Like Tree4Likes
Old 01-06-2004, 04:16 PM   #7351
JohnB's Avatar
R/C Tech Charter Subscriber
Default Editable TC3 setup sheet
Does anyone know of a editable .pdf setup sheet on the net? I've been searching and can't seem to locate one.
JohnB is offline   Reply With Quote
Old 01-06-2004, 04:28 PM   #7352
Default Re: Editable TC3 setup sheet
http://www.msra-racing.com/features/setupsheets.htm
try there for that editable setup sheet.
can someone give a rubber tire on ozite carpet setup to get me going in the right direction? thanks
LJae is offline   Reply With Quote
Old 01-06-2004, 04:47 PM   #7353
Trader Rating: 37 (100%+)
LJae.
try out b.bakers novak set-up at trackside for a start....overall it's a really good place to start with then you can fine tune it to your driving style.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-06-2004, 05:54 PM   #7354
JoshR 85's Avatar
HeY hEy!!!
Hey Barry Baker was running the takeoff 27's (pre-glued) and i still run the take offs when i don't race foam.
JoshR 85 is offline   Reply With Quote
Old 01-06-2004, 06:01 PM   #7355
that race is a control tire race so everyone was on CS27s.
Old 01-06-2004, 06:36 PM   #7356
JasonC's Avatar
Trader Rating: 120 (100%+)
any one know the weight of a stock tc3 ( chassie only )
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 01-06-2004, 07:04 PM   #7357
JohnB's Avatar
Default Re: Re: Editable TC3 setup sheet
That's it, thanks a lot
Old 01-06-2004, 07:19 PM   #7358
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Nexus, FYI, that setup was for the 2002 Novak race in which it was open tire, and he ran sorex 28's.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-06-2004, 07:21 PM   #7359
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Originally posted by mike_Webb
Trackdesigner-
Go to the AE Website and download the instruction manual....it shows the car perfectly and how it gets strapped into the car.
Don't you have a TC3? You said about 2 months ago that you did???
Yes I do. Im hopin to put some parts into it. You wouldnt happen to have any extra stuff you could part with do ya?
trackdesigner71 is offline   Reply With Quote
Old 01-07-2004, 05:40 AM   #7360
Trader Rating: 70 (100%+)
Hi,
can some of you guys post a pic how yall are mounting and installing your reciever antenas inside the body,,, when i race oval cars i have always done that ,, but like to see how yall are doing yours to get a good ideal how they should be in a touring car. thanks for any help in advance .
BIGDON
BIGDON18 is offline   Reply With Quote
Old 01-07-2004, 06:48 AM   #7361
rayhuang's Avatar
DaveW-just say your post on my diff problem-Thanks for the great input.
Ray
Old 01-07-2004, 11:42 AM   #7362
Hatebreed is offline   Reply With Quote
Old 01-07-2004, 11:44 AM   #7363
Check this adress:
http://bluestreek.mine.nu/downloads/setupsheets/tc3.pdf
Old 01-07-2004, 12:38 PM   #7364
Originally posted by stormperson
Losi blocks...
Losi and AE steering blocks do not have the same geometry and there is nothing you can do to match it, its just different ackerman. Its a little more agressive I have found, however they are defently more durable. And I normally run losi 6 degree castor blocks, F-0 front block, and losi steering knuckles. And I run losi rear hubs, since they are alot more adjustble and more durable (which is generally true for all losi parts, lol).
Now for my question! lol...
Does anyone know if there is a shock tower out there that is more adjustable? Like the Ratzas losi one or an Xray one with more shock and camber link options? thanks!
I also use the losi 6 degree blocks and knuckles but do you need to add spacers on the steering rack ball studs? Also do you put any spacers underneath the ball studs on the steering knuckles to compensate for bump steer?
slow is offline   Reply With Quote
Old 01-07-2004, 03:04 PM   #7365
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Does the losi tower have the same mounting points? And I dont think josh actually ran the losi tower, he just used it to re-enforce the stock one, or thats what I heard last, lol.
I remember a few different styles for the Losi tower on the rear of the TC3. When at the Ko GP(at SoCal) I thought I saw a standard front shock tower with a Losi rear bolted to it. In some other pic's, there was a NTC3 shocktower with the Losi tower bolted to it. Basically the Losi tower widens the rear body posts and gives you a few stiffer shock mounting locations. I remember Josh saying that he would rather watch the chassis lean, rather than the body lean through the corners.
Bubblestc3 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
