Old 01-21-2004, 09:06 PM   #7591
Neil's Avatar
Send a message via MSN to Neil
Sorry I'm a little off topic Can any of you guys help me out with a good setup? I'm running rubber tires on a ultra smooth carpet track. I'd like the car to be close to neutral but with a little oversteer. I have looked at setup sheets on the ae site but I don't know what is good.
Neil is offline   Reply With Quote
Old 01-21-2004, 09:14 PM   #7592
Start with Barry Baker's setup for the US Touring Car Champs at Trackside Hobbies/Milwaulkee. You probably won't have to make any changes to it. It works really well.
LJae is offline   Reply With Quote
Old 01-22-2004, 08:12 AM   #7593
hyperformance's Avatar
Proficar, TFB an adult book store you can't say the full track name in public, it's forbidden
GoFaster, get the BRP hingepins, strong + inexpensive
MikeWebb, i like the motor cut out and heatsink mod, but what are the holes under the rear hingepins for?
hyperformance is offline   Reply With Quote
Old 01-22-2004, 08:22 AM   #7594
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Last year I caught a piece of debris and it screwed up my Rear Tranny and my motor and speed controller. I cut the holes there so that any objects that fall in there near the drive axles would hopefully fall through.
The Rock I caught in it last year seized up the drive train and smoked my motor and speed controller.
Mike
mike_Webb is offline   Reply With Quote
Old 01-22-2004, 08:32 AM   #7595
mike, i see, good plan. thanks
Old 01-22-2004, 01:53 PM   #7596
DaveW's Avatar
BIGDON18: Here are a few more pics of the chassis ALMOST finished. A little more finish prep and battery tape slots, ill be content. I didnt go in as deep as some i have seen, im thinking i can make up the weight difference elsewhere, without adding weight for the finished product. I just couldnt see chewing all that bracing away, so i took away as much as i could that still allowed the center bracing at the front and the rear of the "battery box" to be intact, and let the battery in towards the centerline within this guideline. My sheet graphite hasnt come in, so i am taking this into consideration for flex control. Anyways, here they are... sorry it took so long.
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 01-22-2004, 01:54 PM   #7597
DaveW's Avatar
And another from a different angle...
Old 01-22-2004, 01:56 PM   #7598
DaveW's Avatar
And another angle...
Old 01-22-2004, 08:07 PM   #7599
Trader Rating: 70 (100%+)
davew,
man you have put some tlc in that chassis ,, and you did it all with dremel you say? the pics have really help me out alot to understand this modifieding of the chassis,, and yes agree with you i wouldnt take it anymore closer to the center. like they say dave good things come to those that wait,, man did you come threw looks great man. hope she runs for as goos as she looks.
me myself tonight ,, will i got my new bearings in for my used tc3 i got and replace them ,, put all my electrics in ,, decided to take out the novak and put the lrp quantum in,, gives me more room to work with ,i also add me a small fan to blow on the motor brush hood area from the side just a radio shack fan wired in on the speedo when i go the fan goes to,, just something playing around with , it happens reading all this mod stuff,, might hit the section under the motor tomorrow , just getting this ready to start my learning curve in touring cars, this saturday on the carpet at FCCT ,, but to help the transtion i will have a good friend of mine Davepull helping me out so it should be fun. i have raced oval since 1989 now i gonia try the turning right some along with my oval racing.
like to also say thanks again to all the other guys that have posted picks on things that has help me out alot ,,
BIGDN
BIGDON18 is offline   Reply With Quote
Old 01-22-2004, 10:51 PM   #7600
tc3 racer sc's Avatar
Default mike blackstock plse post ur set up on ae
mike ru going to post ur setup of the novak race on on a.e web site undersetups set so i can down load it thxs reggie
tc3 racer sc is offline   Reply With Quote
Old 01-23-2004, 04:28 AM   #7601
OleC's Avatar
Default Baker setup
@Ljae: Is that the one from 1/25-27-2002 where he finished 2nd?
JQ The Car Black Edition - O.S. - BUKU - AKA - Byron - Sanwa - Sav÷x
No sponsors. I drive what I like, and so should you
OleC is offline   Reply With Quote
Old 01-23-2004, 06:31 AM   #7602
Default TC3 Racer...
I am pretty sure they ( ASSOCIATED ) are going to do it pretty soon.. If you look up some on this thread i posted 99% of it there....
Mike Blackstock
Mike Blackstock is offline   Reply With Quote
Old 01-23-2004, 06:39 AM   #7603
Mike B.
Enjoyed watching you at Trackside...Great Run
I do have a question however. Most of the time I run stock (foams on carpet), do you feel that in general the car is faster in stock with a stiffer setup as compared to the setups you guys run in Mod? It would seem to me the mod cars need more side and forward bite whereas a car running stock would benefit from stiffer settings that allows the car to be more "free" in the corners.
Thanks for your time!!
Ozwald Bates is offline   Reply With Quote
Old 01-23-2004, 06:49 AM   #7604
Actually i think the setup from mod to stock is close, There are a few changes . I know running 19t at trackside made me realize that the car was VERY HARD to drive in 19t but in mod the car was very stable and easy to drive. In 19t the car over rotated most of the time so i think if i just ran 19t i would have made the car easier to drive. Sometimes stiffer is not faster.. Matter of fact we are going softer and softer . I think stock would be close to some of the setups we ran 1 or 2 yrs ago.. Purple springs all around .. 70-50 wt oil .. small front bar or no front bar.. F block in the rear with a 3+2 block .. 4 degree's caster a f+0 in the front ..Some of those things i would try...
Also i know this seems weird.. But alot of times stiffer gives you more traction....
Let me know ...
Mike
Originally posted by Ozwald Bates
Mike B.
Old 01-23-2004, 07:43 AM   #7605
lem2's Avatar
Default DaveW
May I ask again what brand are those Prop Shaft you are using, I know they are Ti. Can you give a link Also? Thanks! Lem
lem2 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
