Old 01-20-2004, 07:22 PM   #7561
Arun's Avatar
I was jealous of Dave's pictures, so I threw the digicam on the ground and it started working again. Here is the upper deck I made for my tc3:
It is the only one I have ever seen that does not limit the access to the diff halves (due to my integrating it into the corner braces.) It is also still very low on the chassis, less than 4 mm above the shaft. It is very functional at making the chassis extremely stiff, especially after moving the battery in.
You can also see my other mods: serpent shocks, custom battery brace, and custom motor clamp.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 01-20-2004, 07:27 PM   #7562
Arun's Avatar
I was going to either make a torque rod connecting the upper deck to the rear diff case or integrate the deck into the corner braces, but I decided not to do either because the main chassis already has so many ridges underneath that it would be pointless to hassle with.
Here's another pic. In this one, you can see how low the deck is and a little bit of my main chassis work.
Old 01-20-2004, 07:56 PM   #7563
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Originally posted by Bubblestc3
The TRF shocks DO fit, but you have to use the appropriate hardware to mount them to the chassis.
Setup for Asphalt?
Yeah, unless I decide to race on a track set up on concrete! Yes I mean Asphalt but Im hoping to find a setup that'll work on Asphalt and/or carpet
trackdesigner71 is offline   Reply With Quote
Old 01-20-2004, 09:03 PM   #7564
Trader Rating: 70 (100%+)
Proficar403
thats a nice setup you got there,, really like the upper deck,, totally sweet. i notice your from Ga also ,, where all do race at ,, i mostly go to fla to race.
mike web,,
cool ideal i will us that one on mine,, car looks really nice and clean.
do any of yall that are hard wiring have any picks of your cars with the batteries in the that has this mod done to it, like to see yalls methods of running the wires and avoiding the shaft and brace with the battery post,,
man , yall make me want to get a sheet of graphite and start fabing some stuff up,,,, really nice cars
BIGDON
BIGDON18 is offline   Reply With Quote
Old 01-20-2004, 09:05 PM   #7565
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: SPEEDO
Originally posted by lem2
I use the 2 hole pistons for the front and rear, same oil, and springs. You may want to try 3 hole on the rear or a lighter oil, really depends on the track.
Basically, its like, switching the shock body, same oil, pistons and springs.
Peace and happy racing.
Thanks, I'll definately have to look into it.
Speedo is offline   Reply With Quote
Old 01-20-2004, 09:17 PM   #7566
squarehead's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Default My TC3
Well it took me a few weeks to get everything the way I wanted it, but it is finally done. I'll be dropping it on a track this Saturday if everything goes well. I'm hoping my old radio can come through for me for a little while longer.
Thought you'd dig some pics...
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 01-20-2004, 10:18 PM   #7567
look really good, nice paint also clean ,,,, nice.
BIGDON
Old 01-21-2004, 01:57 AM   #7568
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
DaveW: yup, ive gone from tc3 to xxxs to tc3 to xxxs and now back to TC3. im looking forward to "round 3" with the TC3. i'll let you know how things go. im defenitly gonna be in this topic more often now so i will surely be sharing any info i can .... if they're actually worth anything! haha
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 01-21-2004, 06:46 AM   #7569
Trader Rating: 37 (100%+)
apex.
looks good!
see you at the track on sat.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-21-2004, 06:57 AM   #7570
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
ApexSpeed very nice job. I really like neat wiring and electronics layouts. I think it takes me more time to put in my electronics than to build the car. Pretty trick looking paint job as well.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-21-2004, 07:21 AM   #7571
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Mine is the same as Apex but my wires are shorter and the battery tabs are next to the shaft. I will take a picture of it tonight and post it.
mike_Webb is offline   Reply With Quote
Old 01-21-2004, 07:31 AM   #7572
wyd
Tech Legend
wyd's Avatar
Hey Mike, That chassis you have is that one midified by BillySpence? I have one he done and it looks identical to yours, same foam piece and same black lexan piece by the drive shaft. I really like mine and it looks great. Don't run to bad either.
Old 01-21-2004, 07:35 AM   #7573
mike_Webb's Avatar
I would never run something Silly Billy made!!!!!!!!!!!!
Actually I copied his. I enlarged my motor area underneath the Motor and I don't have a fan which he has for his. The foam is the same stuff he buys. I also copied his lexan cover....before I was using cardboard.
Mike
Old 01-21-2004, 07:40 AM   #7574
wyd
Tech Legend
wyd's Avatar
Well Mike you did a great job. I'm kinda new to the TC3 but I saw the chassis Billy did and he had some for sale and my used TC3 needed a nicer one so I bought it. The car worked very well with it. I just wasn't patient enough to do it myself and I thought his price with including the chassis was resonable enough for me.
You do race at The Track? I think I'm planning to make it down in 2 weeks to run and hang out with a few of the guys I know down their. Plus I oh Teach a visit since he came to RCO. He wants some revenge for the beating I gave him so I'm a man of my words and told Tom I would be down for my carpet beating very soon. I hate taking carpet beatings.
Old 01-21-2004, 08:16 AM   #7575
mike_Webb's Avatar
2 weeks is snowbirds .
Everyone beats Teach . Maybe by then he will have bought his $400 Pro4 hahahahahaha
He was doing really well at the begining of the season but I have not seen him lately. Come on down to The Track. It is a great place to race and the Competition is very good.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
