TC3 Forum
#7681
WYD: I purchased the ceramic pro bearing kit from Acer, the diff bearings came in it as a bonus. Im sure they sell every bearing they have in stock separately. I would hop on the phone and give them a quick call, tell them what you want, and they will have them to you in a matter of days. Sometimes you can spend hours on this friggen box looking... when all it takes is a call to get what you want in ALOT less time. All this information on the internet, not enough time to look at it!
- Dave
- Dave
#7682
I have mentioned this before... MEK will clean bearings REALLY well... dissolving carpet fibers and rubber deposits. MEK (Methyl Ethyl Ketone) is a BAD chemical. It has severe health risks. But you can goto your local Lowes or Home Depot and purchase a gallon can for under 5$. Use a baby food jar (glass) and some steel screen cut to fit the bottom of the jar. The glass jar doesnt dissolve from the chemical, and the steel screen allows dirt to fall away from the bearings. Anything else is chemically dissolved in hours. All seals, unless stainless steel, should be removed. Rubber gloves should be worn, and MEK needs to be used in a well ventilated area.
- Dave
- Dave
#7683
Tech Legend
Trader Rating: 51 (100%+)
- Dave
- Dave
#7685
Thanks guys, i was looking for the integy one. Im gonna check out local drug stores and such for cheaper jewelry cleaners first though.
Increasing caster in the front: I went to 2 degrees from zero and noticed vastly improved turnin. It also helps center the car a little better down the straights (which is nice with 1 degree toe out up front). I run on a really tight track so its a great improvement.
#7686
steering
Has anyone tried to use diffrent types of steering racks on the TC3. like the NTC3 rack or any home made ideas....I hate the slop in the rack let alone the fact that carpet and everything else gets binded in the rack!!! Basicaly I am looking for a better design
#7687
Originally posted by pballkid21587
ok i put the f block in the rear of my tc3 with a 3-2 rear, i spaced the front block up .3 to make them equal. I did it becuase everyone says to, but what did i gain by doing this?
Blackstock said he used .030 washers under the shock towers, are you referring to that? He also cut .030" off the bumper and an F-0 block to make an F-1 block.
Josh
#7688
Horatio. Greetings from Malta.
Get one of Novak's new external schottly diodes from CLM. It will solve your problem with any type of motor.
Just so you know what I am talking about, look at it fitted to my SD in the attached pic. It the bit that's on the servo.
Regards
Joe from sunny Malta.
Regards
#7689
Hello
Does someone know the new link for the TC3 modification page?
The old link does not work anymore:
http://www.ultimewebtechnologie.net/...ciated_tc3.htm
any helpis highly appreciated!
Lem
Lem
#7690
Regards
Regards
Much appreciated. It's now on order If you weren't so far away, I'd have placed my order through you
Thanks again.
#7692
Re: Hello
http://www.mistercrash.ca/_themes/pa...eering_tc3.htm
You can also go on the Associated website in the personnal links.
Lem
Lem
#7693
Regards
Regards
You can kind of make out what I did in my earlier pic, but I will post another pic later today when I get access to my camera. Just look on top of the gt7 and you can see the diode. (I am editing the post so the pic is in my next post.)
#7694
#7695
Re: Re: Hello
Peace and Happy Racing!!
