Old 12-18-2003, 01:08 PM   #7216
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Default Re: wyd
Originally posted by jafucd
Hey where is Turn Marshall Tommy ??????????
Well you never know. Check the 1/12th scale thread. He is in that thread some.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 12-18-2003, 03:23 PM   #7217
PitCrew's Avatar
Mab-
Try a longer or higher camber link. Inside upper hole on the tower, and outside on the hub. Or try leaning the shocks in one hole on the rear. (makes them a bit softer initially)
PitCrew is offline   Reply With Quote
Old 12-18-2003, 03:47 PM   #7218
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Originally posted by Ophidian
I'm having a problems with a bad tourqe steer on my TC3. Anyone has a fix for it?
Solutions...
Rebuild the shocks, and make sure they have equal lengths. Make the droop the same left to right(front and rear can be different for different setups). Make sure the springs have equal tension(ie. color weight the same)(again, left to right, front to rear can differ). Check tires for akward wear patterns. Drop the car onto a Tweak Station to make sure the car is flat. After all of this, run the car and if it still torque steers, take out some droop on the left rear arm. Take out the droop until the car launches straight.
Bubblestc3 is offline   Reply With Quote
Old 12-18-2003, 03:56 PM   #7219
mistercrash's Avatar
R/C Tech Charter Subscriber
Default For anyone interested
The URL of my website has changed....again! You can now find it @ http://www.mistercrash.ca
No brain, no headaches.
mistercrash is offline   Reply With Quote
Old 12-18-2003, 03:57 PM   #7220
Originally posted by mab_man20
Try going back to the 2 degree caster blocks instead of the 4. The added caster gives you great turn in, but it drastically reduces steering coming out of a corner.
Now my question. Im looking for a little more rear traction, but just a little. I dont want to change springs, camber angles, or shock locations. I dont run a rear sway bar, rear droop is 7mm (biggest possibility for change...possibly reduce to 5mm), 2 degrees anti squat, -2 degrees rear toe, and ride height is 5mm.
Im thinking of one of the following:
Reduce droop to 5mm in rear.
Increase front shock oil by 5 #.
Increase anti-squat.
Any suggestions? comments? other ideas?
edit: grammer
What I would do, is reduce the rear anti squat to give more on-power rear traction, or add some rear toe for off-power rear traction(R-2-0, or R-3+2)
Are you measuring the droop by height off a flat surface to the outside of the arm? Or are you using the ae Droop gauge?(pretty sure it is the height, but not 100%)
If you were to add more anti squat, then the car would have more steering exiting corners, because it changes the angle of the arm. Thus making the suspension feel stiffer.
If you were to increase the front shock oil by 5wt, then it might upset how the car enters corners and give you less steering. From what I read, you want more REAR traction, so I would stick to rear-end adjustments.
Old 12-18-2003, 04:02 PM   #7221
PitCrew's Avatar
Thicker oil up front will make the car react quicker to steering input. More turn in.
Old 12-18-2003, 08:04 PM   #7222
stormperson's Avatar
Send a message via AIM to stormperson
Hi,
I was wondering if anyone knew of someone who could machine down a front bumper and arm mounts so that that the car has a lower roll center. Please email me stormperson@hotmail.com thanks!
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 12-18-2003, 08:35 PM   #7223
mab_man20's Avatar
Send a message via AIM to mab_man20
Thanks guys. Now i have some stuff to churn around in my brain.
Brian: Its on power, exiting the corner (most notably coming out of the front sweeper and into the chicane right in front of the drivers stand. If i get on the throttle a little to early/hard it takes me about 3-4 inches off my line and into that island.)
Pitcrew: My shocks are already all the way in, ive never messed with camber link positions, but that may be the easiest thing to test. Any noticable differences between longer vs. higher? Ie going high outside on the block and the shock tower vs moving the mounting position in the block out forther only? or will doing both longer and higher net the best results?
Bubblestc3: I ment to say reduce, thanks. Im so used to running the -2 degree toe i completely forgot that the 3 degree would give me more traction through the corner and help with the steering. Thanks. Ill give the 3+2, 2+0 and the 3+0 a try (in that order of course). I set my droop with a flat surface, the gauge would be a lot easier though (add it to the ever increasing list of cool crap i need )
Im under the impression that increasing the front oil by 5#'s will make the steering more responsive (less side to side motion), but lose a little traction because less weight is transfered forward. If it dials in the rear there are still lots of ways for me to get more steering. Im good at that, its getting the rear to be just perfect that is proving to be more elusive.
