Like Tree4Likes
Old 12-15-2003, 03:42 PM   #7186
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
hey, Im taking the motor and ESC out of my T3 RTR and putting them in my TC3 so I can do some preliminary carpet testing. I have two questions. First, is it smart to put the T3 RTR motor in a TC3 and second, how would you gear it with the stock TC3 spur?
trackdesigner71 is offline   Reply With Quote
Old 12-15-2003, 04:45 PM   #7187
Horatio's Avatar
Exclamation
Rinkrat99:
Centralising problems with Hitec 'stuff' is almost always related to the Hitec transmitters - the pots they use need to be stripped down and cleaned after the first few weeks of use!! I know, cos all my Hitec Flash 3 40 fm radios have developed the same fault.
The servos on the other hand have always worked just fine, evident when I use Tx's from other brands like KO and Futaba
Horatio is offline   Reply With Quote
Old 12-15-2003, 06:50 PM   #7188
JoshR 85's Avatar
HeY!!!
Trackdesigner71 it all depends on how big the track is to gear at it and how open the track is if it's got sweepers at both ends full straight 180's really tight sections and all that.
JoshR 85 is offline   Reply With Quote
Old 12-15-2003, 07:21 PM   #7189
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Is the motor from the T3 RTR Special?(the MVP), if so, then the motor should work just fine in the TC3, but if it is the sealed endbell motor then it will not be fast what so ever. Gearing for the MVP is all realitive, and I gear my MVP at 7.14 ish for medium sized asphault racing.
Bubblestc3 is offline   Reply With Quote
Old 12-15-2003, 10:11 PM   #7190
Arun's Avatar
Default Re: Re: drive train questions
Originally posted by jcrouse
I mean they RUB the spring on the rear shocks.
Duh,
John
My plastic CVDs used to rub the rear shock springs too. I just took some of the AE mini 4-40 nuts and put an additional one on the top and bottom of the shock screws to space it away. Now I use different shocks so it isn't a problem.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 12-16-2003, 01:06 PM   #7191
Thumbs up To rinkrat99
Try to use KO PROPO , PDS-2143FET, its digital servo , very accurate, quick response and I havent had any problems yet. I hope this helps
TAC3 is offline   Reply With Quote
Old 12-16-2003, 04:51 PM   #7192
So what bodies are you guys running?
Old 12-17-2003, 03:03 AM   #7193
Arun's Avatar
I run the Alfa 2.0 right now. It seems to allow the car to switch directions a lot easier.
Old 12-17-2003, 04:40 AM   #7194
R/C Tech Charter Subscriber
Send a message via AIM to acyrier
Default Bodies
I'm sure it's not a leagal body, but our track is allowing most any tc body, it's the HPI Lotus Elise Body. Seeems to really keep the car planted.
The products and places I support.
www.michianarc.com www.facebook.com/michianarc - www.russellrc.com
www.teamtekin.com - www.teamcrc.com - www.teamassociated.com
www.fantomracing.com - www.discountrcstore.com
acyrier is offline   Reply With Quote
Old 12-17-2003, 06:50 AM   #7195
Trader Rating: 37 (100%+)
Have you had any clearance problems when using the RPM ballcups?
i only use the bigger RPM ballcups for certain turnbuckles...not all of them.
the steering turnbuckle i kept stock....because of clearance. i didn't want to shave anything on the car because it might loose some of it's rigidity.
after xmas i'll have a digital camera and be able to post pics of it.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 12-17-2003, 06:57 AM   #7196
Send a message via AIM to Justin Zorc
the associated offroad ball cups are also good... i prefer them over the rpm's an dthey can be used on all ball studs except the steering horn and rack. they are also free right from when they are snapped on.. so no more polishing ball studs. for bodies wither the alfa 2.0 or mazda 6. they seem to be the best overall right now...
Justin Zorc is offline   Reply With Quote
Old 12-17-2003, 05:25 PM   #7197
I'm sorry, I did not make my question clear
I already have my body for my TC3, I was just curious to which body some of the comunity was using.
I'll look for a picture of which body I am using...
Old 12-17-2003, 05:40 PM   #7198
Here, I found one...
Old 12-17-2003, 05:55 PM   #7199
Another...
Old 12-17-2003, 06:14 PM   #7200
Registered User
Post bodys
hey chris, im running the voxhaul and alfa 2.0
muggleh8tr is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
