Old 01-07-2004, 04:19 PM   #7366
BIGDON18
Most onroad racers (that i know) have the antenna going out the body through the antenna tube.(best reception). U can mount the antenna inside the car by using scrap lexan stip about .5 inch wide and 3-4 inches tall with holes cut out. Run the antenna through the holes and tape to somewhere on the chassis.
I have tried this before but i get glitching so i switched back to the tube.
Dont have a pic but can get one soon of both setups, if u need it
MarchTC3 is offline   Reply With Quote
Old 01-08-2004, 10:19 AM   #7367
DaveW's Avatar
Rayhuang: No worries man.
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 01-08-2004, 12:10 PM   #7368
J_Longbrake's Avatar
Trader Rating: 20 (100%+)
Does anyone know were to find the layout for the NTC3 rack on the tub chassis? I saw it on here once but haven't been able to find it? Thanks, Jason.
J_Longbrake is offline   Reply With Quote
Old 01-08-2004, 01:06 PM   #7369
mistercrash's Avatar
R/C Tech Charter Subscriber
http://www.mistercrash.ca/_themes/pa...eering_tc3.htm
No brain, no headaches.
mistercrash is offline   Reply With Quote
Old 01-08-2004, 04:43 PM   #7370
Arun's Avatar
DaveW, are you going to run the plastic cvds on your car this year?
http://nexusracing.com
Arun is offline   Reply With Quote
Old 01-08-2004, 05:47 PM   #7371
hyperformance's Avatar
Default bearing spacer
anybody ever leave the bearing spacer (part# 3965) out of the uprights? i believe the uprights have stops for the bearings, makes me wonder if the spacer is really needed.
hyperformance is offline   Reply With Quote
Old 01-08-2004, 05:52 PM   #7372
I think the spacer may provide a little more support to the bearing in the event of a crash, but I don't use them and I've never had a problem.
DOTMAN is offline   Reply With Quote
Old 01-08-2004, 05:54 PM   #7373
thats what i figured after a close look. i just got some new bearings (trying to find some more speed) and don't want the spacer to interfer with the bearings or the spinning axle.
Old 01-08-2004, 05:58 PM   #7374
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
Smile new guy, from RCZ forums.
Hi Guys! This would be post number 1 for me at these forums. Seemed like a very active tc3 thread so Ive decided to join. I bought my tc3 used, it was a old school tc3 team with no set screw adjustment for droop. It runs ok but does anyone have any tips on freeing up the drivetrain and making it smoother?(without $100 bearings) Ive also noticed that the camber links dont seem to be the same length when i set the camber equally. Would it be just my eyes?
Ive been reading the previous pages (not all ) but when you refer to 100tooth spur gears and using them with 25tooth pinions, are they 48p or 64p? What would my current 19t and 25t pinions / 72t spur 48p gear ratio convert to in 64p?
I plan to run in the stock class...I have a basic duratrax esc, with a monster stock pro and an mx-3 system. Im happy with it but I'll probably move to brushless in the future.
Any other suggestions and tips/hints appreciated. Thanks for your help guys!
R3VoLuTiOn is online now   Reply With Quote
Old 01-08-2004, 06:04 PM   #7375
AMGRacer's Avatar
Hi guys,
I am too a brand new TC3 owner, just picked up my FT TC3 today. Anybody have any tips when it comes to building the car?
Also I run on a medium/large asphalt track with foam tires. Any optional parts which you think will be useful for me on such a track. I am thinking oneway for sure.
Any other general tips appreciated.
AMGRacer is offline   Reply With Quote
Old 01-08-2004, 07:30 PM   #7376
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
whats the part number on the TC3 blue screw set? Id like to change the screws in the car
trackdesigner71 is offline   Reply With Quote
Old 01-08-2004, 07:58 PM   #7377
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Trackdesigner71 - #3935 Factory TeamTC3 Aluminum Screw Kit set $13.00 http://www.rc10.com/shusting/Catalog.../screw_loc.htm
AMGRacer - just make sure you pick up an extra rear shock tower for the front.
Building tips - you want tomake sure all of the outer plastic from the molding it gone(duh), when you put the front (suspension: steering blocks and c-hubs) make sure you dont screw the upper ball cup into the steering block to tightly or it will later strip, just snug and check after each run or two, work on the drivetrain, the big thing here is dont worry about making it spin for 340029271818494028 seconds like most people think it needs to spin for. All you need is at least 7 seconds or so of spinning and you'll be fine. Now, the best method I have found is take the FT kit bearings, leave both seals on, and spray with motor cleaner, let it sit a bit and you will see white liquid come out(grease) then wipe off and cover the seal with a thin oil (I use Tribo). It will soak into the seals and all the way through the bearing. Spin the bearings several times to get them lubricated (That is all for the bearings). Next, move on to working all of the areas that the drivetrain bearings sit in (excluding the outer suspension). Take a dremel and lightly work on the places where the bearings are smashed together by the diff cases, work on that until you can place the bearing in its place with out it looking to be snug. Also, make sure you work on the shaft support where the spur gear is located (very valuble).
About the bearings, dont worry about taking one seal out and all of that buisness, b/c I have messed with that, and for club racing, it is useless, and you will just find yourself replacing bearings, good bearings at that, because they are gritty from all of the $!!# that got in them.
=MisFitz= NuKe is offline   Reply With Quote
Old 01-08-2004, 08:28 PM   #7378
AMGRacer's Avatar
Ok great stuff! I do have a question about your advice, what is the extra rear shock tower for the front do?
Old 01-08-2004, 08:41 PM   #7379
It is basically widening the top of the tower compared to the front tower, and it is lowering it. For asphalt and rubber tires, most run the rear shock tower with the blue springs, but if you are going to be running foam, you may want to leave the regular tower on with a stiffer spring set-up than blue and silver.
Old 01-08-2004, 08:41 PM   #7380
ya, if ya need anything else, just post away
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