Thanks a lot to everyone...please feel free to offer more tips and insights.
mab_man20 is offline   Reply With Quote
Old 12-19-2003, 05:27 AM   #7224
mab: I missed the start of your posting however, lean your shocks out! If you can drive your car with your shocks leaned stood up then you can drive a fast car. Also have u tried an alfa body? And 7mm's is way to much rear droop, you are trying to get steering from places where it shouldnt come from, lol. Also on carpet, there is nothing like 6 degree blocks! I have yet to see a fast TC3 on carpet without 6 degree blocks in the past year or so. Also if you are running on carpet I would stick with an F-0 front block.
Camber links will adjust your reactive camber. The longer the link the less camber change and thus the more grip. Its actually kinda odd because i am pretty sure for full scale racing its the opposite, and it makes more sense too... lol. Not sure on moving up or down there.
And the tweak stand isnt really that useful. For a tc3, you should tweak your car on the track and always run the same size tires left to right, lol. None of the factory drivers that I know really use a tweak stand.
Team Pickles
Old 12-19-2003, 04:00 PM   #7225
Moderator
Speedo's Avatar
Has anybody else tried using the lower-inner hole for the camber link on the rear tower? I tried this at the club race the week before our two day race and had very good luck, it seemed to free the car up a lot and take away the slight push I had.
I have 2 degrees rear toe, all shocks in middle hole on tower, rear is outer on arm and front is inner, front tower on front, 2 deg. total castor (0 kick up 2 castor), 1.5 deg. camber, 0 toe, yellow springs front/60wt, purple springs rear/50wt, no antisquat, standard sway bars front and rear, 5mm droop front and 4mm rear, plaid front, dbl pink rear, custom made front hubs imitating the Dumas part with the extra hole further back, and batteries forward. Also was using the Proto Alfa 2.0 with the large wing size.
At the two-day race other people's cars were inconsistent but mine stayed excellent throughout the weekend. I could adjust the amount of steering easily by just altering my dual rate setting, or using more or less paragon on the front tires.
One question: what would be a good set of bearings? I have the standard ones still, but a few are starting to go and Id like to install a better set in the car. Are ceramics worth it, or just good quality steel bearings?
Speedo is offline   Reply With Quote
Old 12-19-2003, 04:56 PM   #7226
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Josh,
I went from the upper inner holes all around to the lower inner and yeah, it seemed to free up the car in the corners, was more consistent..and faster!
I'd just get some more teflon sealed ones, like from Acer. $30 you can't beat that. A couple people I know have just run the teflons with the stock grease in there and after a few race weekends the driveline is really free even with the grease. You could get ceramics and have a super-free drivetrain, but I hear that they're quite fragile and a hit can blow the bearings pretty easily.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-19-2003, 08:32 PM   #7227
Moderator
Speedo's Avatar
That's cool, I'll have to try dropping the link in the front also. I think we did that with the older yok's too, and it worked well.
$100+ is alot for bearings that might shatter.
Thanks,
Josh
Old 12-19-2003, 10:53 PM   #7228
JasonC.,
Hey, did you get the handling back on your TC3?(do you need help ?)
Are you coming to SoCal tomorow?
And, if you do come, are you going to race?
Ok, I am not making any promis's, but I am THINKING of running 19t tomorow... You interested?
Old 12-21-2003, 12:46 PM   #7229
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
Thanks,
Josh
Speedo...the new style ceramic bearings will not shatter...The only thing harder than the ceramic balls are a diamond. That is what is used to shape and polish the balls. This is the reason the ceramic bearings are so expensive. The very first ones that came out 2 or 3 years ago would shatter...they were a very low grade. I have been running a set since the snowbirds last year and they still spin smoother and longer than ANY steel bearing I have ever had!!
ea
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 12-21-2003, 01:13 PM   #7230
Moderator
Speedo's Avatar
Thanks for the info, maybe some ceramic bearings are in order. Do you care for them like you would steel bearings, or can you just leave them alone?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
