TC3 Forum
#7757
BMI Chassis
Originally posted by Rory
i know the warpspeed changes the layout, but i think the BMI and IRS chassis' are the same
Before I purchased the BMI, I looked at the demon 1 and 2. I'm not really sure what made me by the BMI. I just happend I guess.
#7758
Originally posted by Randman
Thank you for the info Brian.
One thing I don't fully understand is that with a double deck, if the chassis twists enough, the screws will slightly shift and cause tweak. Of coarse this is less likely to happen with the stiffer chassis, but it does still happen. You wont have that problem with the tub chassis that the car comes with stock.
#7760
Originally posted by carkillaii
Is it an instant change in performance
with the bmi and worpspeed chassis
#7761
Tech Legend
Trader Rating: 51 (100%+)
I just built my BMI car and will be running on Saturday. I went with them because when I looked at it and compared the features it was the overall best for me. I like the fact that I didn't have to file the chassis. Most kits today seem to have alot of work to do to them once you get them, like filing battery slots. Also once I saw BMI's shop with the total state of the art equipment that also swayed me. The final point was Jason of BMI was very helpful and didn't put down any other manufacture and has total confidence in his product. I had my chassis overnighted and showed up right on time.
The best is look at all the chassis out their, Hardcore Racing, Extreme, Warpspeed, BMI, IRS and a few others I missed and go witht he one that offers the most features that work for you and then go for it. None of the ones out suck so you will get something good no matter what you get. Good luck as it is tough.
#7762
#7765
Originally posted by protc3
yeah but you suck howard.
#7767
The only two chassis out for the TC3 in the states that are actually competitive are the Warpspeed and BMI cars. The IRS is all show and no go (flexes like a noodle) and the hardcore one is HEAVY.
Both the Warpspeed and BMI cars are very good. They both have some similar and many different features. You can pick the one that appeals to you most.
I can tell you close to everything you want to know about the Warpspeed Demon kit.
Randman, yeah I've heard of that happening, but that is not happening with my car. IF it ever takes a tweak in a hit, it'd be a hard hit for one, and i'd be more worried about other components on the car (arms, pins, other bent stuff etc.).
Jason don't forget to scrubb!
#7768
R/C Tech Elite Member
Originally posted by howard hudson
mmm not the case with the warp car randman I know you have seen me drive and I know You have seen me hit some stuff pretty hard but it never goes out of tweak . NOT ONCE. I have checked out the yok SD and it does have a lot of flex in it probably due to the thin graphite that is used . but both my warp cars are 3mm kits and are very stiff. next time we race come over and check them out
#7769
Originally posted by DOTMAN
One of the reasons is because the Tub does tweak or warp from the heat of the motor. Another is weight. The double deck setup is stiffer too. If you want stiffer, you can however add an upper deck to your tub chassis
