Old 01-29-2004, 07:05 PM   #7771
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
See
ooops, forgot pic...
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-29-2004, 07:10 PM   #7772
Chassis & Top Deck
USVTA Member #211
Old 01-29-2004, 07:10 PM   #7773
Car put together
USVTA Member #211
Old 01-29-2004, 07:11 PM   #7774
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I've seen those pics I think in the other thread before, but it really just looks heavy to me... I think the CGM will be the answer for the SD owners looking for a stiff car.
Old 01-29-2004, 07:13 PM   #7775
protc3's Avatar
i think the problem with the yokomo cars is that they cut the carbon fiber in the wrong direction.carbon fiber is directional(when layed at 0,90,and 45 degrees).it is stiff as a brick in one direction and flexable the other way.you need to base your design on that and i have a mr4tc and the chassis is not cut right.
im all scrubbed up
punk
protc3 is offline   Reply With Quote
Old 01-29-2004, 07:14 PM   #7776
Maybe, definitely worth a look for all SD owners though.
USVTA Member #211
Old 01-29-2004, 07:14 PM   #7777
im all scrubbed up
punk
Actually Yokomo doesnt use any 45 degree fibers in their chassis, this is why there is so much torsional flex in the chassis.
Old 01-29-2004, 07:15 PM   #7778
Jason, that's the problem with almost ALL (production) double deck cars out right now.
USVTA Member #211
Old 01-29-2004, 07:16 PM   #7779
I dont want to turn this into a SD thread when I was interested in the design of the TC3, but maybe you can relay back to warpspeed that it would be a good idea to countersink the upper deck, this will reduce the likelyhood of the chassis twist.
Old 01-29-2004, 07:23 PM   #7780
protc3's Avatar
they use 0,90?wow,i am doing a sd chassis kit and i couldnt think of anthing but that they cut it the wrong way because i even made an identical upper brace and it was stiffer with my brace.wow,that took me by surprise.thanks for the info randman.
brian,is that what extreme and irs use?
Old 01-29-2004, 07:25 PM   #7781
Yeah, and they use lower quality two weave CF at that.
USVTA Member #211
Old 01-29-2004, 07:29 PM   #7782
I was surprized as well. I took my chassis to DA graphite who used to supply some of the RC manufacturers with their graphite, and he showed me how to look at the weave, and sure enough, there was nothing diagonal.
Old 01-29-2004, 07:40 PM   #7783
protc3's Avatar
interesting.i have to admit,i didnt even think to check it.i never would have expected that.
Old 01-29-2004, 07:41 PM   #7784
carkillaii's Avatar
so it does'nt matter if the chassis is 2.5mm or 3mm
what matters is how its cut to get the best strength
or how stiff its going to be?
carkillaii is offline   Reply With Quote
Old 01-29-2004, 07:43 PM   #7785
No it does matter. A 3 mm chassis with the good CF will be a bit stiffer than 2.5 mm of the same quality stuff. But what we're saying is the triple weave CF in 2.5 will be stiffer than 3 mm stuff, and much stiffer than 2.5 mm stuff of what most companies use, just because of that extra weave.
USVTA Member #211
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
