have a lot of cool stuff for the TC3.
http://www.rc-square.com/parts24.htm
use this to translate
http://babelfish.altavista.com/
Just duno how you guys could get them.
Just saying this so you would not waste money.
Peace and Happy Racing!
lem2 is offline   Reply With Quote
Old 02-03-2004, 10:35 AM   #7833
I disagree with this, mine (and I have several) spins perfect. The spur gear is perfect. Don't crank the screws down so you warp the spur.
spyderx is offline   Reply With Quote
Old 02-03-2004, 11:07 AM   #7834
mab_man20's Avatar
Send a message via AIM to mab_man20
The problem with the plastic spur gear mount isnt the screws used to mount the spur. What ive experienced is the pin slowly enlarges the slot in the plastic causing side to side slop, and then if not replaced widens the slot enough to get a forward-backward slop which causes uneven meshing and wear on the spur.
With that, how do i order from that site and what is the price of the spur gear hub shaft?
mab_man20 is offline   Reply With Quote
Old 02-03-2004, 11:15 AM   #7835
stormperson's Avatar
Send a message via AIM to stormperson
The IRS spur gear mount actually wears just as fast as the stock plastic one, and it costs 4x+ as much, although it is pretty.
I just change my stock one every few months as well as the input shafts, although I always leave my pinion and spur (in the gearboxes), since those are broken in and mesh well (and thus are smoother).
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 02-03-2004, 04:23 PM   #7836
Moderator
Speedo's Avatar
I've gone through several of the stock spur gear mounts, and a few spurs with each one, and they never spun true. I don't know what the IRS part is like, but I got the Trinity mount and that fixed my problem. Maybe I just got some bad parts, but it makes sense to me that a molded part cannot be as precise as a machined part due to the inherant cooling and shrinking of the composite used in the stock mount, which could easily cause the surface not to be flat, and not a perfect right angle with the input shaft.
Old 02-03-2004, 10:06 PM   #7837
Ian_da_bomb's Avatar
Send a message via AIM to Ian_da_bomb Send a message via Yahoo to Ian_da_bomb
How do I buy some of those Sqaure parts?!?!?! They have nice body mount braces from what it looks like... as well as some gorgeous blue aluminum things that would be a great waste of money and would look great on my car. Does anyone know of any US distributors?
Ian_da_bomb is offline   Reply With Quote
Old 02-04-2004, 05:05 AM   #7838
Horatio's Avatar
Moulded parts do vary in consistency and thats a fact. I have to say though that I never had a problem with mine, but I was very careful to tighten the screws uniformly and not to clamp them down too hard. A machined part will almost always be better (assuming it is well machined) especially if it's a rotating part. However, they are not necessarily lighter....
Leave the lap times do the talking guys!
Horatio is offline   Reply With Quote
Old 02-04-2004, 06:03 AM   #7839
Hey, does anyone have a setup using, pink, magenta, and/or platinum foam tires? I run indoor asphalt that has medium/ high traction. I normally run purple(rear), dbl. purple(front), but the pinks, magentas, and platinums came with a box of foams that I bought.
Pleskit is offline   Reply With Quote
Old 02-04-2004, 09:31 AM   #7840
rc-zombies's Avatar
anybody here knows if someone makes Ti Dogbones for the TC3?
lmk thanks
For those looking to order Square parts visit Rc Model in HK at:
http://shopping.rcmodel.com.hk/
Old 02-04-2004, 12:30 PM   #7841
hi just registered..
Grrr took some time to find this place.
Does anyone have any carpet setups
for the tc3 running on pit shimzu d20 d treaded
26mm wide rubber note they have a wavey pattern. On ozite carpet running a stock p2kpro
and a general roll out or gear ratio for this motor.
thanks
Smoking motor.. is offline   Reply With Quote
Old 02-04-2004, 12:54 PM   #7842
Horatio's Avatar
thanks
This is one cool place, that's for sure! It's good fun looking back over the old pages - but all 260 will take you a while
There have been loads of carpet set-ups - one is bound to work for you.
Many advise to use Barry Baker's carpet setup as a base and fine tune that.
Personally, I think it's better to improve your car bit by bit to suit your own style of driving and arrive at a setup that way. There is no right set-up. If a change improves your times - keep it, if not - don't. I reckon this is the way to learn, too.
Old 02-04-2004, 01:00 PM   #7843
Horatio's Avatar
For the P2k 2, I reckon you'll be using pinions in the region of 22 - 25 teeth, depending on the size of the track.
That an overall ratio range of 1:8.18 - 1:7.20
Somewhere within that range you'll find gearing to suit your indoor track.
BTW, I don't use rollout for rubber tyres - I stick to counting teeth.
Rollout is for foamies
Old 02-04-2004, 01:13 PM   #7844
www.titaniumracing.com makes titanium cvd's for the tc3
RC311 is offline   Reply With Quote
Old 02-04-2004, 01:24 PM   #7845
rc-zombies's Avatar
who sells in the US? all I see from TIR are Pinions...
Had a difficult time ordering from TIR last year.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
