Old 01-20-2004, 01:26 PM   #7546
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
could we get blackstocks setup from the novak race
Kave is offline   Reply With Quote
Old 01-20-2004, 01:48 PM   #7547
Here is my setup from the novak race....
FRont end... 70 #3 Piston's . Purple spring.. f block -1 ant dive in the car .. 4 degree's caster.. .055 front sway bar.. Rear shock tower on the front, shocks mounted in the body mount hole and the inside on the arm.. droop was @ 5, 1 deg camber 4.5 mm ride height .. Camber link long and up
I also space my rack with a .080 fiber glass and the silver ball for a ackerman change from stock..
Rear End.. I ran 50 #3 piston's . Purple spring , Shock Mounted in the middle hole and outside of arm . F block instead of the R block for lower pin's .. 3+2 Rear toe block with losi 0's Camber link long and down.. no rear sway. Ride Height 5 MM .. 1.5 deg camber
Batteries where forward and wheel base was short.
I ran the protoform Alpha 2.0
I think that is all.. Hope this helps...
oops almost forgot tires were 2.27 size and double pink / Orange in the front and Double pink Jaco's in the rear...
Mike Blackstock
Mike Blackstock is offline   Reply With Quote
Old 01-20-2004, 01:56 PM   #7548
Trader Rating: 70 (100%+)
Davew,
keep the pics coming and i will study them real closely,, at first i thought the guy might have made the mod too close to the center , the bars are really close to the shaft ,, i had to bend them more wrap around closer over the cells to just barely mis the saft,, with the bent straight up word in a normal L shape they was hitting the shaft, with deans bars. but if you would when you can a pic with car in race ready battery setup would be great ,, this is my second tc3 and kinda want to build it up for the daytona race in march,, and leave my other one set up for carpet.
good luck at the birds ,, wish i could be there this year but do to several reason i not goin to be able this year.
BIGDON
BIGDON18 is online now   Reply With Quote
Old 01-20-2004, 03:44 PM   #7549
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
DaveW your chassis work looks nice. I bought when done for me and it works great. I think mine was milled 7mm closer to the driveshaft. Batteries fit and are close to the driveshaft but not touching. I have a nice thick piece of foam going along the outside of the chassis so my packs fit in nice and tight and has a really thin piece of lexan donw the chassis on the shaft side. If you would like a pic of it I can take some and then email them to you.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-20-2004, 04:30 PM   #7550
mistercrash's Avatar
R/C Tech Charter Subscriber
Originally posted by Penguin r/c
Currently we do not however we hope to get some on our website shortly under the Sneak Peeks secion.
Brion Sohn
President
Penguin r/c
I'm a big fan of your products. I can't wait to see pics of this chassis on your website.
DaveW
I too cannot believe that you don't have a drillpress Get one, you'll never regret it
No brain, no headaches.
mistercrash is offline   Reply With Quote
Old 01-20-2004, 04:34 PM   #7551
wyd,
would you send me some pics also,, with battery in and out of the chassis, bigdon@wayxcable.com ,,
guys thanks for all the help ,, i have been crash coursing my self on all the tips and tricks with the tc3.
dave pull ,, man he has been a ton of help ,, and iam goin to bug him to death at the carpet track this weekend
BIGDN
Old 01-20-2004, 05:17 PM   #7552
tc3rookie: you are using a short wheelbase aren't you? because that will give a tighter turning circle
Rory is offline   Reply With Quote
Old 01-20-2004, 05:23 PM   #7553
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Default Chassis Mod
Here is a piture of mine. Batteries are right up against the shaft but not touching.
mike_Webb is offline   Reply With Quote
Old 01-20-2004, 05:43 PM   #7554
mark david's Avatar
Default Message...
Hi guys!! Just trade my losi xxxs for a Factory Team TC3. Well all I can say it handles great and it suites my driving.
Heads Up!!!
mark david is offline   Reply With Quote
Old 01-20-2004, 06:12 PM   #7555
Default Re: Chassis Mod
Hey, Mike. How's it going? Quick question. What is that you used to shield the batteries from the center webbing?
DOTMAN is offline   Reply With Quote
Old 01-20-2004, 06:17 PM   #7556
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Originally posted by trackdesigner71
So I take it the new Tamiya Flourine shocks fit the TC3? Also, whats a good standard setup for stock racing?
My apologies. I didnt specify what I was asking for. Im lookin for a good stock rubber setup that can work indoors and outdoors. Also, do the new Tamiya shocks fit the TC3 or just the Evo 3
trackdesigner71 is offline   Reply With Quote
Old 01-20-2004, 06:33 PM   #7557
mike_Webb's Avatar
I bought a Losi Body for my car and it had a lot of spare lexan so I cut it out and laid it in the chassis and then cut it so that it would not stick above the center webing. It is secured to the Webing by Double Sided Servo Tape.
Old 01-20-2004, 06:40 PM   #7558
Is Lexan a good insulator?
Old 01-20-2004, 07:03 PM   #7559
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
The TRF shocks DO fit, but you have to use the appropriate hardware to mount them to the chassis.
Setup for Asphalt?
Bubblestc3 is offline   Reply With Quote
Old 01-20-2004, 07:09 PM   #7560
mike_Webb's Avatar
The lexan does its job. I hav enot had to replace it and it keeps the battery from touching the Shaft
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
