Old 01-15-2004, 07:33 AM   #7471
hyperformance's Avatar
i'd like some more info on the yok shock caps, no one here is running them. you guys using the bladders, caps & taking out the foam or what?
dave, a thread like this is invaluable, i found this one when it was on 206 pages, i started at #1..... reading. it took me over a week to catch up, but i've read every page
proficar, we practiced with you friday night for that tri-state event. i was running the blue G350gt body. saturday my car spent a lot of time in the crowd as i adjusted to the "road doom" corner dots. yeah, i said doom not dome
hyperformance is offline   Reply With Quote
Old 01-15-2004, 08:12 AM   #7472
Horatio's Avatar
Talking
Originally posted by mike_Webb
My friend filled his shocks with WD40. After about 3-4 runs the shocks would be empty. Man...those were the days.!!!!
Horatio is offline   Reply With Quote
Old 01-15-2004, 08:22 AM   #7473
Horatio's Avatar
DaveW:
The Avante? That's the buggy that had alloy everything and multi link rose-jointed suspension! I remember it.
My mate had one when I was a teenager, but he kept breaking it cos he couldn't drive
I couldn't afford to buy it off him either. As far as I know, he still has it in his attic - must be worth something now!!
Suntan lotion - no way!!!
I once used EP 80 gearbox oil in my shocks. Needless to say all the O-rings dissolved and my shocks were soon bone dry
Old 01-15-2004, 09:50 AM   #7474
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
DaveW, I assume you've tried Penguin? I got a 3mm thick sheet from them when I made my top deck for the older Yokomo.
Speedo is offline   Reply With Quote
Old 01-15-2004, 10:09 AM   #7475
vtl1180ny's Avatar
People still use suntan lotion, softenes the rubber and foam up nicely...
vtl1180ny is offline   Reply With Quote
Old 01-15-2004, 11:38 AM   #7476
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default Diff setup for carpet
Hi all,
I had some difficulty last night setting up my car and I did find the diffs were set way wrong. Some help would be appreciated since I adjusted to full tight then backed off 1/2 turn per the manual and it was still rock tight.
First how should the diff be setup for carpet racing, Front loose/rear tight or viseversa or what?
What is the best way to tell when the above setup is correct? How does it feel?
rinkrat99 is offline   Reply With Quote
Old 01-15-2004, 01:06 PM   #7477
davepull's Avatar
Originally posted by DaveW
PROFICAR403: If only i could drive eh?? Did you ever get your carbon fiber sheet?? Im strugglin to find some 3mm sheet to make a center brace! How thick was yours? Man i need a hobbyshop here that stocks more than planes...
- Dave [/B]
Hey Dave try this site they sell sheets of graphite http://www.mcmaster.com/
davepull is offline   Reply With Quote
Old 01-15-2004, 02:10 PM   #7478
DaveW's Avatar
DAVEPULL: HOLY CRAP MAN!! That site has all kindsa goodies on it!! YES YES!!
SPEEDO: Penguin R/C? Didnt they make a chassis for the TC3 a few years ago? Or am i thinking of someone else?
HORATIO: We need to visit this mate of yours with that Avante in his attic. Surely i have something of value he could be interested in... i would introduce him to my ex-wife, but if she was of no use to me, then i am sure he wouldnt want her either. The Avante was a sweet car, it was supposedly Tamiyas competition for the Yokomo dogfighter that was out at the time. We see what happened with that, didnt we??
Guys, thanks so much for your responses on the fiber! Ive got to get a top brace made!!
RINKRAT: Did you compress the springs that go in the diffs before assembly?
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 01-15-2004, 03:43 PM   #7479
Moderator
Speedo's Avatar
They didn't make a chassis, but they did make some chassis braces.
They sell 9 x 7 inch sheets from 1.5-3mm thick c/f.
http://www.penguinrc.com/products/ot...iteplate.shtml
Josh
Old 01-15-2004, 06:17 PM   #7480
davepull's Avatar
yah mcmaster carr has alot of good stuff look at the lathe bits. there like 4 bucks.
i love that site and order alot of stuff from it also i get alot of stuff off of fastener-express.com holy wheel nuts. they are the same as the trinity ones
Old 01-15-2004, 06:53 PM   #7481
Who makes some carbon fiber shock towers for the TC3?
Rowdy Racer is offline   Reply With Quote
Old 01-15-2004, 07:22 PM   #7482
Arun's Avatar
- Dave
Dave,
I got my sheet in FINALLY (After it got lost in the mail!!!!!!!!). I got it from penguinrc.com. The last time I ordered it I got it very quick, like 2 days, but this time they forgot to put my Apt. # so I did not get it until a few days ago.
My upper deck turned out great! I made it yesterday. It looks to be very functional. I made it with 2.5mm graphite. I'll try to post some pics tomorrow, so check back here tomorrow night .
I have a lot to do tomorrow. First, I am going to mill a chassis for someone, then, I am going to rebuild my tc3 completely.
I am going to be doing a lot of testing this weekend. I have yet to mess with putting the rear shock tower on the front, and I want to experiment with different caster and rear toe settings.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 01-15-2004, 08:01 PM   #7483
Square - www.square-rc.com/parts24.htm
Rory is offline   Reply With Quote
Old 01-16-2004, 01:44 AM   #7484
Horatio's Avatar
Good luck guys with your carbon fibre sheet etc.
DaveW:
I'll let my mate know about your offer. Knowing him, he'd probably accept
Old 01-16-2004, 08:21 AM   #7485
davepull, you let the cat out of the bag on McMasterCarr.com i get lathe bits from them & sell for $10 at the track anybody tried the diamond bits they sell?
proficar, try 4degrees caster and 0 anti-dive for foams & reg diff on carpet. i haven't done the rear shock tower yet either but will try soon. also with foams you can run 1degree rear toe. use the "F" block in rear with the "R 2+2" or "R 2+0". some guys use the losi uprights to run 0degrees
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
