Old 01-26-2004, 01:44 PM   #7651
Speedie's Avatar
Originally posted by wyd
When using the Associated lightweight plastic diff halves what size are those diff bearings? Don't want to use those bronze bushings. The bearings from my steel diffs are too thick to work.
We had a long discussion a while ago about this. The reason for the bearings being discontinued was that the diff halves were melting. I cant remember why the bushings were better, it had something to do with the flex of the plastic versus the metal halves or something to that affect. I think you can still find bearings tho but cant remember where. I know not much help but Im old and forgetful.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 01-26-2004, 02:12 PM   #7652
DaveW's Avatar
Sorry guys, just thought i would give ya something to laugh about...
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 01-26-2004, 02:13 PM   #7653
DaveW's Avatar
And something to drool over... man i hope i can get one of these!
- Dave
Old 01-26-2004, 02:17 PM   #7654
Dave....
Just promise me you'll ditch that ugly wing if you get one.
Factory RICE.
Bodido is offline   Reply With Quote
Old 01-26-2004, 02:21 PM   #7655
DaveW's Avatar
Do you know, the dealer actually charges MORE for that batwing?! They need to offer it as a freebie, like Chick-Fil-A offered nuggets years ago to mall shoppers for free before they could charge for them! There are two of em here at the dealer... i wonder if they would notice the difference between my bent A$$ Prelude and the red EVO8?!
- Dave
Old 01-26-2004, 02:24 PM   #7656
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Well it is closer that where I was before. At least I know why I can't find them at this time.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
wyd is online now   Reply With Quote
Old 01-26-2004, 02:28 PM   #7657
DaveW's Avatar
WYD: You can get them from Acer Racing. I have them, and they work well with no meltdowns as long as you pack the area they are in with a diff grease. I did this with the bushings as well. The only thing i noticed was the diffs stayed smooth longer with less rebuilds. No actual difference in handling ability.
- Dave
Old 01-26-2004, 02:46 PM   #7658
wyd
Tech Legend
wyd's Avatar
Thanks Dave. I will check out Acer. I was looking for a little longer lasting smooth diff setup.
Old 01-26-2004, 02:48 PM   #7659
wyd
Tech Legend
wyd's Avatar
- Dave
Do you know the size of the bearing or does Acer just say plastic diff half bearing.
Old 01-26-2004, 03:04 PM   #7660
Crashmaster's Avatar
Default Re: Shimming
Originally posted by Crashmaster
Hi guys, my first ever post !! So far I'm on page 130 of the thread so still got more to read!!
I was wondering if you could help me with the shimming of my transmission. I have read that you don't run with the outdrive shim, but I am running with the metal diffs, so I wasn't too sure if the same applied to the metal as the plastic diffs. Also could you reccomend the number of shims on the front and rear input shafts, as again I'm not to sure if this will differ.
Cheers
Crashmaster
P.S. Great thread so far
Anyone Help?? Basically trying to free up the drive train as much as possible.
Thanks again
Crashmaster
Crashmaster is offline   Reply With Quote
Old 01-26-2004, 04:11 PM   #7661
wyd
Tech Legend
wyd's Avatar
Clean all the bearings and then check the transmission cases for binding. As you tighten the cases it can pinch the bearings and cause binding. I used really small spaces between the cases and now my tranny spins super smooth and free.
Old 01-26-2004, 05:01 PM   #7662
Roger's Avatar
thx, im gonna have to check mine
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 01-26-2004, 06:25 PM   #7663
chubbsrugby's Avatar
Angry binding
I'll tell you right now that a file and dremel job on those trans cases will work wonders!!
chubbsrugby is offline   Reply With Quote
Old 01-26-2004, 06:40 PM   #7664
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
Default binding in tranny case
I used a dremel sanding bit #407 to sand the case were the outdrive bearings sit . The bit is almost the exact size of the bearing + it doesnt remove alot so its hard to overdo it.
Sal Amato is offline   Reply With Quote
Old 01-26-2004, 06:44 PM   #7665
Angry binding
Also by loose screws in the trans cases this could alter the shock towers by making them "wiggle" because of the loose screws. Un less you used spacers...but then your letting dirt in to the trannys....Also going nuts with the sanding will create "wobble" in the diffs themselves..there is a fine ling between loose and to loose.
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
