Old 01-16-2004, 09:01 AM   #7486
Originally posted by Rory
Square - www.square-rc.com/parts24.htm
Sorry Rory, bad link! Can you try again?
Rowdy Racer is offline   Reply With Quote
Old 01-16-2004, 10:55 PM   #7487
lee82gx's Avatar
www.rc-square.com
lee82gx is offline   Reply With Quote
Old 01-17-2004, 05:02 AM   #7488
vtl1180ny's Avatar
R/C Tech Charter Subscriber
PrecisionRC has them...
vtl1180ny is offline   Reply With Quote
Old 01-17-2004, 06:09 AM   #7489
lem2's Avatar
Default Shocks
Tested my Car with the Tamiya Flourine Coated shocks and it feels different in a good way!!!!
You could try it out!
lem2 is offline   Reply With Quote
Old 01-17-2004, 11:58 AM   #7490
Moderator
Speedo's Avatar
lem 2, what felt different about your car? Did you change oil, spring, or piston settings when you changed to Tamiya shocks?
I had a 414M for about a week, and when I built the shocks they were the best I'd ever seen.
Speedo is offline   Reply With Quote
Old 01-17-2004, 08:19 PM   #7491
Thanks Everyone!
Old 01-18-2004, 03:06 PM   #7492
vtl1180ny's Avatar
Ok... First weekend runnng the TC3 and I just couldn't get a good setup... Very tight carpet track... Started out in the morning traction rolling played around with the setup and it just got worse... Running white/purple springs... 40/35 foams... Car was very twitchy... Been running the Yok and doing ok... But waiting for a part if I broke something was getting out of hand...
Old 01-18-2004, 03:24 PM   #7493
Moderator
Speedo's Avatar
Do you remember the Dumas front hubs that were around last year made of delrin? They had an extra hole behind the standard one for the ballstud, and using this made the car much smoother. Most people at my track who run a TC3 including myself have made one using a piece of fiberglass. You just need a couple screws and drill a hole in the standard part. Doing this smooths the car out, it might be something you could try. You do have to shorten the tie rods and drill into the ballcups slightly for it to work, but it's worth it.
I'll have my camera back tonight so I'll take a picture and post it if you're interested.
Old 01-18-2004, 03:54 PM   #7494
vtl1180ny's Avatar
That's definitely an interesting mod... I miss the adjustability of my Yok, but I can't keep tryng to have at least one of everything that can possibly break on hand...
Old 01-18-2004, 05:48 PM   #7495
Moderator
Speedo's Avatar
Some pictures if you're interested...
Old 01-18-2004, 05:49 PM   #7496
Moderator
Speedo's Avatar
from the top
Old 01-18-2004, 05:50 PM   #7497
Moderator
Speedo's Avatar
from the bottom
Old 01-18-2004, 06:21 PM   #7498
JJ187RC's Avatar
Default TC3 Carpet Setup
Anyone have a good starting point on a carpet setup fpr a TC3?
JJ187RC is offline   Reply With Quote
Old 01-18-2004, 06:34 PM   #7499
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Mike D.
Quick question that I should have asked you last night at the Track....
When you told me about the -2degree of kickup in the front of the car where you talking about the Front arms leaning Forward? You said you had to cut material from the f-2 or F-0 block so I am wondering if I run the F-0 block and put a .030 Washer under the F block to make the arms lean forward? Is this Correct and was this what you were talking about?
Also when you run the F block in the Rear do you have to run spacers under the F block when using the R+3+2 or R+2+2 blocks? Or do you just run a washer under the F block when you use the R+3-0 or R+2-0?
Mike Webb
mike_Webb is offline   Reply With Quote
Old 01-18-2004, 06:36 PM   #7500
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
who here has tried using the losi rear hubs in the tc3? what exactly is being achieved by doing so? i know cyrul used to do this so he could set toe in at the hubs rather than using the arm mounts/holders to get toe. but he also had to eliminate the toe angles at the arms pivots by using an inner F block in the rear. if i still use the arm mounts to achieve toe angle and simply switch to 0-degree losi rear hubs, what changes in handling can i expect? and what ball stud should i use on the hubs, a silver or black stud? thanks in advance.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
