Old 01-29-2004, 07:46 PM   #7786
hogdaddy77's Avatar
Default virgin racer here
I am going to be racing my TC3..the RTR version..with a quantum competition esc, monster stock pro motor, sorex tires(26R), and a XS3 radio,,, the only hop-up on her is threaded shocks..besides practice..is there anything else I should have/do?
hogdaddy77 is offline   Reply With Quote
Old 01-29-2004, 07:50 PM   #7787
protc3's Avatar
3mm is stiffer than 2.5.there are a few different types of c/f.you have 0,90 deg.,0,90,45 deg.,carbon kevlar,and colored c/f.they are all available in different weaves.the ones i use (BMI Racing)is colored c/f fine weave layed at 0,90,45 deg. and black layed at 0,90,45 deg.
they all are good for different applications.the only one i dont like is kevlar c/f.it is abrasive as hell and not very stiff.it is abrasion resistant but it has very similar qualities of fiberglass.
protc3 is offline   Reply With Quote
Old 01-29-2004, 07:51 PM   #7788
carkillaii's Avatar
Thanx Biran
U learn something new every day
carkillaii is offline   Reply With Quote
Old 01-30-2004, 04:16 AM   #7789
lem2's Avatar
Default QUESTIONS
1. what do you use to remove the anodizing? Will oven spray cleaner work? Will do a TC3 project and want all the components to be in silver!!.
2. Can I also mill a team chassis even if its composite? If the flex will be too much, by adding an uper deck solve this?
carkillaii
Buy both the BMI and WARP, so you won't confuse yourself anymore
You won't go wrong with either!! Peace to U and Happy Racing!
Brian McGreevy
I posted ur picture at our thread, would love to have a fellow Warp owner here
lem2 is offline   Reply With Quote
Old 01-30-2004, 05:19 AM   #7790
Horatio's Avatar
Originally posted by Randman
I was surprized as well. I took my chassis to DA graphite who used to supply some of the RC manufacturers with their graphite, and he showed me how to look at the weave, and sure enough, there was nothing diagonal.
Is this 'missing' weave apparent with the Yok Black CF chassis?
I often wondered why the SSG chassis was so 'flexi'.
Horatio is offline   Reply With Quote
Old 01-30-2004, 05:34 AM   #7791
Location: Rory Brenen - 2nd Last- Metro Masters DISGRACE
Send a message via AIM to Rory2Qik Send a message via Yahoo to Rory2Qik
Originally posted by Rory
i know the warpspeed changes the layout, but i think the BMI and IRS chassis' are the same
Who cares Rory, Build a bridge...
I love you xxx
Rory2Qik is offline   Reply With Quote
Old 01-30-2004, 09:29 AM   #7792
I dont want to turn this into a SD thread when I was interested in the design of the TC3, but maybe you can relay back to warpspeed that it would be a good idea to countersink the upper deck, this will reduce the likelyhood of the chassis twist.
Randman, maybe that's part of the reason why I've had so little problem what tweak on my Warp cars. The Upper decks DID come with countersunk screw holes.
DOTMAN is offline   Reply With Quote
Old 01-30-2004, 11:59 AM   #7793
hyperformance's Avatar
anybody got a link for Hardcore or for the Extreme chassis? i found the IRS, Warpspeed & BMI sites, but not the others.
hyperformance is offline   Reply With Quote
Old 01-30-2004, 12:06 PM   #7794
www.racinghardcore.com
jcrouse is offline   Reply With Quote
Old 01-30-2004, 02:36 PM   #7795
thanks
Old 01-30-2004, 03:17 PM   #7796
BlueisBetter's Avatar
Default Stock setup
Hey all
I was just wondering what tips and tricks you all use to get the most from the your setup assuming everything is free and running smooth and you have the best possible speed when racing 27thurn and 19turn
So should I use 0 degrees toe front and rear to get the most straight line speed and go softer on your tyres and then 0 degrees Antisquat to help traction under acceleration out of the corner
{ assuming the track is flat }
just so you know I run a TC3
so help with this particular chassis is appreciated
BlueisBetter is offline   Reply With Quote
Old 01-30-2004, 03:40 PM   #7797
29Dennis's Avatar
Default Shocks suck!
I was wanting to know how often everybody re-builds the shocks. I've been having to re-build mine about every race weekend. They lose their rebound which I notice when I try to check my droop.
29Dennis is offline   Reply With Quote
Old 01-30-2004, 04:00 PM   #7798
Are you losing oil from the o rings at the bottom of the shock cos you shouldnt be losing oil really
check the top of the shock for that seal too cos the leak has to be one end
Old 01-30-2004, 04:02 PM   #7799
29Dennis's Avatar
well I just took the shocks apart and they were clean around them and not hardly any air in the oil either.
Old 01-30-2004, 05:41 PM   #7800
mab_man20's Avatar
Send a message via AIM to mab_man20
More important that what is in the shock is what is outside. Is the arm or area around the lower shock mount covered in oil? If your losing the rebound the oil has to be going somewhere.
Id rebuild the shocks using a liberal amount of green slime on a set of new o-rings and see what happens.
Brian: No torque steer??? lol jk.
mab_man20 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
