Old 01-05-2004, 03:39 PM   #7336
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Ok, I guess my first question wasnt all that clear (and my sincerext apologies for that). I am curious how exactly you secure the motor to the chassis. I dont know if the motor screws go on the end of the motor with the pinion or go somewhere else.
trackdesigner71 is offline   Reply With Quote
Old 01-05-2004, 04:16 PM   #7337
Default Stock Motor Ratio
Anyone have the ratio to run with a monstor stock in the TC3. I am running a 72 tooth spur.
Need to know pinion and tire diameter. Also need to know the spring/brush setup for the tc3 with a monstor stock.
Thanks.
savio7 is offline   Reply With Quote
Old 01-05-2004, 04:17 PM   #7338
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Trackdesigner-
Go to the AE Website and download the instruction manual....it shows the car perfectly and how it gets strapped into the car.
Don't you have a TC3? You said about 2 months ago that you did???
mike_Webb is offline   Reply With Quote
Old 01-05-2004, 05:23 PM   #7339
mab_man20's Avatar
Send a message via AIM to mab_man20
savio7: The gearing greatly varies depending on your driving style and track size. What are the approximate dimensions of the track and are you able to run a full race without crashing? For foams most people run from 60-57 mm, 60 being a good starting point and working until either performance drops off or there is no foam left.
As for brush spring combos for the monster. 99% of people agree that the red(+)/green(-) springs work very well. Recently ive been using Hurricane's gold brushes and have been very pleased with the results (www.teamhurricane.net). Other brushes that work well are Reedy 767, and trinity 4499 (or "99" brushes).
mab_man20 is offline   Reply With Quote
Old 01-05-2004, 05:28 PM   #7340
Default 200 mm body on TC3 ?
I'm looking at doing a Porsche gts body on a TC3 chassis. Associated lists the chassis as 190 mm but the HPI Porsche is 200 mm. What would the consequences be?
ropedog is offline   Reply With Quote
Old 01-05-2004, 06:20 PM   #7341
I think actaully AE makes somethin that can make the elec TC3 200mm (actually I think thats the rally conversion kit correct me if Im wrong)
Old 01-05-2004, 06:42 PM   #7342
etzkev's Avatar
Send a message via AIM to etzkev
Yes, its the rally conversion kit that makes the electric tc3 200mm instead of the normal 190mm.
-etzkev
etzkev is offline   Reply With Quote
Old 01-05-2004, 06:48 PM   #7343
stormperson's Avatar
Send a message via AIM to stormperson
Does the losi tower have the same mounting points? And I dont think josh actually ran the losi tower, he just used it to re-enforce the stock one, or thats what I heard last, lol.
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 01-05-2004, 07:27 PM   #7344
Arun's Avatar
Originally posted by ottoman
Does anyone know who makes a nice sway bar mount for the TC3? The stock system sucks... I did see a trick mount at the Cleveland race but the guy only knew that it came from Japan.
Here is a place in English:
http://precisionrc.com/cgi-bin/cart.pl?IT=SQR2-STC18
http://nexusracing.com
Arun is offline   Reply With Quote
Old 01-05-2004, 08:03 PM   #7345
Default 200 mm rally kit
Thanks all for the Replies...
Would the Rally converted TC3 still comply with ROAR specs? I saw a retail site that stated the HPI porsche was rated as class '1' (ROAR qualified) but this doen't address the Rally conversion option.
Old 01-05-2004, 08:27 PM   #7346
Super Moderator
Grizzbob's Avatar
No, for ROAR-sanctioned racing, electric touring cars are limited to 190mm width, so the rally conversion would make a TC3 illegal under those rules(but if you want to try it & the tracks you may want to run on don't mind you using it, then feel free to try it)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 01-05-2004, 08:44 PM   #7347
Yes, you're right. I was just at the ROAR site and stock touring requires a 4 door sedan. The porsche would be a 't-2' rig for a GT class which the local track doesn't run....
Maybe I'll set one up later for fun but for now will stay to the family car chassis...
Old 01-05-2004, 09:38 PM   #7348
mab_man20
Thanks for the reply. Track is 100x45. I can stay off the boards for 5 mins. What pinion should I use with a monstor stock?
Thanks.
Old 01-06-2004, 07:26 AM   #7349
DaveW's Avatar
Rayhuang: Try checking the two bearings in the middle of the diff. If they are the wider ones used in the steel outdrive set, they will keep the diff far enough apart to allow slippage, but still keep it all together, no matter how tight you make it. The bearings that ASC released to fit in the plastic outdrives are what you want to use, they are the same size (thickness) as the bushing used in the lightweight outdrive set from ASC, but thinner than the bearings used in the steel outdrive set. It sounds to me like you have the thicker bearings from the steel set (which is the same bearings used in all of the ASC/B2-4,T2-4, GT differentials) and it is not allowing your diff to tighten properly. Now i also understand ASC has stopped production of this bearing for the lightweight outdrives, if you cannot find them, you can get them from www.acerracing.com. If you happen to order the ceramic pro bearing kit, they (4 for both diffs) come with it! Otherwise you can order them separately, and get them in a matter of days for nominal cash flow. I ran into the same problem, considered using the bushings because they fit, but didnt have the heart to ruin such nice outdrives with the wear of bushings. Another possibility, but not a probability... if you are a racer that resurfaces your diff rings on 1000 grit sandpaper, then you can sand them too thin, and have the same problem. They are usually only good for two resurfacings on each side, then the ring needs to be replaced. The ring will get so thin the bushings/bearings in the middle of the diff will be pinched between the outdrives, and the rings will not touch the balls in the ring gear enough to actuate as anything more than a slipper, or if tight enough, a spool. Hope this helps a little...
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 01-06-2004, 07:26 AM   #7350
rayhuang's Avatar
Default Re: Re: Aluminum diff help
Originally posted by Bubblestc3
I know that when the ae diff thrust spring gets kind of old, it has a tendency to do something similar to what your hc diff is doing...
Also, if it has bushings/berrings, check to make sure that they are the correct dimentions(not too wide, then not enough tension on the diff balls and then sliping occurs)
I don't run Hardcore diff's, but if I were in your position, that is what I would put my attention towards...
Thanks Bubbles. I gave up and put another IRS diff in back last night and it is fine now. ITs also much easier to set the lash on the IRS one. The dimensions on the HC ones seem much different than on the IRS or plastic ones. You have to shim them a lot or the body of the diff rubs the diff cases....hmmmmmm.
I put all the internals of the HC diff back into the plastic diffs and it built up perfectly.
Strange-but all better now-thanks!!!
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
