Old 12-04-2003, 10:24 PM   #7096
davepull's Avatar
ive always run a 98
davepull is offline   Reply With Quote
Old 12-04-2003, 10:36 PM   #7097
Send a message via AIM to Johnnytc3
laptraffic i have some email me for some pics.
johnnytc3@hotmail.com
Johnnytc3 is offline   Reply With Quote
Old 12-05-2003, 05:07 AM   #7098
Speedie's Avatar
Default Re: 64 Pitch
Originally posted by nitromike
What's the most popular sizes of 64 pitch spurs to use on a TC3?
The more teeth you have on your spur gear the more tunning options you have. For everty tooth you add to your spur you double the number of steps you have to adjust off of. I run a 100 tooth basicly just to make it easy to figure out gear ratio.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 12-05-2003, 01:39 PM   #7099
tc3rookie's Avatar
Default equilivent
what would be the 64 pitch equilivent of a 72 tooth spur and 24 tooth pinion? 98 or 100 teeth spur.
tc3rookie is offline   Reply With Quote
Old 12-05-2003, 01:55 PM   #7100
Trader Rating: 36 (100%+)
tc3rookie.
that gives you a ratio of 7.50
in 64pitch....
98 spur + 33 pinion = 7.42
100 spur + 33 pinion = 7.58
you can download the whole gear ratio chart from the AE website.
Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 12-05-2003, 03:50 PM   #7101
What is the magic formula for calculating rollout on the tc3?
sook is offline   Reply With Quote
Old 12-05-2003, 04:37 PM   #7102
tc3rookie's Avatar
Default formula
Sook:
i don't know a formula, but this is my favorite calculator for rollout:
http://www.easy-rc.com/gearratios/
BTW; thanks for the #'s, Nexus.
Old 12-05-2003, 05:28 PM   #7103
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
100t with Stock, and sometimes 104t with mod...
Bubblestc3 is offline   Reply With Quote
Old 12-06-2003, 11:11 PM   #7104
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Default Bump Steer
I was looking at Barry's set up sheet and under bump steer it says .60.
How many of the white spacers is that? Also, the spacers that are used are the ones you use for the wheel base to make it short or long, right?
Thanks...
wolfeman09 is offline   Reply With Quote
Old 12-06-2003, 11:43 PM   #7105
Send a message via AIM to R/C Anonymous
can anyone help me get the chattering out of my car...it happensin cornering...i tried putting lighter shock oil in but that doesnt help...im using takeoff 27's
Front:
rear shock tower onfront middle hole and outer hole on arm
50 wt oil #2 pistons
0 toe in/out-1.5 camber F+2
front AE sway bar and just put in a front one-way
Rear:
middle hole and outer on arm
30 wt. oil #2 piston
R3+2 block
-1.5 camber
Jack the Gripper full on back and inside 1/3rd on front
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 12-07-2003, 01:13 AM   #7106
Registered User
What is the advantages and disadvantages using solid front axle instead of using diff.?
Aku-Man is offline   Reply With Quote
Old 12-07-2003, 06:30 AM   #7107
Send a message via AIM to vere513
R/C Anonymous
well for the first thing the shock oil is too heavy try 25-30 wt oil lighters springs and try 2 on ur camber
vere513 is offline   Reply With Quote
Old 12-07-2003, 07:21 AM   #7108
lem2's Avatar
Default R/CAnonymous
Originally posted by vere513
R/C Anonymous
to add from that, remove the sway bars, try silver front green rear. Looks like your tracks is bumpy?
lem2 is offline   Reply With Quote
Old 12-07-2003, 09:33 AM   #7109
tc3 racer sc's Avatar
Default putting 4 block in rear
what page on this form about putting f- block on rear and adjusting rear toe with diffent set ups thxs let me know
tc3 racer sc is offline   Reply With Quote
Old 12-07-2003, 01:03 PM   #7110
lem2...its actually a very smooth trackexcept for one small sweeping corner...check it out at www.roadragehobbyspeedway.com
Geoff C.
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
